#15 | |
- Andrew |
#16 |
Drives: '23 BRZ
#17 | |
Drives: 2022 BRZ sport-tech
Thanks again. I am assuming the answer is no but I will ask anyways, did going to the B8 give you more wheel/suspension clearance? If i have to run camber plates to fit 17x9, for the price of shocks, camber plates and lowering springs, i might as well run Fortune Auto 500 with camber plates already or the B14. I will just swap back to the stock suspension for the winter time. Thanks.
Daijiro Katoh - Champion Forever!
Past: 92 EG w/JDM B18C, 00 EK w/JDM B18C, 04 600RR, 97 ITR #421, 10 Acura CSX-S, 17 BRZ Current: 22 BRZ, 00 S2K - #0220 |
#18 | |
Drives: '23 BRZ
The B8s definitely gave significantly more bump travel up front. I was pretty much resting on the bump stops at -30mm ride height with the PP Sachs struts and Raceseng camber plates (which take away some bump travel). Any small bump => BAM! It was pretty terrible on the street. I'd have to slow to a crawl and weave around to avoid bumps. With the B8s the car is transformed! Drive over bumps at normal speeds with no problems.
One reason I went with non-adjustable Bilsteins is that I'd rather have *good* nonadjustable dampers engineered to work well over a broad operational range, than lower-end adjustables. I didn't like the B14 progressive spring rates for track work: F 2.5-4.5, R 3.0-7.0, and ride-height adjustability costs me a point (42 lb.). FortuneAuto might be fine. I didn't consider them because ride-height adjustability (1 point, 42 lb.), and also Bilsteins seemed more of a known-good quantity. Quote:
#19 |
#20 |
Drives: '23 BRZ
| The Following User Says Thank You to ZDan For This Useful Post: | Racecomp Engineering (08-20-2020) |
#21 |
#22 | |
What I meant was wheel/suspension clearance (as in more room for camber bolts) with the B8 vs PP sachs. Yes, I did read up on the progressive rate of the B14. Seems like everything is a compromise. haha.... Agreed with the Fortune Auto name vs Bilstein but FA's package is hard to beat. $2k (cdn) all in for their 500 series (street/track) that is a monotube design, 5 year warranty, built stateside as is the rebuilt at $75 a corner. Each shock comes is dyno matched......seems like they are somewhat big in the drift scene. Could be all marketing but sounds not too shabby.
#23 | |||
Drives: '23 BRZ
Another thing to consider for me was that it's my daily driver and gets driven on snowy/salted roads, I get the impression that most aftermarket coilovers are not really designed to stand up to that. |
#24 |
Drives: '15 BRZ RA
If you want to adjust height between summer and winter seasons, then it'll be a pain to keep the threaded sleeves clean and functional. Same about corrosion, which most of the manufacturers saying that they have protection and in reality you have corrosion! I had a set of adjustable "quality" coilovers with limited mileage and I sold them after 2 years. I cannot imagine what would be their condition if they were installed in a highly mileage car ...
| (SOLD) Swift Spec R Springs & Raceseng Caster/camber plates | Brzzee | Brakes, Suspension, Chassis | 5 | 09-27-2018 08:46 AM |
| FS: MCS 1WNR Coilvers w/ Hypercoil Springs, Raceseng Camber Plates | skylinekin | Brakes, Suspension, Chassis | 2 | 09-14-2018 09:58 PM |
| FS: Custom Bilstein motorsports coilovers, Raceseng, Swift | zdr93523 | Brakes, Suspension, Chassis | 2 | 01-27-2017 12:16 AM |
| KW V3- 7k Swift Springs, Velox Camber Plates | byun | Brakes, Suspension, Chassis | 3 | 10-05-2016 01:20 AM |
| FS (NY): Bilstein B16 (PSS 10) + Raceseng camber plates + Raceseng B16 spring perch | dp1 | Brakes, Suspension, Chassis | 7 | 05-01-2016 10:28 PM |
