#15 | |
Drives: manual Toyota 86
I watched plenty of YouTube vids like this one before i made my decision. [ame="https://www.youtube.com/watch?v=2MuBD10WzBI"]https://www.youtube.com/watch?v=2MuBD10WzBI[/ame] I used ULTRA QUIET Resonator 2.25in inlet / outlet x 14in overall length. Not a lot of room down there actually so you're not going to be able to fit anything larger, my exhaust guy had to lower the piping slightly to fit it between the catback and front pipe. Its not to low that it catches speed bumps or anything like that, but it might depending if you slam your car, He charged me $100 took him 20 minutes, i watched it he did a good job. If somebody charges you more then $150 they are probably overcharging. But if you're going with an aftermarket cat back or keeping it stock with a header I would recommend getting this resonator, its pricy $200 but its worth the price imo. Last edited by evoto86; 10-22-2019 at 04:53 AM. |
#16 | |
Drives: Toyota 86 GTS Manual 2015
#17 |
Drives: 2016 Scion FRS Release Series 2#439
I recently installed a Gruppe-S (catless) header and a JDL Ultra Quiet (catted and resonated) combination front pipe/overpipe.
The balance of the exhaust is OEM. I like the sound. It's a mature performance sound. Nice grumble at start-up. Good tone when driving but only slightly louder than stock. Also paired with an OFT stage II tune the power is noticeably stronger in the low and mid ranges where my commuting is done. Will experience top end power come Sunday when lapping (TMP, weather permitting). |
#18 | |
Weight Weenie
Drives: 15 FR-S
Looking forward to your thoughts after TMP. Good luck! |
#19 | |
Drives: 2014 Subaru Forester
Are you still using the OEM midpipe and axleback? |
#20 |
Drives: 2013 FR-s
I’m running a cat less UEL with stock pipes. The sound is OK to me, cold start is a little louder/different than stock. I could live with it-but I picked up a straight front pipe and a vibrant resonator, just to see if I can get a bit more grumble out of it.
#21 |
Drives: 2020 Subaru BRZ
2020 BRZ. I added a EL catless header, over pipe and catless and resonated front pipe. Added a drop in K&N filter. The rest of the exhaust is stock. The normal driving is perfect. The hard driving has a great sound. I took it for a tune but the tuner couldnt get the new stuff to tune it cause the car is so new (according to him). But while on the dyno, it made 176 hp. About 10 more than the bone stock cars. With a good tune it should increase about 15 or so.
#22 |
I am planing to do the exactly what your asking. Will be getting rid of UEL and catback setup and will be moving to a JDL 4-2-1 EL with all stock exhaust except I plan to add a vibrant ultra quiet resonator into the stock front pipe removing the dinky stock one. I hope the combo will allow the car to be quiet while cruising but a nice tone/sound when I get on it.
2013 Series 10 FRS #553
| SRT full header back exhaust + header? | KenTK808 | Engine, Exhaust, Transmission | 21 | 11-29-2017 05:07 PM |
| JDL UEL header/Nameless header-back exhaust (Atlanta area) | carbon_raven | Engine, Exhaust, Bolt-Ons | 16 | 05-09-2015 02:26 AM |
| Who has Open Flash Header (or aftermarket UEL header) in the GTA with stock exhaust? | alanhung85 | CANADA | 6 | 10-21-2014 10:41 PM |
| Exhaust mods on stock exhaust | FRSoxfan | Engine, Exhaust, Transmission | 9 | 01-12-2014 08:04 PM |
| What mods next? Exhaust? Intake? | Ludacrits | Scion FR-S / Toyota 86 GT86 General Forum | 7 | 09-05-2013 08:25 PM |
