#15 | |
Drives: 2013 FRS GTX3076R
![]() Sent from my SM-G950W using Tapatalk |
#16 | |
Sent from my ONEPLUS A5010 using Tapatalk |
#17 | |
Drives: jrsc_brz
just another option that you might not have considered...
JACKSON RACING l RALLYBACKER l FORGESTAR l FORTUNE AUTO l INVIDIA
| The Following User Says Thank You to HaXx For This Useful Post: | yzf219 (10-14-2020) |
#18 | |
#19 |
Drives: '13 Whiteout
That is Steering Axis Inclination. I does have SOME benefit is certain applications as far as scrub radius however when introducing negative camber that way the tires will most likely hit the struts
| The Following User Says Thank You to TommyW For This Useful Post: | yzf219 (10-14-2020) |
#20 | |
#21 |
Drives: 2016 Scion FRS Release Series 2#439
I use Pedders top mounts which are good for -.75 along with the 14mm camber bolts (bottom hole) and 16mm camber bolts (top hole) and have achieved -2.75 front camber (aligned by Alex at Burning Rubber in Oakville).
Using a pyrometer, the tread surface shows very similar values all across during 8-10 lap sessions at TMP. This with Conti Extreme Contact Sport 245-45-17. Using Blox LCA's adjusted at -1.5 rear camber, similar even temps are found out back. After about 6-7 lapping events these tires, which wear incredibly slow, show dead even wear across their width. |
#22 | |
Did you ever run the car with just 2 sets of bolts and no top mounts? If so curious as to what amount of camber you were able to achieve? Also are you lowered at all? Sent from my SM-G950W using Tapatalk |
#23 | |
#24 | |
Tire size Wheel width Wheel offset I'll tell you what you can get away with |
#25 | |
I wouldn't bother tracking with less then -3 degrees of camber up front unless I really wanted to destroy a set of tires. Competitive autox setups are around -4 degrees camber up front. |
#26 |
Just a "lets butcher a base sedan Civic to make it cool" reference. Was not intended to be accurate nor truthful.
#27 |
Drives: 16 Silver BRZ, 04 Silver WRX wagon
OP, why not ask a vendor like RCE or CSG. They have a lot of experience with there own cars and sell suspension parts.
| Camber Bolt Options? | Maverick986 | Suspension | Chassis | Brakes -- Sponsored by 949 Racing | 4 | 04-05-2018 12:10 PM |
| Top mount/camber plate options for KW V3? | owenxguo | Suspension | Chassis | Brakes -- Sponsored by 949 Racing | 9 | 05-21-2014 11:28 PM |
| Bushing upgrades, geometry options and other component options? | der_rainman | Suspension | Chassis | Brakes -- Sponsored by 949 Racing | 10 | 06-26-2013 01:53 PM |
| Color options Camber Plates, Stress Bar, & Shock Mounts | GC_Adam | Suspension | Chassis | Brakes -- Sponsored by 949 Racing | 14 | 03-26-2013 02:08 PM |
| Rear camber adjustment options? | zooki | Suspension | Chassis | Brakes -- Sponsored by 949 Racing | 24 | 09-12-2012 11:46 AM |
