Old 08-20-2020, 11:08 AM   #15
Racecomp Engineering
Originally Posted by ZDan View Post
Oh yeah, the new setup worked great at Palmer Motorsports Park a couple of weekends ago
Definitely a lot less midcorner-understeery, and probably now more rear bumpstop-active vs. front so more oversteer but not a problem at all. I'm not planning to add back in any front bump-stop length, or to take away any from the back. If anything, I might get some rear subframe inserts to keep the rear end from squishing around which it feels like it is doing a bit in left/right transitions.
Rear subframe inserts are nice! What other bushings are you allowed?
- Andrew
Old 08-20-2020, 11:17 AM   #16
ZDan
ZDan's Avatar
Drives: '23 BRZ
- Andrew
Aftermarket poly or rubber bushings allowed, any metal => points...
Old 08-20-2020, 11:32 AM   #17
Petah78
Drives: 2022 BRZ sport-tech
I never tried camber bolts as I knew it was a no-go. Actually that had been my plan but friend and competitor told me to forget about it, get plates. He was right... Running -3.3/-3.4 with camber plates
Thanks again. I am assuming the answer is no but I will ask anyways, did going to the B8 give you more wheel/suspension clearance?
If i have to run camber plates to fit 17x9, for the price of shocks, camber plates and lowering springs, i might as well run Fortune Auto 500 with camber plates already or the B14. I will just swap back to the stock suspension for the winter time.
Thanks.
Daijiro Katoh - Champion Forever!
Past: 92 EG w/JDM B18C, 00 EK w/JDM B18C, 04 600RR, 97 ITR #421, 10 Acura CSX-S, 17 BRZ
Current: 22 BRZ, 00 S2K - #0220
Petah78 is offline   Reply With Quote
Old 08-20-2020, 12:01 PM   #18
ZDan
ZDan's Avatar
Drives: '23 BRZ
The B8s definitely gave significantly more bump travel up front. I was pretty much resting on the bump stops at -30mm ride height with the PP Sachs struts and Raceseng camber plates (which take away some bump travel). Any small bump => BAM! It was pretty terrible on the street. I'd have to slow to a crawl and weave around to avoid bumps. With the B8s the car is transformed! Drive over bumps at normal speeds with no problems.
One reason I went with non-adjustable Bilsteins is that I'd rather have *good* nonadjustable dampers engineered to work well over a broad operational range, than lower-end adjustables.
I didn't like the B14 progressive spring rates for track work: F 2.5-4.5, R 3.0-7.0, and ride-height adjustability costs me a point (42 lb.).
FortuneAuto might be fine. I didn't consider them because ride-height adjustability (1 point, 42 lb.), and also Bilsteins seemed more of a known-good quantity.
Thanks.
Old 08-20-2020, 12:06 PM   #19
Gotcha. Some opportunity there then IMO either with rubber or poly.
- Andrew
Old 08-20-2020, 12:14 PM   #20
ZDan
ZDan's Avatar
Drives: '23 BRZ
- Andrew
Plan is to take incremental approach. 1st stabilizing the rear subframe and seeing what that does, proceed from there.
Racecomp Engineering (08-20-2020)
Old 08-20-2020, 12:47 PM   #21
Makes sense. You've got a good set up going already.
- Andrew
Old 08-20-2020, 01:55 PM   #22
Petah78
What I meant was wheel/suspension clearance (as in more room for camber bolts) with the B8 vs PP sachs.
Yes, I did read up on the progressive rate of the B14. Seems like everything is a compromise. haha....
Agreed with the Fortune Auto name vs Bilstein but FA's package is hard to beat. $2k (cdn) all in for their 500 series (street/track) that is a monotube design, 5 year warranty, built stateside as is the rebuilt at $75 a corner. Each shock comes is dyno matched......seems like they are somewhat big in the drift scene. Could be all marketing but sounds not too shabby.
Old 08-20-2020, 02:03 PM   #23
ZDan
ZDan's Avatar
Drives: '23 BRZ
Ahhh, nah, not much if any difference as far as clearance for wheels/tires I'd bet, though I didn't specifically measure clearance before/after...
Indeed!
Yeah, they seem to have a decent rep and offer spring rate options.
Another thing to consider for me was that it's my daily driver and gets driven on snowy/salted roads, I get the impression that most aftermarket coilovers are not really designed to stand up to that.
Old 09-11-2020, 09:26 AM   #24
nikitopo
nikitopo's Avatar
Drives: '15 BRZ RA
If you want to adjust height between summer and winter seasons, then it'll be a pain to keep the threaded sleeves clean and functional. Same about corrosion, which most of the manufacturers saying that they have protection and in reality you have corrosion! I had a set of adjustable "quality" coilovers with limited mileage and I sold them after 2 years. I cannot imagine what would be their condition if they were installed in a highly mileage car ...
(SOLD) Swift Spec R Springs & Raceseng Caster/camber plates Brzzee Brakes, Suspension, Chassis 5 09-27-2018 08:46 AM
FS: MCS 1WNR Coilvers w/ Hypercoil Springs, Raceseng Camber Plates skylinekin Brakes, Suspension, Chassis 2 09-14-2018 09:58 PM
FS: Custom Bilstein motorsports coilovers, Raceseng, Swift zdr93523 Brakes, Suspension, Chassis 2 01-27-2017 12:16 AM
KW V3- 7k Swift Springs, Velox Camber Plates byun Brakes, Suspension, Chassis 3 10-05-2016 01:20 AM
FS (NY): Bilstein B16 (PSS 10) + Raceseng camber plates + Raceseng B16 spring perch dp1 Brakes, Suspension, Chassis 7 05-01-2016 10:28 PM
