#15 |
Drives: 2016 Subaru BRZ
Given that I don’t want to spend a lot of money on coils if I’m not tracking the car I might just go with RCE springs. Anyone year round drive the car and have any issues with snow?
#16 |
Drives: 2014 GT86
Big issue on deeper snow or on unplown road with deep groves to me was limited ground clearance of twins. So i wouldn't want even RCE ones winter-driving wise, that are of mild drop vs some other aftermarket spring offerings, but still slightly lower then stock.
#17 | |
Drives: MY14 86 GTS Manual Velocity Orange
I have said in other threads that i have the TRD lowering springs and the TRD sways. they probably cost a bit more than others but the kits come with all new fitting hardware including new shorter bumps stops - you don't re-use any bolts or nuts. the sway bar kit is the same, all new hardware including bushings and grease. instructions are included if you want to DIY. it's a well thought out kit and designed for the car. |
#18 | |
Wes
Instagram: @gt86ws
#19 | |
Drives: 2017 toyota 86
Read up the comparisons of RCE vs TRD if you like. But many people have driven in both and/or even swapped from one to the other. It was pretty unanimous that RCE was better overall vs TRD springs. That’s not to say TRD are horrible or worse then stock though. RCE springs aren’t going to be as good as a good coilover obviously, but they are an improvement over stock. And for 300$ it’s a great option for a street car. This car is already a phenomenal car for handling, everyone praises how great it handles and that its a true drivers car made for twisties but not straight lines. But then when talking about suspension act like stock is completely crap and doing anything but dropping 2k on coilovers will ruin your car. Cheap coils will ruin it sure. But a quality well designed lowering spring like RCE will be an improvement all around on a car that is already great. Slightly lower, slightly stiffer, you feel more planted, more responsive, and less body roll. You will want rear lower control arms, don’t need to go fancy, spc lca work just fine. And spc camber bolts for front. Install and get alignment asap. |
#20 | |
Drives: FR-S Whiteout
Do you still have the Meisters on the car?
Intent > Content
cowardice is the mother of cruelty. |
#21 |
OP if you REALLY wanna save money. Get a used set of springs and chop a half to one coil off. Or do it to your existing one. One coil off the OE spring should still have some decent preload on it with slight lowering effect without compromising the coilover assembly.
Old skool style. With a "K."
Intent > Content
#22 |
Drives: '23 BRZ
You probably won't need aftermarket rear control arms. Especially if you go with something like TRD or even RCE yellows which only lower ~3/4".
The Swift BRZ Sport springs on my car brought it down 1.25", and rear camber went up to about -2.5 degrees. Which is fine for me as I track the car. And anyway, that much camber isn't terrible for tire wear as long as toe is kept reasonably near zero. |
#23 | |
#24 | |
Drives: 2013 DGM BRZ, 2020 C8 Corvette
This was my experience - when I first lowered the car with Swift springs, the rear camber was noticeably uneven from one side to another. It's the way a lot of the twins come from the factory and you can't adjust it without LCAs. I installed LCAs and got a proper alignment done.
My DGM BRZ vid: https://www.youtube.com/watch?v=0OL9OhxexAA
My car journal thread: http://www.ft86club.com/forums/showthread.php?t=43402 |
| The Following User Says Thank You to shiumai For This Useful Post: | 86TOYO2k17 (04-18-2020) |
#25 | |||
Drives: '23 BRZ
Lowering springs shouldn't really add any more to asymmetry though... Quote:
For sure aftermarket LCAs aren't strictly necessary... Curious, how far off was your left/rear camber? At 1.25" lower, I was at -2.4L/-2.6R (or maybe the other way around...). For my usage, just about perfect, so done! I probably still wouldn't have bothered with LCAs even if L/R camber were different by as much as half a degree though. Quote:
Anyway, even for cars that have some built-in asymmetry (to a point), the *need* for LCAs is IMO overstated and in any case not a function of whether or not lowering springs are used. |
#26 |
When the Swift springs were installed without LCAs, left rear camber was -2.13° and right was -1.65°.
#27 |
@ZDan after RCE install.
Before alignment -1.44 FL, -1.16 FR -1.32 RL, -1.96 RR After alignment -1.8 front -1.6 rear Exact same both sides. To be fair i have no idea my true before because I installed springs, camber bolts, and LCA before going in. Last edited by 86TOYO2k17; 04-18-2020 at 05:08 PM. |
#28 | |
But A proper alignment, especially if your alignment is way out of wack from factory. Will be as beneficial if not more beneficial to your handling, response, driver feel etc... compared to lowering springs or even coilovers, and so spending less than 250$ for LCA and camber bolts in order to achieve an optimal alignment seems like a no brainer to do at the same time as spending 300$ on lowering springs when the benefits will be greater for less, and its very easy to install everything at same time, get one alignment and be done. |
| Lowering a PP BRZ: Springs vs Coilovers | TofuTogue | Suspension | Chassis | Brakes -- Sponsored by 949 Racing | 17 | 08-17-2018 02:07 PM |
| Can't get lowering springs, so what coilovers? | jnmxcvi | Suspension | Chassis | Brakes -- Sponsored by 949 Racing | 15 | 03-17-2017 02:31 AM |
| WTB: Lowering springs or used coilovers | Rsmith954 | Want-To-Buy Requests | 4 | 03-12-2017 07:55 PM |
| Lowering Springs v Coilovers and Exhausts | thehapaone | Northwest | 6 | 07-14-2013 03:23 PM |
| Coilovers or lowering springs | Hawk77FT | AUSTRALIA | 9 | 07-30-2012 10:41 PM |
