Old 01-24-2021, 01:21 PM   #15
RZNT4R
Professional Mechanic
Drives: 2017 86 6MT Oceanic
https://demos.starbase7.net/t3Portal/
Navigate to 2015 Repair Manual > DRIVETRAIN > TX6A AUTOMATIC TRANSMISSION / TRANSAXLE > AUTOMATIC TRANSMISSION SYSTEM
You'll find the complete wiring diagram in > SYSTEM DIAGRAM, pinouts at > TERMINALS OF ECU (sorry, I said test at PCM, I meant test at TCM which is on the other side of the dash, I'm too used to cars that have transmission functions integrated in the PCM), and a complete troubleshooting workflow in the header dedicated to the trouble code you've got. The basic diagram in > P0707,P0708; Transmission Range Sensor "A" Circuit Low shows all the PNP does is take 12V from IG1 #1 relay and Backup Lamps fuse and patches it to one of 4 pins on the TCM depending on the position.
*** this brings up a good point! check your BKUP LT fuse ***
So with your DVOM set to voltage, you can backprobe each of those wires at the TCM to see if the PNP switch is sending voltage to the appropriate circuit in each position.
Old 01-30-2021, 09:49 AM   #16
Abz 86
Drives: 2015 Toyota 86 GTS AT
A little update, I decided to give the car to a different Toyota dealership and this is what the came up with.(attached JPEG) This is probably the fourth time I've been told it's the park/neutral safety switch. And have since got 2 second hand ones and neither have solved the problem. The rear light issue seems interesting. I am going to revert the reverse light back to stock and replace the fuse and see if anything changes
Abz 86 is offline   Reply With Quote
Old 02-01-2021, 12:43 PM   #17
RZNT4R
Originally Posted by Abz 86 View Post
(attached JPEG)
JPEG not attached
Old 02-01-2021, 08:16 PM   #18
Abz 86
JPEG not attached
I discovered the issue yesterday. And my god, I am physically unable to shake my head enough. I swapped my headunits to an android headunit some time ago, but I didn't connect the reverse camera. I just left it as a naked wire inside. After reading a wiring diagram I decided to fully unplug the headunit and replace the bkup light fuse. AND IT WORKED all the dash lights are off, the car turns on functions normally. I cant believe that something so simple was the cause of all these issues and all this trouble
Old 02-01-2021, 09:22 PM   #19
RZNT4R
The cause was human all along
What did I say on the first page?
"I've seen what people do trying to fix cars and let me tell you, it's nasty."
And your last dealership adventure is in line with what I expected: they had a code and tried to throw a part at it. They didn't try to find the issue.
May this be a lesson: any person looking at even the basic diagram would have seen the fuse, and the first thing you check is the fuse. The dealer tech didn't check the fuse. You checked the fuse. You win (even if you caused the issue :P )
Old 01-24-2023, 04:34 PM   #20
arrow34
Drives: Firestorm red FRS 2015
Hey! You saved my sanity. It was blown for me too. I replaced it in my car. Started functioning normally, but it blew again. My backup unit is hooked up and nothing is changed but it blew again. I'm not sure what the problem is but I disconnected my backup and going to get some more fuses and do some testing
arrow34 is offline   Reply With Quote
control module, ecu, ecu issue, electrical issues, transmission issue
how many rpms do you rev at starting off first gear? 2isballer Scion FR-S / Toyota 86 GT86 General Forum 84 08-03-2015 05:40 PM
Starting off in 1st gear Phantobe Scion FR-S / Toyota 86 GT86 General Forum 150 07-19-2014 05:21 PM
Starting in 2nd Gear? Manic Scion FR-S / Toyota 86 GT86 General Forum 61 11-03-2013 02:55 PM
starting in second gear cantaloupe BRZ First-Gen (2012+) — General Topics 38 03-11-2013 06:18 PM
Another way of starting from 1st gear..help tintumz22 Scion FR-S / Toyota 86 GT86 General Forum 32 09-24-2012 12:14 AM
