Old 12-11-2019, 01:35 PM   #15
TommyW
TommyW's Avatar
Drives: '13 Whiteout
Originally Posted by bmxr View Post
I am driving to account for a barely perceptible understeer, but it's not really a problem. I just want the car a little looser. If a sway bar would do that, it seems like a very easy fix. I think I am going to go with more front grip rather than less rear grip.
Thanks again everyone!
Sounds good. Yes always work on the end of the car you're having trouble with. You can also play with tire pressures.
The Following User Says Thank You to TommyW For This Useful Post:
bmxr (12-12-2019)
Old 12-12-2019, 03:31 AM   #16
jflogerzi
jflogerzi's Avatar
Good info in this thread. Thanks for sharing
2013 Series 10 FRS #553
The Following User Says Thank You to jflogerzi For This Useful Post:
bmxr (12-12-2019)
Old 12-12-2019, 10:35 AM   #17
Petah78
Drives: 2022 BRZ sport-tech
17x9 et42 Apex wheels running 245s. Firestone and Hankook both rub very slightly.
What are you rubbing on? Fender/quarters? Or inner lip against the struct?
Thanks.
Daijiro Katoh - Champion Forever!
Past: 92 EG w/JDM B18C, 00 EK w/JDM B18C, 04 600RR, 97 ITR #421, 10 Acura CSX-S, 17 BRZ
Current: 22 BRZ, 00 S2K - #0220
Petah78 is offline   Reply With Quote
Old 12-12-2019, 10:51 PM   #18
bmxr
bmxr's Avatar
Drives: 2017 BRZ PP WR Blue
Thanks.
I trimmed the spring perch slightly but there are tire marks on the spring itself. No marks on the tire, so it’s very slight. No problem with fenders or anything else. It’s just that I’m using eccentric caster bolts at their max adjustment.
bmxr is offline   Reply With Quote
CSG Suspension - Daily | Street | Track | Race Proven Setups! CounterSpace Garage Brakes, Suspension, Chassis 9 10-23-2019 12:51 PM
My 2015 daily BRZ and track weapon :) zbrz Tracking / Autocross / HPDE / Drifting 28 01-21-2018 11:35 PM
Track/daily drive car suggestion ayau Tracking / Autocross / HPDE / Drifting 24 01-31-2013 10:41 AM
