Old 11-09-2020, 08:21 AM   #15
dragoontwo
dragoontwo's Avatar
Drives: 22 BRZ limited
Originally Posted by RToyo86 View Post
If you have fog lights turn them off. I don't run mine in rural areas or I get flashed.
Unless mine are aimed for shit, my fog lights don't seem to do anything in fog for me. I never run mine as they are useless.
dragoontwo is offline   Reply With Quote
Old 11-09-2020, 10:56 PM   #16
soundman98
ProCrastinationConsultant
soundman98's Avatar
Do you use it often?
yes. every time i have more than one person in the car, or load up for a weekend away.
of course, my adjuster is a little more forgiving than everyone else's...
https://www.ft86club.com/forums/showthread.php?t=81277
Spuds (11-09-2020)
Old 11-19-2020, 02:58 AM   #17
2020BRZtS
2020BRZtS's Avatar
Drives: '20 BRZ tS (15/300) / '09 Scion tC
I don't think it's your aim. White light only bounces back at you in the fog, and more so with a brighter white light. If you want them to help in fog, put yellow film over the lens or swap the bulb.
2020BRZtS is offline   Reply With Quote
Old 11-20-2020, 01:21 AM   #18
churchx
churchx's Avatar
Drives: 2014 GT86
Yeah, fog lights partially work with toned light color as certain light wavelengths reflect a bit less, but mostly what's work in fog lights against reflecting off small particles in the air is low placement of foglights and highly limited from above light beam.
Imho people that expect for foglights to be magical replacements for main lights are not too well informed of how foglights are designed to provide light that doesn't reflect much. It's their design bit that they don't illuminate far but have focused close and wide. In light fog one should drive with normal lights, and in very heavy fog or snow storm, when main far lights form "white wall" just ahead of car, they should reduce speed and drive with fog lights, that do the job enhancing illuminating road close by.
Fog lights are not supposed to illuminate road as well & as far as main lights. And if they do, with some chinese aftermarket wonder magic kit, that will compromise their functionality of providing specific focused light beam that doesn't reflect off particles. In countries, that not just regulate, but also check lightbeam of fog lights, it would be MOT fail.
Obviously, chinese aftermarket will make/provide/sell to one whatever one wishes. And if uninformed ones are ones that "vote with wallet" .. well, such life/rules of market. I'd just point, that "Unless mine are aimed for shit, my fog lights don't seem to do anything in fog for me. I never run mine as they are useless." is often due wrong expectations of how specific product is designed to actually work and how/when it should be used.
The Following 2 Users Say Thank You to churchx For This Useful Post:
Jdmjunkie (11-20-2020), x808drifter (11-20-2020)
Old 11-20-2020, 09:15 AM   #19
dragoontwo
dragoontwo's Avatar
The BRZ fog lights are useless. Unlike what you said, I don't expect them to magically brighten everything above the main beams. The only thing they enhance in fog for me is about a foot on either side of the car and that is it. They add no illumination to the front of the car whatsoever. Its nice to see that you have done my thinking for me though.
Old 11-20-2020, 09:55 AM   #20
Cephas
Cephas's Avatar
Drives: 2017 Toyota 86 (860 SE)
That's interesting. The fogs on my 86 are quite good, I think.
Cephas is offline   Reply With Quote
First only left headlight works, then only right headlight russsak Cosmetic Modification (Interior/Exterior/Lighting) 2 09-23-2020 03:05 PM
BRZ headlight shroud inside FRS headlight? S84kam Cosmetic Modification (Interior/Exterior/Lighting) 9 04-02-2016 12:24 AM
Product To Reduce Dash Glare? Captain Snooze Cosmetic Modification (Interior/Exterior/Lighting) 12 08-20-2015 06:55 PM
Tinting mirrors to reduce nighttime glare Assphalt Cosmetic Modification (Interior/Exterior/Lighting) 38 03-27-2015 08:48 AM
WTB Stock headlight projectors from retrofit OR a broken headlight official_george Exterior Parts (Aero, Lighting, Etc.) 3 12-02-2013 03:32 PM
