Old 12-24-2020, 06:15 PM   #15
Ashikabi
Ashikabi's Avatar
Lengths of the internal standing waves are shorter in the cold. ...and longer at high altitude.
So you gotta change headers in the winter? There's an untapped market
The Following User Says Thank You to Ashikabi For This Useful Post:
Ultramaroon (12-24-2020)
Old 12-24-2020, 10:52 PM   #16
Ultramaroon
not playing cards
Ultramaroon's Avatar
So you gotta change headers in the winter? There's an untapped market.
lol genius
Old 12-25-2020, 10:36 AM   #17
gpvecchi
gpvecchi's Avatar
I worked in audio sector before, and I have some acknoledgment that can be applied to manifolds, too.
They act like organ's pipes, or sub woofers bass refles pipes.
Longer and bigger pipes resonate at a lower frequency, I.E., choosing a resonating frequency of 50 Hz (that is 3000 rpm) for a specific box volume (the cylinder) needs specific diameter/lenght pipe that will resonate at that frequency (and will give more scavenging).
To resonate at the same frequency, a smaller pipe will need a longer tube.
A smaller and longer pipe will have more flow velocity; a too small pipe will on countrary offer too resistance to the flow.
So, this has to be let to engineers, my question is do secondary pipes intervene in this? My hypotesis is that secondaries pipes are more important, as gas velocity will be lower than in primaries, so they have to be more efficient in scavenging.
P.S.: gas temperatures in exhaust manifold are almost the same, around 850 Celsius degrees.
gpvecchi is offline   Reply With Quote
The Following User Says Thank You to gpvecchi For This Useful Post:
JIM THEO (12-25-2020)
Old 12-25-2020, 01:24 PM   #18
gen3v8
30 minute maintenance
gen3v8's Avatar
Drives: My18 wrxsti
The rpm`s vary, so different setups operate better at different rpm. Like the 2s pipe mentioned to voice "Pipe tuning" It has an rpm range and is engineered to suit, port/valve timing, capacity etc. It is also a whole pipe not just a set of Extractors.
P.S. I still think Gun powder,fire,chanting and a dance helps.
gen3v8 is offline   Reply With Quote
The Following User Says Thank You to gen3v8 For This Useful Post:
Ultramaroon (12-25-2020)
Technical question about MT/AT Toyota 1 Engine, Exhaust, Transmission 8 08-27-2017 12:29 PM
New Technical Sub Forum? EarlQHan Site Announcements / Questions / Issues 3 04-30-2015 08:29 AM
technical drawings D K Engine, Exhaust, Transmission 2 12-19-2014 06:21 PM
Technical Issues Thread hyper4mance Site Announcements / Questions / Issues 1 06-25-2012 06:26 PM
