#15 | ||||
https://www.tirerack.com/tires/tests...y.jsp?ttid=223 No question, ECS in completely standing water will be quicker simply because of void tread vs PS4S. PS4S is quicker (IMO) in basically all rain instances because the chances of a monsoon event are slim to none (where you have visible standing water). I've found for the most point all rain instances are either wet (not standing) or in a transition phase where it's wet going to dry. In these cases, PS4S will be significantly quicker than ECS (which is something none of these tire tests show because it's always just full bore wet). The transition phase from ECS to say RE-71R is basically once dry patches start forming you need to switch ASAP or you're already late. PS4S you can let it almost become fully dry before switching because the tire still performs well under semi-wet conditions (as long as it's kept cool and doesn't overheat). If that makes any sense. Quote:
PS4S in the wet is simply like cheat mode. I can only compare against others in the class in same conditions when they were running RE-71Rs or similar and it is seconds. I know the weight penalty is higher with A052s...but worth consideration
Kyle H. - #89 STX
| The Following 2 Users Say Thank You to M0nk3y For This Useful Post: | strat61caster (05-04-2020), ZDan (05-04-2020) |
#16 |
Remember that the Conti and MPS4S both will heat cycle, but the Conti physically can get hotter and thus, cycle itself faster and also showing higher friction (grip).
The MPS4S has a softer sidewall, which tends to help driver confidence with intermediate level drivers, but the sustained grip of the Conti is greater, given a comparison of fresh tires of both compounds. The MPS4S lasts significantly longer than the Conti, and rides quieter/softer. I used to compete in a class that mandated 220+TW tires, and have tried basically all the tires personally on my BRZ. Nankang NS2R Achilles 123S Michelin PS4S Continental ECS Federal 595 Some others that I don't remember as the results were poor. |
#17 | |||
Drives: '23 BRZ
#18 | |
As far as cycling goes, I'd say you'll get 4 competitive sessions out of them. Beyond that, it'll depend purely on how quick your competition is. First few sessions is fastest as usual. For the fresh comparisons, it would be sticker vs sticker. I've used a few sets of ECS, but TONS of MPS4S, as that's my default go-to true street tire. It's value for strictly street use is unbeatable, and I've worked for some companies that were Michelin partnered, and effectively had an unlimited supply of 4S/CUP2. Both of these tires run wide for a "normal" tire. |
#19 | |||
Drives: '23 BRZ
Depending how first event goes, I might get another set of tires for event 2. Which could be another set of ECS to save for TT, or MP4S, or Rival S. Last edited by ZDan; 05-05-2020 at 07:52 AM. |
#20 | |
Drives: BRZ 2017 Pure Red, MT
Have you tried the Yokos Neova AD08R? I got a brand new set SUPER cheap because of a store closure sale, and was wondering if they are going to be good for HPDE. Not looking to set records. |
#21 | |
That said, yes, I have. |
| The Following User Says Thank You to CSG Mike For This Useful Post: | nico_rsx (05-11-2020) |
#22 | |
Drives: 18 BRZ tS, 27 GRMN 86
Rain a lot in my area especially March to May and September to November. Just want to think of back-up plan on which "wet" tire to go for. Thanks! |
| Conti ExtremeContact Sport vs Hankook R-S4 | Guru Woodman | Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack | 14 | 06-05-2019 07:24 AM |
| Finally upgraded from stock tires to 225 MPS4S! | Kushkaki | Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack | 24 | 06-04-2018 05:24 PM |
| FS: 2 Continental ExtremeContact DW- Sold | bggns | Canada Classifieds | 2 | 05-03-2018 08:02 AM |
| Continental ExtremeContact DW vs Michelin Pilot Super Sport tread width 235/45/17 | tracerit | Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack | 2 | 11-22-2016 09:32 PM |
| Sold - Set of practically new Conti ExtremeContact DW 255/40R17 | Slick | Canada Classifieds | 1 | 06-25-2015 09:34 PM |
