Old 10-31-2019, 01:42 PM   #15
TunaNoCrust
TunaNoCrust's Avatar
Drives: 86, 981S, RX8, 2500HD, GenesisV8
Camber bolts, fresh brake fluid, torque wrench, tire pressure gauge, seat time, lots and lots of seat time!
I ran Hawk HP+ F&R they are great entry level with a low initial bite, descent modularity, and good beginner operating temp range. I never even bothered with the TRD pads on track.
Skip the ducts at least for now, these cars aren't particularly hard on brakes.
TunaNoCrust is offline   Reply With Quote
Old 10-31-2019, 03:45 PM   #16
ZDan
ZDan's Avatar
Drives: '23 BRZ
Originally Posted by RotARy15 View Post
That is what I expect. I found a series of roads where I could run the car at about 7/10 for a couple minutes non-stop and the factory oil temp gauge measured 235ish. That seemed to suggest a 15 minute session is too much.
Doesn't suggest that to me... 90F track days, mine goes up to just over 270F and holds there. If it had ever shown signs of continuing to get hotter uncontrolled, I would consider an oil cooler. As it is, I'm not.
The risks of not running an oil cooler IMO tend to be overstated, especially for "casual" HPDE usage. 275F is not a problem for good 30 weight synthetic oil for 15-20 minutes at a time.
Also consider that the risk of adding and running an oil cooler is not zero. Leaks are fairly common, occasionally leading to loss of engine and even loss of car (fire).
You have to assess what is the actual risk you are mitigating, vs. the actual risk you may be adding.
Plenty of us are tracking these cars without a cooler...
Old 10-31-2019, 04:25 PM   #17
RotARy15
Drives: 1993 Mazda RX-7 R1, 2025 BRZ tS
I recognize that. This was in 50F weather so I am concerned but not panicked. My plan was to start tracking in winter so any thermal issues have the best chance of being spotted early.
RotARy15 is offline   Reply With Quote
The Following User Says Thank You to RotARy15 For This Useful Post:
ZDan (10-31-2019)
Old 10-31-2019, 04:51 PM   #18
ZDan
ZDan's Avatar
Drives: '23 BRZ
Gotcha. FWIW mine *always* goes to just over 270F and holds there, whether in 90F temps or the coldest temp I've tracked in, probably ~45F. So I think it's somehow either internally thermostatically controlled, *or* the temp reading displayed on the gauge is programmed to go to the same spot and hold until temps start to really get hot, to prevent people from freaking out.
Old 10-31-2019, 05:08 PM   #19
RotARy15
Aww yes, the old "People don't know what this means so we will hide the truth from them. Even though the only chance for them to learn is to tell them the truth...."
Like my NB's oil pressure gauge. "What is my pressure?" "Yes"
The Following 2 Users Say Thank You to RotARy15 For This Useful Post:
Icecreamtruk (11-01-2019), TunaNoCrust (11-01-2019)
Old 10-31-2019, 05:14 PM   #20
Grady
Grady's Avatar
The truth????? You Cant Handle The Truth!!!!!!!!!!!!
The Following User Says Thank You to Grady For This Useful Post:
weederr33 (11-01-2019)
Old 10-31-2019, 05:48 PM   #21
ZDan
ZDan's Avatar
Drives: '23 BRZ
[ame]https://www.youtube.com/watch?v=ueLFRHQSnhk[/ame]
Old 10-31-2019, 06:02 PM   #22
Grady
Grady's Avatar
I am a little older.
[ame]https://www.youtube.com/watch?v=PWSx0bBiNIs[/ame]
Old 10-31-2019, 07:36 PM   #23
Racecomp Engineering
Zero HPDE's. 1 autocross on an actual track (that just seemed goofy). 5-6 time trials at Mineral Wells (think high speed autocross). And 2 full years of local group autocross. My on-board video records suggests 27 autocross events.
My plans for next year are about 1.75 track events a month. Avoiding mid-summer. I'm pretty much burned out on autocross. It's not worth the money to seat-time ratio.
Cool.
I would choose a tire that is not the RE71R in the 200 treadwear category.
In response to your other post:
You don't necessarily need 9 inch wheels and 245s to track your car. A season on the OEM 7.5 inch wheels, 225 tires, and OEM suspension will teach you a lot. You'll really want some camber though, which we can help you with.
G Loc R12 and Cobalt Friction XR2 are great options for you. I have not used the CSG pads but hear good things. Same pad front and rear in most cases.
Seat time, good pads and fluid, and a good alignment will get you really far.
- Andrew
Old 10-31-2019, 08:00 PM   #24
RotARy15
Originally Posted by Racecomp Engineering View Post
Cool.
- Andrew
How would you describe the main differences between R8, R10, and R12 compounds? What are the release characteristics as they relate to each other? And is there any point in the hierarchy where noise gets insane? I will end up being lazy and just leaving the pads on for the street. I can handle noise but if people start looking for out of control trains while I'm around, it's going to get old.
Old 10-31-2019, 08:31 PM   #25
i8ur911
Drives: 17 BRZ Series.Yellow
Any decent pad for the track is going to make noise.
One of the pros of the PP cars is the quickness of changing pads with the Brembo's. I can do all 4 calipers in less than an hour....and that's taking my time.
With that being said, it's in your best interest to swap pads. Not only is the noise annoying, but you don't want to wear out expensive pads by street driving them. You also don't want to ruin rotors with using "cold" track pads on the track.
That's my $0.02.
Sent from my Pixel 3 using Tapatalk
i8ur911 is offline   Reply With Quote
The Following User Says Thank You to i8ur911 For This Useful Post:
Racecomp Engineering (11-01-2019)
Old 11-01-2019, 10:26 AM   #26
ZDan
ZDan's Avatar
Drives: '23 BRZ
I doubt it!
Knowledge of the "A Few Good Men" scene is assumed, required as context for full appreciation of The Simpsons scene
Old 11-01-2019, 10:38 AM   #27
ZDan
ZDan's Avatar
Drives: '23 BRZ
Not nearly to the same degree though! WinMax W5 are in a totally different league vs. most track pads, SUPER loud. Meanwhile PFC 11s are practically street-pad quiet, I streeted on them through the entire track season.
A lot of us find it super-convenient to run streetable track pads. I've been doing it for years and will continue to do so, as there are a decent selection of not-too-loud, not-too-dusty, and decent-cold-bite track pads out there like the PFC 11, Carbotech XP8 and XP10 and others.
Old 11-01-2019, 11:16 AM   #28
i8ur911
I'll have to try these PFC11's at some point then.
Every other track pad I've run makes noise and I've never been a fan of the "street/track" pads. There's always a compromise with those as they can't be great at both disciplines.
WTB: Performance Pack Wheels Chuckable Want-To-Buy Requests 0 07-27-2019 12:18 PM
WTB: Performance Pack Wheels Chuckable Want-To-Buy Requests 0 07-27-2019 12:16 PM
Performance pack brakes Jdmuscle Suspension | Chassis | Brakes -- Sponsored by 949 Racing 7 03-11-2019 05:05 PM
to performance pack or not Victorscp Suspension | Chassis | Brakes -- Sponsored by 949 Racing 13 10-19-2018 03:53 AM
GT-86 optional performance-pack Ziptuning Scion FR-S / Toyota 86 GT86 General Forum 24 08-29-2012 03:00 AM
