Old 11-06-2019, 05:47 AM   #15
JD001
JD001's Avatar
Drives: Subaru BRZ
Emission checks in the UK are pretty stringent. I have a aftermarket UEL (no cat) and fast flow cat in the aftermarket front pipe. I have been running this for 4 odd years, over the past 3 years the car has been tested annually for emissions... no issues.
Old 11-06-2019, 02:59 PM   #16
wparsons
wparsons's Avatar
Originally Posted by Wil View Post
Don't worry, I know the exhaust like my pocket, ahah!
I mean, would adding a 100/200-cell cat after the second cat do the trick?
I don't care if the care smells when it warms up. As long as, when it's warm, the smell is gone, then mission accomplished.
But would I benefit from the added performance of a catless header? Just by "moving" the first cat down the line and swapping it for a sportier one?
Supercharging... I would love that! But hey, this is Belgium...
Change your rims and you won't pass inspection. That's half true though.
I'm confused... are you still getting the catless smell with the stock secondary cat in place? You really shouldn't be.
flickr
Old 11-06-2019, 04:08 PM   #17
Irace86.2.0
Irace86.2.0's Avatar
Drives: Q5 + BRZ + M796
^^^This.
OP, maybe there would be smell on startup, but the precat is there to heat the main cat. It doesn’t do much more than that. In fact, it is mainly there for startup when the main cat is cold, and potentially at low speeds or idling situations in cold weather.
https://www.roadandtrack.com/new-car...ent-explained/
The precat isn’t even needed for good emissions once the car is warm. It begs the question why wouldn’t an electrical heater like a block warmer be a better solution than even the Koenisegg’s solution.
Old 11-11-2019, 04:29 AM   #18
Wil
Wil's Avatar
Drives: Drives like a crab.
Would a cerakoted header partially solve the issue?
Wil is offline   Reply With Quote
Old 11-11-2019, 09:17 AM   #19
Vital
Drives: 2015 BRZ
Cerakoting the header has nothing to do with Cats...those are two separate things.
Vital is offline   Reply With Quote
Old 11-21-2019, 08:42 AM   #20
Timmy_Jones
Spun
Drives: 23' Supra
Whats the EU punishment for being caught tampering with the cat and exhaust? Honestly doesnt sound worth tampering with the exhaust at all.
Timmy_Jones is offline   Reply With Quote
Old 11-21-2019, 01:07 PM   #21
mrg666
pessimistic skeptic
mrg666's Avatar
^^^This.
My understanding is that our main cat is the one on the header. that is why the oxygen sensors are attached to it. The second cat is there to help with emissions rating but it is not a requirement for running the engine.
Old 11-21-2019, 01:23 PM   #22
mav1178
mav1178's Avatar
Drives: 2005 Toyota Camry
The problem is catalytic converters need a minimum temperature to function.
Without testing your theory with thermal probes and datalogging the results, it's impossible for any of us to armchair and say "yes it will work".. you can wrap headers all you want but you're the only one with this idea so far.
FS: P&L catted & coated EL header, Perrin catted front pipe and res 2.5" catback Turbowned Engine, Exhaust, Bolt-Ons 13 08-11-2019 11:54 PM
catted header or catted front pipe? gabeg86 Engine, Exhaust, Transmission 28 10-13-2015 12:32 PM
Catted header or catted front pipe? wilfredwong Engine, Exhaust, Transmission 5 02-09-2015 06:11 PM
Group Buy: TSUDO Performance Hi-Flow catted Test Pipe/Front Pipe/ Downpipe JonMotoring Groupbuys 65 08-27-2013 12:33 PM
P&L Catted headers and Nameless catted Front pipe. Also is this cricket noise? Xdragonxb0i Engine, Exhaust, Transmission 23 04-24-2013 12:29 PM
