Old 03-13-2021, 01:58 AM   #15
pro_turbo
Drives:
Originally Posted by PulsarBeeerz View Post
IIRC the two twins that were actually able to make use of the GReedy ITBs by running them open like Gawd intended are both running MoTec.
noob question
what or who is IIRC
pro_turbo is offline   Reply With Quote
Old 03-13-2021, 02:06 AM   #16
pro_turbo
Drives:
Ill try to upload video when i drive the car. If cant i will upload on youtube
Old 03-13-2021, 03:16 AM   #17
Ultramaroon
not playing cards
Ultramaroon's Avatar
Originally Posted by pro_turbo View Post
noob question
what or who is IIRC
Shorthand for If I Recall Correctly.
BrahmaBull1990 (03-15-2021)
Old 03-15-2021, 11:10 PM   #18
BrahmaBull1990
Howdy
BrahmaBull1990's Avatar
Drives: 2020 BRZ PP
I did not know this, either.
Nice post; nice Chewy avi.
There's a point at 7,000 RPM... where everything fades. The machine becomes weightless. Just disappears. And all that's left is a body moving through space and time. 7,000 RPM. That's where you meet it. You feel it coming. It creeps up on you, close in your ear. Asks you a question. The only question that matters. Who are you?
BrahmaBull1990 is offline   Reply With Quote
The Following User Says Thank You to BrahmaBull1990 For This Useful Post:
Ultramaroon (03-16-2021)
Old 03-17-2021, 03:17 AM   #19
pro_turbo
Drives:
Here are the video on youtube. Full comparison
Old 03-19-2021, 02:39 AM   #20
pro_turbo
Drives:
no one comment on this?
Old 03-19-2021, 04:04 AM   #21
steve99
Id guess motec have not done a lot of work with auto transmissions maybe motec assume anyone using motec is racing and will use full manual mode all the time ?
usually you need sport mode on transmission for auto blip ??
Also with stock setup the transmission ecu stops doing auto blip and shifts differently when transmittion detects problems with its own control unit readings or the engine ecu data. If motec not providing correct info to transmittion computer likey why auto blip dioesnt work and shifting lazy
If transmission shifting works fine with stock ecu then id say its just motec have not got all the auto transmission communications correct between teansmission ecu and engine ecu. There is likely a lot of data exchanged between the two control units ie engine and transmission, likey a lot we dont know about. throttle position , engine load, road speed gear rpm ignition retard on shift . The transmission ecu likely sends data back to engine ecu like shift complete shift in progress maybe has economy mode at light throttle and more. Its unlikely anyone but motec can fix those issues.
My only suggestion would be go back to stock ecu and ecutek to control the boosted engine if is cost effective to sell motec and purchase ecutek cable and licience
nikitopo (03-19-2021)
Old 03-20-2021, 08:34 AM   #22
pro_turbo
Drives:
My man steve is here finally..
Thanks steve for your comments.
Yes i agree it seems motec is more focused on manual
Then why they launch the auto packages ?
Dont make sense right ?
Yes .. the blip is fine wigh stock ecu. Just have bottom limit speed i guess. Like 70kmh
Below 70 they not present.
No need push sport mode.
So basically leave the blip and flat shift later on
I just focussed on two things
1. Start button has to pres 2 times with motec
2. Light throttle. The hift up is always after 3000rpm with motec.. it feels very rough.
And fuel consumptions is damn..
With stock ecu i can reach 6-8 liters per 100Km on 80-90kmh speed
With motec it was 12-14 liters/ 100km
Well yeah i was thinking of going ecutek.
But motec guy just came and replied my email lately.
Nathan and stephen dean who wrote the packages himself is working on it.
I will give them a try.
I still believe a 5000$ ecu has to be better than stock at least.
I cant wait to install my supercharger and go to track again.
The Following User Says Thank You to pro_turbo For This Useful Post:
steve99 (03-22-2021)
Old 03-23-2021, 01:12 PM   #23
degozaru
Drives: 2016 oceanic frs
that 5000$ ecu assums you know what you're doing. If you arent, better to get a tuner to handle it for you.
degozaru is offline   Reply With Quote
Old 03-24-2021, 01:25 AM   #24
pro_turbo
Drives:
even on the motec dealer they are stuck with this.
4 years i ve been working to solve this
no motec au is just begin to start collecting all data they need from my logs
and can analyser
Old 03-24-2021, 07:41 AM   #25
BrahmaBull1990 (03-24-2021), ermax (03-24-2021), NoHaveMSG (03-24-2021), RToyo86 (03-24-2021), Ultramaroon (03-25-2021)
Old 03-24-2021, 09:58 PM   #26
ermax
ermax's Avatar
Okay @ you had me cracking up over here. Hahaha
Old 03-26-2021, 12:33 PM   #27
pro_turbo
Drives:
Anyone had no experience this
It seems motec AU is giving up soon
Nathan already said.. its worthless to chase 1 car problem which is mine. And they put the blame on the car. Because other car is working fine.
Well i guess i will have to solve this my self
Old 04-11-2021, 03:59 AM   #28
nikitopo
nikitopo's Avatar
Drives: '15 BRZ RA
Looks that Motec on-boarded to our platform as vendor, without much internal product research and development. Easy money!
I was told in the past by a "racing" team in Germany to swap the factory ECU and install a Link G4+ Extreme ECU. They were insisting that this was the best option and we would even have to travel at a tuner in Belgium (?!) to make the tuning of the maps. I was lucky enough to not bite the bullet and start doing nonsense.
Swapping the factory ECU to another vendor's ECU ...
The Following User Says Thank You to nikitopo For This Useful Post:
pro_turbo (08-24-2021)
MoTeC FT86 Titanmotorsports Software Tuning 7 02-25-2021 03:11 PM
MoTeC on an Android tablet? GrabTheWheel Software Tuning 4 03-04-2019 08:41 PM
Motec M150 smudge Want-To-Buy Requests 0 02-07-2018 09:55 AM
Motec / Steering interface. Nigelr32 Software Tuning 1 09-24-2015 10:51 PM
MOTEC coyote Software Tuning 16 02-09-2014 11:41 AM
