| BRZ First-Gen (2012+) — General Topics All discussions about the first-gen Subaru BRZ coupe |
#15 | |
Drives: AP2 S2000, 91 Miata 1.8L Rotrex 5MT
1. The true answer here is that every car is different. The real way to find what camber you should have is done by pyrometer readings and well the lap timer results. Here's a great "how-to" on using a pyrometer. It may be a little over the head of a beginner going to the track, but it's a good skill to have for later. (https://supermiata.com/using-a-tire-...49-racing.aspx) 2. That being said, I can pretty confidently say that even a new driver will want more camber than stock. When I got the car, I baselined it with zero mods and left halfway through the day because the understeer was that bad. I'd recommend at the least, grabbing a set of camber bolts and maxing them out. In my case, doing this did not change my toe a noticeable amount so there was no alignment needed. I would do this after your first track day at the very least. 3. Otherwise, if you are looking for a good set point I would aim for -3 front, -2.5 rear as a starting point. From there use a pyrometer to dial it in. Likely it will need more camber than that. In most cases, lightweight underpowered cars like a ton of camber. I'm around -4 degrees and I could even go further based on my pyrometer readings. I think 949 racing runs more than that on their project car "Blub" too.
2022 Hyundai Elantra N 6MT SCCA TT S3//Will be back in an 86 eventually
| SOLD: Raceseng caster + camber - adjustable front camber plates | higrip | Brakes, Suspension, Chassis | 4 | 09-17-2019 02:43 PM |
| SPC 16mm and 14mm camber bolts - dirty grimey kid's camber dream :) | Joesurf79 | Brakes, Suspension, Chassis | 2 | 01-13-2017 06:03 PM |
| *FREE alignment* with Purchase and install of Front Camber / SPL Rear Camber Arms! | Corner3garage | Southern California | 188 | 04-24-2015 02:10 PM |
| *FREE alignment* When you get Front Camber Bolts and Rear Camber Arms Installed! | Corner3garage | Mechanical Maintenance and Tools | 6 | 10-31-2013 04:40 PM |
