#15 |
Professional Mechanic
Drives: 2017 86 6MT Oceanic
https://demos.starbase7.net/t3Portal/
Navigate to 2015 Repair Manual > DRIVETRAIN > TX6A AUTOMATIC TRANSMISSION / TRANSAXLE > AUTOMATIC TRANSMISSION SYSTEM You'll find the complete wiring diagram in > SYSTEM DIAGRAM, pinouts at > TERMINALS OF ECU (sorry, I said test at PCM, I meant test at TCM which is on the other side of the dash, I'm too used to cars that have transmission functions integrated in the PCM), and a complete troubleshooting workflow in the header dedicated to the trouble code you've got. The basic diagram in > P0707,P0708; Transmission Range Sensor "A" Circuit Low shows all the PNP does is take 12V from IG1 #1 relay and Backup Lamps fuse and patches it to one of 4 pins on the TCM depending on the position. *** this brings up a good point! check your BKUP LT fuse ***So with your DVOM set to voltage, you can backprobe each of those wires at the TCM to see if the PNP switch is sending voltage to the appropriate circuit in each position. Last edited by RZNT4R; 01-24-2021 at 03:16 PM. |
#16 | |
Drives: 2015 Toyota 86 GTS AT
#17 |
#18 |
I discovered the issue yesterday. And my god, I am physically unable to shake my head enough. I swapped my headunits to an android headunit some time ago, but I didn't connect the reverse camera. I just left it as a naked wire inside. After reading a wiring diagram I decided to fully unplug the headunit and replace the bkup light fuse. AND IT WORKED all the dash lights are off, the car turns on functions normally. I cant believe that something so simple was the cause of all these issues and all this trouble
#19 |
What did I say on the first page?
"I've seen what people do trying to fix cars and let me tell you, it's nasty." And your last dealership adventure is in line with what I expected: they had a code and tried to throw a part at it. They didn't try to find the issue. May this be a lesson: any person looking at even the basic diagram would have seen the fuse, and the first thing you check is the fuse. The dealer tech didn't check the fuse. You checked the fuse. You win (even if you caused the issue :P ) |
#20 |
Drives: Firestorm red FRS 2015
Hey! You saved my sanity. It was blown for me too. I replaced it in my car. Started functioning normally, but it blew again. My backup unit is hooked up and nothing is changed but it blew again. I'm not sure what the problem is but I disconnected my backup and going to get some more fuses and do some testing
| Tags |
| control module, ecu, ecu issue, electrical issues, transmission issue |
| how many rpms do you rev at starting off first gear? | 2isballer | Scion FR-S / Toyota 86 GT86 General Forum | 84 | 08-03-2015 06:40 PM |
| Starting off in 1st gear | Phantobe | Scion FR-S / Toyota 86 GT86 General Forum | 150 | 07-19-2014 06:21 PM |
| Starting in 2nd Gear? | Manic | Scion FR-S / Toyota 86 GT86 General Forum | 61 | 11-03-2013 03:55 PM |
| starting in second gear | cantaloupe | BRZ First-Gen (2012+) — General Topics | 38 | 03-11-2013 07:18 PM |
| Another way of starting from 1st gear..help | tintumz22 | Scion FR-S / Toyota 86 GT86 General Forum | 32 | 09-24-2012 01:14 AM |
