#15 | |
not playing cards
https://datazap.me/u/ultramaroon/log...?log=0&data=38
#16 | |
Drives: Edelbrock SC 2015 FR-S 6MT
#17 |
Datalog: https://datazap.me/u/rb28dett/nov-17-cruise
Short cruise after everything had warmed up. Very little throttle throughout, with one instance up to 4k RPM with light throttle as well. |
#18 |
Drives: 2013 FR-S Series 10
The edelbrock tune is not for catless headers.
2013 FR-S 10 Series ~75k (SOLD)
RCE SS-1 Coilovers Corsa Catback Edelbrock Supercharger installed @ 50k |
#19 | |
not playing cards
| The Following User Says Thank You to Ultramaroon For This Useful Post: | localhost (11-17-2019) |
#20 |
Drives: 14 BSP Edelbrock BRZ
An engine is basically an air pump. Your air pump can now flow about 20% more air because the outlet is less clogged. You can't run the tune designed for 20% less air.
It is difficult to drive because the throttle tables in the Edelbrock tune are left like they are in stock form - a small pedal input results in a large change in throttlebody opening. In stock form this is done so the car doesn't feel like a slug. When you have forced induction available this makes it very tough to keep the engine in vacuum. Swap the headers or get a real tune ASAP. |
| The Following 3 Users Say Thank You to toast For This Useful Post: |
#21 |
Headers change the VE. The calculation for load uses VE in the divisor, so for a given measured airflow the ECU will undervalue the engine load and will not add the appropriate amount of fuel until the AFR shows lean and then it will attempt to correct it up to the maximum fuel trim allowed.
I've never seen fuel trims over 27%, I didn't know they could go as high as his log is reporting. I guess that is also determined in the tune. |
#22 | |
Drives: BRZ Turbo
Just FYI there's another hidden bolt on the left of that backet quite far down that goes straight into the block, that one in particular is the grounding bolt, so check that one too. |
#23 | |
Reading through these comments I'm fairly certain my catless header with a tune that isn't expecting one is the root cause of these issues. I'm going to swap back to the OEM ones this weekend and see if it gets better. |
#24 | |
#25 |
not playing cards
It's not the problem. Just make sure the screws are tight.
#26 |
not playing cards
Yeah. I didn't mean to sound dismissive. It's just that it's an Occam's razor thing. Don't get too caught up in the least likely stuff.
| The Following User Says Thank You to Ultramaroon For This Useful Post: | solidsnake11 (11-21-2019) |
#27 |
I haven't fixed it yet. I'm planning on swapping back to the OEM headers on Saturday when I have some time and seeing if it fixes it.
That said, I had to drive the car to work today and I noticed something very interesting. Under very light throttle and low rpm, the LTFT is sky high as I've shown in the previous log (over 35% sometimes). I've been driving it like this for the past few days to avoid damaging something but today I had to give it some gas and get it to the higher RPM to make a merge and I noticed that at around 4500rpm and beyond, both LTFT and STFT would drop to 0 and stay there as long as I was on the accelerator. I suspect 4500rpm is where the system transitions from PI to DI and there's a noticeable hiccup/blip/lack of acceleration for a split second before the car starts accelerating again and LTFT and STFT both drop to 0. Essentially, below 4500rpm LTFT is very high and the engine is probably using PI. Past 4500rpm it uses DI and fuel trims are perfect (so is AFR). There is also a small noticeable transition between these two modes noticed as a momentary lack in acceleration. I didn't have my OFT plugged in to log, but I did have the torque app for monitoring and I was able to get some data logs with that. The resolution is low but it shows exactly what I mean: https://datazap.me/u/rb28dett/nov-21...a=3-5&mark=153 . Every time you see LTFT drop down to 0 was when the engine had crossed past 4500RPM. I've linked it to an area where I could be above 4500rpm for a (very) short period of time due to traffic. Question is whether this behavior is because of the wrong header for the tune or if there is something going on with my injectors/fuelling. Last edited by localhost; 11-21-2019 at 09:48 PM. |
#28 |
| CELs and not cranking | 86 driver | Issues | Warranty | Recalls / TSB | 8 | 09-28-2017 01:08 PM |
| Odd CELS. | Karl07 | Issues | Warranty | Recalls / TSB | 4 | 10-08-2016 07:53 PM |
| Unichip stock map to avoid CELs | pwells | Software Tuning | 3 | 12-28-2013 02:57 AM |
| Engine Mods and CELs | Captain Snooze | Engine, Exhaust, Transmission | 2 | 04-08-2013 10:13 PM |
| Cam Gear Related CELs - How many miles? | uspspro | Issues | Warranty | Recalls / TSB | 16 | 10-22-2012 02:57 PM |
