Old 05-24-2020, 04:55 PM   #15
ls1ac
ls1ac's Avatar
"it does make and sound when pressing button with the key"
Old 05-24-2020, 05:16 PM   #16
Yitzb
Yitzb's Avatar
Drives: Brz with wudebody. Hopefully boost
Yes it does
Yitzb is offline   Reply With Quote
Old 05-24-2020, 06:34 PM   #17
ls1ac
ls1ac's Avatar
yes it makes a noise
no it does not make a noise
I am confused.
Old 05-24-2020, 10:35 PM   #18
Dave-ROR
Site Moderator
Dave-ROR's Avatar
Drives: Stuff
So I think he's saying the lights flash and horn beeps but the doors don't actually lock?
OP, do the doors lock when you use the door lock/unlock button in the car?
If not just start tracing the circuit. Start with the fuses.
Or sell the car cheap to me haha
-Dave
DD: 2005 Acura TSX
Tow: 2022 F-450
The Following User Says Thank You to Dave-ROR For This Useful Post:
ToySub1946 (05-25-2020)
Old 05-25-2020, 04:12 AM   #19
JD001
JD001's Avatar
Drives: Subaru BRZ
Clearly not an open and shut case.. I don't understand why the OP doesn't go back to the dealer...
Old 05-25-2020, 10:51 AM   #20
Dave-ROR
Site Moderator
Dave-ROR's Avatar
Drives: Stuff
It's a salvage title/rebuilt title car. Dealerships will work on it but it won't be under any warranty.
I'm not sure if the car is even fixed yet, he may just be trying to fix this while rebuilding it.
-Dave
DD: 2005 Acura TSX
Tow: 2022 F-450
JD001 (05-25-2020)
Old 05-25-2020, 01:37 PM   #21
Yitzb
Yitzb's Avatar
I am confused.
It doesn’t make locking noises with key or from door.
It makes beeping noises when I use the key fob to lock but doesn’t lock
Old 05-25-2020, 01:38 PM   #22
Yitzb
Yitzb's Avatar
My car is salvage if I go to dealer won’t be under warranty
Old 05-25-2020, 01:38 PM   #23
Yitzb
Yitzb's Avatar
The body is fixed but not really drive able as of now. Hopefully soon tho
Old 05-25-2020, 01:59 PM   #24
JD001
JD001's Avatar
Drives: Subaru BRZ
What made it a "salvage"? How bad or good was it?
Old 05-25-2020, 02:21 PM   #25
Yitzb
Yitzb's Avatar
The front end was smashed and steering wheel and dashboard airbags were deployed. It was ok damage.
Old 05-25-2020, 02:32 PM   #26
Dave-ROR
Site Moderator
Dave-ROR's Avatar
Drives: Stuff
Trace. The. Circuit.
You'll find the cause that way.
-Dave
DD: 2005 Acura TSX
Tow: 2022 F-450
Old 05-25-2020, 02:33 PM   #27
JD001
JD001's Avatar
Drives: Subaru BRZ
Okay. Could it be an issue with the ECU? As the airbags were deployed perhaps they triggered something in the brains department ie unlocking the the doors.
Old 05-25-2020, 02:34 PM   #28
ls1ac
ls1ac's Avatar
The question was, is the noise from in the door?
Is the noise (if there is one) from both doors?
You have established that the fob communicates with the car.
You have not established that the hard wired switch in the door or the key switch will communicate.
Some where between the door and the computer or the computer to the door is a communication problem.
Broken wire, fuse, plug.
Adding doors auto-lock and oil t° display to your FRS / BRZ / 86 T0rt0r0 DIY (Do-It-Yourself) Guides 82 05-14-2019 01:46 AM
Doors won't lock. mynameis940 Issues | Warranty | Recalls / TSB 9 03-15-2018 03:05 PM
Trunk won't open and doors won't lock/unlock Mazikowski Electronics | Audio | NAV | Infotainment 13 03-05-2018 11:50 AM
Auto Lock (Doors) pinoyplaya BRZ First-Gen (2012+) — General Topics 67 11-13-2017 11:47 AM
Doors won't automatically lock adan Issues | Warranty | Recalls / TSB 18 03-01-2014 11:02 AM
