Old 11-29-2019, 05:06 AM   #15
Captain Snooze
Because compromise ®
Captain Snooze's Avatar
Drives: Red Herring
Originally Posted by solidsnake11 View Post
Plus have a witch doctor do a ritual on it.
Old 11-29-2019, 07:06 AM   #16
Captain Snooze
Drives: Red Herring
I have also read a lot of info on it, my conclusion its as good as voodoo.
I totally disagree. It is no where close to being as good as this:
[ame]https://www.youtube.com/watch?v=YV78vobCyIo[/ame]
I know, you didn't actually mention people. *shrug* I'm calling artistic license. It's the first thing I think of when I read/hear voodoo.
And yes, this is a thread hijack. I'm bored.
Old 11-29-2019, 04:30 PM   #17
gtengr
Drives: 2017 BRZ
Oem part broke replaced with cryo treated part it broke. This was a high cycle fatigue failure.
Because an accepted steel treatment technology did not completely solve the problem in your application, it's reasonable to conclude that said treatment offers no benefit at all.
gtengr is offline   Reply With Quote
Old 11-29-2019, 04:57 PM   #18
DarkPira7e
Rust bucket enthusiast
DarkPira7e's Avatar
What value is there in treatment if your first hand experience is that it doesn't help? I don't blame him for being sour.
Old 11-29-2019, 05:26 PM   #19
Lonewolf
Lonewolf's Avatar
Drives: Moped
OP - Here is something that may interest you:
https://www.verus-engineering.com/si...-with-Clip-Kit
Old 11-29-2019, 08:11 PM   #20
gtengr
Drives: 2017 BRZ
One data point = case closed and reason to refer to it literally as voodoo? Given the factory trans rating, cryo treatment could increase durability by 15-20% and the trans would still be overstressed by high boost superchargers with header, most turbo kits, e85, etc. It's already been discussed that it's a waste of money to rebuild an AZ6 with factory gears for higher torque applications, but if someone insists, why not throw everything at it?
Well if you did 4 burnouts and it broke then you decided you wanted just 1 more burnout before it breaks then cryo is the answer.
What if it's the difference in a few hundred more burnouts for the car making 25 ft-lbs less than yours?
Old 11-29-2019, 09:32 PM   #21
Odds are if its going to break without cryo its going to break with it. Just my opinion.
My transmission was chipped at the snap ring without abuse, only roll ons and granny shifts.
We tried cryo on the chucks and drives on our vertical lathes that make rotors.
We found that:
It only works on very specific materials. Any material lower than tool level steel just became brittle and tended to shatter.
On the materials where it would work it rapidly increased the wear on the untreated parts that contacted, held or spun the treated ones. If you can't do every part that contacts it you are just moving wear issues down the line to something else.
On the lower speed parts it was impossible to determine if it was reducing wear at all. Any changes in wear over a period of time were so small that we could not even measure them. The really high speed parts did have a minimal measurable decrease in wear but as I said the parts attached to them had a corresponding increase so it was a wash.
Places that can do it right are rare. There are places that claim to be able to do it but metallurgic analysis of their "treated" parts showed virtually no change over standard.
It is bloody expensive to have it done properly! We calculated that we could buy almost two (1.8 if I remember right) new standard parts for every one treated one. That is not a good return on investment.
All in all it is not something I would have done on a cheap Japanese car tranny no matter how much power I was putting through it.
Old 11-29-2019, 09:44 PM   #22
DarkPira7e
DarkPira7e's Avatar
Everyone is entitled to an opinion, right? I'm not saying he's accurate, I'm saying he has experience and is sharing his insight
Old 11-29-2019, 10:14 PM   #23
This is mostly what I found when I was researching it a few years ago.
Thank you.
To be clear there were places which did it that showed substantial changes after the treatment.
But...
Unless it was the right base materials those changes were not always good!
There certainly is value in it for very specific applications but it is not a fix all that can just be applied and work well for everything. Took us over two years of trials and analysis to determine that it was a waste of money for our needs. It did however work out really well for the equipment in our caliper plant though.
Old 11-29-2019, 10:26 PM   #24
Milhouse86
Noob
Milhouse86's Avatar
Drives: 13' FRS, 13' F150, 17' A4, 69' 442
So what's the best option today? Did I read we can swap in a 350z trans? How's that running? Gonna start searching but if anyone can help point me that would be great!
Sent from my Pixel 2 XL using Tapatalk
-2013 FRS/Black (Motor Blown/Under Construction)
http://www.ft86club.com/forums/showthread.php?t=135599
-1979 Trans AM/Black (Sold) -1969 Olds 442/Orange with white racing stripes - 2017 Audi A4/Black
Milhouse86 is offline   Reply With Quote
Old 11-30-2019, 11:49 AM   #25
Nitemare15
Drives: 2015 Scion FR-S
Guys, I seriously appreciate all of the information and help. I'm not looking to go to insane boost levels. I don't even want to go above 250whp. It looks like the HKS kit that I've been looking at pushes right at 250whp on 91 or 268whp on 93. Assuming I don't want to drop $5,000 on the CD009 listed above (and I do understand that with ANY amount of boost there is the chance of failure) is it safe to say that I'll have minimal issues with a rebuilt AZ6? Or is there really no way to tell? When I rebuild the transmission, I plan on also going to a more sturdy clutch, verus clutch fork and TOB, shift springs and a short throw shifter (already purchased the shifter actually). If the serious suggestion and only reliable option is a transmission swap, I may have to put all of this on hold for a bit longer. $5000 is almost double what I've budgeted at this point for a transmission..
Nitemare15 is offline   Reply With Quote
Old 11-30-2019, 12:21 PM   #26
Sleepless
Drives: 2016 FR-S
I’ve beat the hell out (mostly road course driving) of stock trans and clutch for 3 years with JRSC with zero issues. Edlebrock does need a clutch upgrade.
Sleepless is offline   Reply With Quote
Old 11-30-2019, 12:31 PM   #27
86TOYO2k17
Drives: 2017 toyota 86
@Nitemare15
Stock manual transmission is rated at 250nm or 185ft lbs torque. Gears start shearing around 240ft lbs torque. (Individual experiences and driving conditions may differ)
Centrifugal superchargers don't make much torque more about top end whp. Probably the easiest on engine/drivetrain out of any FI options.
185ft lbs at crank at 7000rpm is 246hp. So stock clutch may start slipping a little at 240whp+
Old 11-30-2019, 12:46 PM   #28
Nitemare15
Whoa! Okay that makes me feel a hell of a lot better. I'll most likely go with the rebuilt AZ6 route then from Jack's. I've read reviews and apparently they do a stellar job and seem to resolve any issues that the AZ6 had from the factory. Like I said previously, I'll most likely upgrade the clutch while I've got the transmission pulled. I haven't done much looking for SCs but I've heard good things about HKS.
Upgrading exhaust Kkobe2 Scion FR-S / Toyota 86 GT86 General Forum 5 04-10-2015 02:25 AM
Upgrading Fog Lights to LED bobka7914 BRZ First-Gen (2012+) — General Topics 6 11-03-2014 11:35 AM
Upgrading frs frz06 Scion FR-S / Toyota 86 GT86 General Forum 12 06-01-2014 05:10 PM
Toyota is Replacing My Transmission orangeblue Issues | Warranty | Recalls / TSB 40 07-03-2013 06:10 PM
What are you upgrading from? Rusty86 AUSTRALIA 78 09-22-2012 06:56 AM
