Old 11-04-2020, 01:43 AM   #15
Captain Snooze
Because compromise ®
Captain Snooze's Avatar
Drives: Red Herring
Originally Posted by Purist View Post
And a side note... I have made a point of only taking performance advice from people who have some trophies in their cabinet.
I'm not sure taking advice from my aunt, who has trophies for cake baking, would help you tune your dampers.
soundman98 (11-04-2020)
Old 11-04-2020, 01:44 AM   #16
Purist
Purist's Avatar
Drives: Subaru BRZ
I came second in a local cake competition once. There were two entries. I was robbed.
Sent from my SM-G973F using Tapatalk
Less More
Purist is offline   Reply With Quote
The Following 2 Users Say Thank You to Purist For This Useful Post:
soundman98 (11-04-2020), x808drifter (11-04-2020)
Old 11-04-2020, 11:09 AM   #17
Racecomp Engineering
Oh I could write a lot about this...and probably will at some point for our theapexfiles instagram page.
But real quick. Yes the type/brand of coilover matters, but not just because of what the range of valving looks like, but how the actual adjustment happens.
Sometimes you have an adjuster that primarily affects low shaft speed damping. This is a bleed adjuster. This'll give you a good control over handling and response if used correctly. Usually less of an affect on ride quality, but still some effect depending on other factors.
Other times, you'll have a shim preload or dish adjuster. This has some effect throughout low, medium, and high shaft speeds. On a shock dyno chart, it's doesn't affect the shape of the curve so much as the amount of force needed for the damper to "blow off" and the "knee" which kind of moves everything up or down.
*there are other, fancier types of adjusters, but most of the time we're dealing with either a bleed or a preload adjuster
There are advantages and disadvantages to both types. Sometimes you'll have 1 adjuster that affects both compression and rebound, other times it'll be 1 adjuster that just affects rebound.
It is very helpful to know what you are adjusting! For example, if you adjust your shocks to full stiff to reduce bottoming but your adjuster only affects rebound....you're making things worse, not better.
Also, a lot of people see it as a good thing when a damper has a huge range of adjustment. Soft is really soft and stiff is really stiff. IMO whether that's good or not depends on how that range is achieved.
I see a lot of "digressive" coilovers with a lot of range, but they actually lack much low speed damping unless they're set to very stiff settings...at which point they're outrageously stiff for low and mid-speed. This tends to happen with a LOT of built in shim preload (without an adjuster) and then a bleed adjuster. The dyno chart might look good on paper at full stiff, until you look at the actual forces.
So, lots of nuance. Shocks are more complicated than just "soft" and "stiff".
- Andrew
The Following 6 Users Say Thank You to Racecomp Engineering For This Useful Post:
Captain Snooze (11-04-2020), Compelica (11-05-2020), nathand (11-07-2020), soundman98 (11-04-2020), TylerLieberman (11-11-2020), x808drifter (11-04-2020)
Old 11-04-2020, 11:10 AM   #18
Bleed adjuster example:
Preload/dish adjuster example:
- Andrew
The Following 3 Users Say Thank You to Racecomp Engineering For This Useful Post:
nathand (11-07-2020), soundman98 (11-04-2020), x808drifter (11-04-2020)
Old 11-04-2020, 11:34 AM   #19
Westen86
Purist
Westen86's Avatar
Drives: 2013 FRS - Hot Lava
Counter Space Garage and Racecomp Engineering are the boulders that hold this website together. You guys post coherent responses all over the forum. Thank you for what you do. If I could afford your parts, I would have bought enough to be a poster car for you guys.
WTB: Everything Verus
RaceComp SS-1, Complete SuperPro bushings, TR Motorsport FF10 17x9 +45, GruppeS UEL, HKS Hi-Power V2, OFT(93/E85)
Westen86 is offline   Reply With Quote
The Following 2 Users Say Thank You to Westen86 For This Useful Post:
Racecomp Engineering (11-04-2020), soundman98 (11-04-2020)
tein flex a, tein flex z
Car clicks but won't crank. Battery or Starter? JERM^ Issues | Warranty | Recalls / TSB 93 09-14-2019 10:11 AM
Tein Street Advance Z - too many clicks for damper adjustment possible Nickmann Suspension | Chassis | Brakes -- Sponsored by 949 Racing 8 04-08-2019 03:10 PM
BC Coilovers - How stiff is stiff? XxFooManDrewxX Suspension | Chassis | Brakes -- Sponsored by 949 Racing 19 09-24-2015 12:53 PM
KW V3: 16 clicks for compression? h3opama Suspension | Chassis | Brakes -- Sponsored by 949 Racing 4 07-02-2015 08:01 PM
Driver side window clicks everytime it opens umpadupa Issues | Warranty | Recalls / TSB 10 10-25-2013 10:20 AM
