#15 | |
Drives: 2018 Premium Black silica BRZ
So I was gonna replace the slave cylinder But if that might not be a problem should I bleed the clutch ? Sent from my iPhone using Tapatalk |
#16 |
Also there is some gunk/residue on the slave cylinder
#17 |
not playing cards
Meh. Slave cylinder is cheap. Of course it will need bled if you open the system but it's really easy.
#18 | |
Hey so I changed my slave cylinder and bled my clutch and replaced it. everything is good. The only thing is when I press in the clutch and rev up my rpms there’s STILL a clunk sound from the front half of the car. Does anyone know what this could be Sent from my iPhone using Tapatalk |
#19 |
not playing cards
No idea. Post a recording of the sound to youtube. Try to capture a decent example.
#20 |
Drives: 15 Impreza
It's grease from the slave cylinder piston and clutch fork. Clean the area and if it doesn't come back its grease. If it comes back your slave cylinder is leaking. I'd also recommenced re-greasing this pivot point with a higher temperature grease.
| The Following User Says Thank You to cueball89 For This Useful Post: | pher.da.rico (02-08-2020) |
#21 |
Drives: 2016 FRS
Pro tip: don't Google image search the thread title.
| The Following User Says Thank You to BigHugeFatGuy For This Useful Post: | SuperTom (02-12-2020) |
| Bad tranny | Retrorv | Issues | Warranty | Recalls / TSB | 16 | 10-16-2018 07:50 PM |
| Looking for 86 A/T Tranny | Soloside | Want-To-Buy Requests | 0 | 03-10-2017 10:45 AM |
| STI JDM tranny mount vs Perrin tranny support NVH | khrono | Engine, Exhaust, Transmission | 2 | 03-15-2016 09:43 PM |
| Tranny to Driveshaft Oil Leak | BDotG | Engine, Exhaust, Transmission | 3 | 09-07-2015 12:05 PM |
| Tranny fluid or engine oil leak? | G.I.Choe | Issues | Warranty | Recalls / TSB | 1 | 05-28-2014 07:53 AM |
