#15 | |||
Drives: 2022 GR86
![]() If none of them are directly compatible with the software you use, there are still a couple more options: a) Ask the RC developer to add those export formats (he is fairly responsive, and generally open to support more import/export formats) b) Write your own converter from one flavor of CSV to the one you need (in case you have at least basic Python knowledge) Quote:
Add 5) ability to conveniently review data between sessions With RaceChrono, you can review data whenever you can use a phone. In my personal experience, it's incredibly useful to be able to see the sector breakdown and comparison between laps. After each session I see where my next "opportunities" are, and focus on those, rather than "try to mildly overcook the whole lap and see what happens". I believe most AIM products require using a laptop (laptop!) and additional software to be able to review things. That IMO is something not everyone is going to bother doing after each session. Whereas with RaceChrono (and probably HLT?), reviewing data is so accessible that why not? |
#16 |
Drives: 2013 SWP BRZ Ltd. / E60 M5
Any solution that requires wireless connections and multiple different pieces of hardware working in conjunction is going to be more prone to error. Look at the number of Harry's lap timer videos where the speed clearly is not matched to or consistent with what you are seeing on the video.
Any system that does not automatically overlay data and video together quickly just makes it harder and more time consuming to watch video and data together. Although data analysis on its own can be very informative, for a lot of people, hovering over a laptop in between sessions etc. just doesn't work. Data analysis post-track day with notes for the next time you go to that track is often the outcome. I bought an AIM dash thinking I would use data in between sessions, overlay video at lunchtime and overnight before day 2. I used the GoPro I already had instead of paying over a grand for a smartycam. After one season of screwing around with that, I went and got a smartycam. Now, I can pull video immediately after a session, watch it with people, and get instant feedback on what I can do differently. To be clear, video, even with overlaid data is not a substitute for data analysis but it can be very helpful "immediately" when at the track. Just my experience.
2013 BRZ Limited | SWP | Verus Ventus 1 and High-Efficiency Rear Wing | Invidia N1 Ti | JR Oil Cooler | RCE T2 | RaceSeng Cas/Cam | SPL LCA & TA | Wilwood/RR Racing Stage II/Sport Performance | XP10 | Apex ARC-8 | Toyo R888R | 245/40-17 | Sparco Ergo II/Evo II | AIM MXP | SmartyCam GP HD 2.2
| The Following User Says Thank You to Alan For This Useful Post: | CSG Mike (03-08-2021) |
#17 | |||
Drives: 2022 GR86
Since I started logging CAN data, which includes a data channel for the steering angle, it became very easy to sync video to the data perfectly. I first approximately sync audio vs video my checking the map, and then I only need to find one place in the data log where I do some quick steering correction (e.g. counter-steering). The whole process takes less than a minute for me now. You can gauge the quality of results in the examples I shared above. Quote:
That's why Garmin Catalyst is so popular, despite being a $1000 product with no OBD connector. |
#18 |
I am going to start with the following setup
HP tuners track addict Andriod phone External gps Qstarz BT-Q818XT BAFX Products Wireless WiFi (OBDII) Campark X35 Action Camera 4K 24MP Wi-Fi control Tackform Headrest Mount for GoPro ARKON BT010 Windshield Suction Mount for external gps Use the lap comparison built into track addict. Sent from my GM1915 using Tapatalk
2013 Series 10 FRS #553
#19 | |
Drives: 2022 GR86
Just a few weeks ago someone in the 86DC told me that TA still doesn't even support custom OBD PIDs. You really want to be able to log the brake pedal input, and it's not a standard PID. I used Track Addict a couple of times before I tried RaceChrono, and never looked back after I switched to RC. |
#20 | |
#21 |
Drives: 2022 GR86
| The Following User Says Thank You to timurrrr For This Useful Post: | jflogerzi (04-01-2021) |
#22 | |
OBD-II header: 0x7B0 PID: 0x2141 Equation: min(100, 1.1 * max(A-10, 0)) Edit** Got it to work. Just needed to restart my One Plus 7 Pro after I added the custom Channel and its working! Noticed Throttle % idle is at 14. Normal or is there a way to adjust this? Also is there a way to figure out current gear like in Track Addict?
RCE T2's, SPC LCAs -4/2.6 camber JDL 4-2-1 EL, FP and OP, Tuned by Zach@CSG on e85 RR Wilwood Front/Rear Sport BBK, Motul 600 Fluid ARC-8 17x9 SX2 GTs 245s/Koing 17x8 v730's 225's Last edited by jflogerzi; 04-01-2021 at 02:13 AM. |
#23 | |
#24 | ||
Drives: 2022 GR86
![]() See another custom PID I posted on the same thread on July for accelerator. Quote:
TBH, the gear number is not the most useful channel, since you can generally tell the gear by looking at speed and rpm. This is also how the gear is calculated by the ECU anyways. Given how limited is the bandwidth of data over OBD, I'd recommend getting the data on other channels at higher rates rather than wasting bandwidth on the gear number. |
#25 |
With race Chrono do you need to have the channel active on one the screens to get the data available for videos and analysis?
#26 |
Drives: 2022 GR86
No! As long as you select the right channels in vehicle profile, it will be logged even if the RaceChrono screen is set up as a simple lap timer.
| The Following User Says Thank You to timurrrr For This Useful Post: | jflogerzi (04-04-2021) |
#27 | |
#28 |
Surprised Petrel hasn't come up, they nailed quick intuitive data analysis imho. I always struggled with racechrono and track addict to get it to show me what I want, but it's been years since I tried them. If you've got the money for AIM and don't mind whipping out a laptop it's still the best at getting every piece of data synced and ready for review, if I was chassis tuning a serious competition vehicle that'd be my choice hands down (racecapture a close second) but as a hack driver Solostorm and upcoming Circuitstorm focus on where I need the most help.
https://www.petreldata.com/ |
| Data Logger choices : Aim MXL2 - MXS - MXG | philooo | Tracking / Autocross / HPDE / Drifting | 10 | 01-05-2023 10:48 AM |
| Custom data logger prototype | mabviper | Electronics | Audio | NAV | Infotainment | 45 | 09-06-2017 04:36 AM |
| FS: Racelogic PerformanceBox Data Logger | ft86Fan | Miscellaneous | 0 | 09-07-2015 06:26 PM |
| iPhone track data logger app? | Wonderbar | Tracking / Autocross / HPDE / Drifting | 14 | 05-07-2013 04:31 PM |
| ECU Data Logger | Motordyne | Engine, Exhaust, Transmission | 5 | 07-18-2012 10:27 AM |
