Old 06-16-2020, 11:16 PM   #15
Chuckable
Drives: 2017 Toyota 86
Performance Pack Brembo Rear Brakes
Thanks to @86league, we have some pad radial height data. I recalculated the numbers and now come up with:
OEM base: 69.3% front bias
OEM Brembo: 66.3% front bias
Stoptech/Brembo: 64.9% front bias
Stoptech/base: 69.3% front bias
To summarize, it appears that the Brembo rear calipers apply about 14% more torque to the rear rotors versus base calipers, and the net impact of the Brembo performance pack brakes is to shift brake bias rearward by 3%.
However, my numbers are different from 86league. Can anyone chime in to double check the math?
Chuckable is offline   Reply With Quote
Old 06-20-2020, 09:01 PM   #16
86league
Drives: '13 BRZ Limited
FYI - I rebuilt a set of stock front calipers today. Measured the pistons - looks like 40.4mm, not the 42.8 in the table posted previously.
Essex tells me their calculations show the stock system system at 65.5% front bias.
Parts catalog shows that the front/rear pistons are same part number, so should be the same diameter. Using 40.4mm front and 40.4mm rear with the radial depth info posted above I get 65.56%. Very close to Essex's number.
86league is offline   Reply With Quote
Old 06-20-2020, 10:15 PM   #17
Chuckable
Thank you, 86league. It’s good to have an actual measurement of the front caliper pistons.
Old 03-29-2021, 06:50 PM   #18
timurrrr
timurrrr's Avatar
Drives: 2022 GR86
Awesome data, thanks for sharing!
Quoted that post in the thread.
timurrrr is offline   Reply With Quote
Old 04-05-2021, 05:53 PM   #19
doug1234
doug1234's Avatar
Drives: 2017 BRZ w/pp
Trying to find a thread that listed pads and the model numbers that fit the brz pp. If you know of thread I'm talking please share the link.
Sent from my Pixel 2 XL using Tapatalk
doug1234 is offline   Reply With Quote
Old 06-13-2021, 05:09 AM   #20
Garvin29
Drives: Subaru BRZ limited 2015
@CSG Mike can the pp brembo be fitted to the 2013 -2016 models?
Garvin29 is offline   Reply With Quote
Old 06-13-2021, 05:25 AM   #21
churchx
churchx's Avatar
Drives: 2014 GT86
Garvin29: obviously it can be. But: 1) stock wheels won't clear, 2) while PP brembos is good deal when bought anew, when you source it from parts for retrofit, it's cost gets unreasonably high, higher then that of aftermarket offerings.
Old 06-13-2021, 02:11 PM   #22
^ What @churchx said.
Old 07-20-2023, 01:31 PM   #23
ojuniour
ojuniour's Avatar
Drives: Subaru BRZ 2017
sorry for reviving old thread.. So What's the verdict on mixing the stoptech with the rear brembo for daily/street driving?
ojuniour is offline   Reply With Quote
Old 07-20-2023, 02:55 PM   #24
ojuniour
ojuniour's Avatar
and also I realized no one brought up suspension suspension compared to OEM.
A stiffer setup would benefit with less front bias in comparison to OEM.
So based on this:
If you are running anything other than the OEM suspension which most like more stiffer than OEM, Won't the Stoptech/Brembo combo actually balance things out a bit?
2017 BRZ Performance Package Brembo Brakes Part Numbers Veloist Suspension | Chassis | Brakes -- Sponsored by 949 Racing 146 04-27-2023 09:36 AM
SOLD: Performance Package Brembo Brakes. NEED TO MOVE! Desain2137 Brakes, Suspension, Chassis 2 04-12-2020 01:11 AM
Performance pack brakes Jdmuscle Suspension | Chassis | Brakes -- Sponsored by 949 Racing 7 03-11-2019 05:05 PM
FS; Brembo Brakes Performance PCKG 900 miles brz/frs sokol Brakes, Suspension, Chassis 21 02-27-2019 01:15 AM
WTB brembo bbk (performance pack preferred) Mo Want-To-Buy Requests 2 12-28-2018 12:13 AM
