#15 |
Drives: 2023 Toyota GR 86 Cup
Sounds like you need to nut & bolt* everything either may have touched.
*nut & bolt = put a torque wrench on every bolt they would've removed and make sure it is tightened to the proper torque. The noise does't sound like anything internal (engine or transmission) sounds like something is loose. I'd be suspicious since the dealer already had to bend a mount for another noise. The pics of the TOB all look fine
2023 GR Cup Car
#16 | |
Drives: White FR-S
Sent from my H3223 using Tapatalk |
#17 | |
[insert cool phrase here]
Drives: BRZ Premium
![]() ![]() ![]() Same as any other TOB. Lube the shaft, slide her in, locker her place and enjoy the ride. Old man @humfrs knows. FYI new TOB has better grease, better seals, and better balls-bearings. I think... don't quote me that.
Weekend fun/track car - '91 MR2 Turbo Gen3 Old daily driver - '88 MR2 Supercharged |
#18 | |
ALWAYS BE SURE TO ORIENT THE NEW TOB SO AS THE WHITE DOT IS ON THE TOP NOTE: Iffen the clutch disk is worn down into the brass rivets, go to the junk yard and get a better one. Put it all back together. |
#19 |
Drives: White FR-S
Finally got under the car while it was parked at a slope and took these videos while the car was being pushed moderately. The noise was even louder when pressure was placed on the wheel and pushed on as opposed to the frame. Seems like a bad suspension component. I stood over the engine and the noise seems to be from over the struts as opposed to the transmission but damn its hard to tell. I cant even jack the front to get a better listen because if I raise it even little the noise goes away (the slope has to be pretty steep to get it to make noise). Not sure if this helps add insight but I wanted to update everyone. Next step is to install new coils and replace the transmission fluid. I need coils anyways. While im installing im going to inspect the LCA's and also redo this noise test this time with the wheel off. Thanks for everyones help. https://cloud.tapatalk.com/s/5eed8633..._233927378.mp4https://cloud.tapatalk.com/s/5eed864d..._234137799.mp4
#20 | |
#21 |
Drives: White FR-S
#22 |
Now, THAT is one weird sound for a car to make without the engine running.
Back in the day, I would have mixed up a mixture of 30w oil and kerosene (50/50 ratio) in a squirt can, have a buddy make the car squeak, crawl under the car and squirt away in the direction of the squeak. Today, I would do the same thing with a large spray can, with a flexible spout, of silicone and go squeak hunting. |
#23 |
Something, attached to the part being pushed on, is not tightened properly. Check the metal under engine tray, if not that, start checking suspension, front subframe and supports.
2023 GR Cup Car
#24 |
Drives: White FR-S
PROBLEM SOLVED
Quick Explanation - Time and bumpy roads solved the problem. Rarely hear the noise. Full details: So often I see a problem posted with no resolution or update on what happened so I wanted to write what is likely the final update. Upgrading to Coilovers did nothing but time did. The original noise (Sounded like Lifters hitting for those who didn't hear the original audio) stayed for 6+ long months. THEN one day on my way to the farm I hit a few massive potholes going slow, 5mph or less, and it started getting better. It would act up only after 20mins of driving. Then 30mins. Then an hour. After a year of rattling and those country roads it stopped making the noise. If its hot, I'm facing downward, and I hit the brakes maybe it will make the lifter noise but in flat Florida those moments are few and far between and will hopefully be gone in another year. I think many of you were spot on. It was a clearance/alignment/torque issue. Not inside the transmission although that's what the dealer and the transmission shop said. It's my theory that the reason it was not rattling when the engine was cold was because metal shrinks when cooled and expands when heated. This slight expansion after warming up was causing the rattling of the misaligned/torqued parts. After a year of rattling, driving on those bumpy country roads, Florida summer heat, and 50 degree winter the rubbing parts finally settled in and created their space. To this day the car still drives with no issues or check engine light. Hopefully someone somewhere learned something from this. Apart from the 2 bad TOB's this car has been so reliable. Thank God the car made it through this nightmare and thanks for everyone's help. |
| Recall service question - what other maintenance/repair work to do at same time? | fiveoneoh | Northern California | 9 | 07-14-2020 05:37 AM |
| Block replacement under warranty - what all needs to be replaced? | chipmunk | Engine, Exhaust, Transmission | 8 | 02-16-2019 09:29 PM |
| I just made the worst mistake | zizon93 | Scion FR-S / Toyota 86 GT86 General Forum | 86 | 08-05-2017 12:57 AM |
| Anyone had their shift knob replaced under warranty? | FRiSson | Issues | Warranty | Recalls / TSB | 16 | 11-04-2013 09:21 AM |
| Anyone have a windshield replaced under warranty? | NickFRS | Issues | Warranty | Recalls / TSB | 8 | 05-16-2013 10:19 AM |
