Old 10-14-2019, 10:39 PM   #15
86TOYO2k17
Drives: 2017 toyota 86
I thought they were just going to "inspect automatic transmission fluid".
humfrz
Possibly. I believe owners manual says to do one drain/flush every 30k miles. Trans holds 7 quarts, each drain/fill replaces 2 quarts.
The Following User Says Thank You to 86TOYO2k17 For This Useful Post:
humfrz (10-14-2019)
Old 10-14-2019, 10:44 PM   #16
Grey86
Grey86's Avatar
Drives: Tornato grey 86
You gotta remember that they all gotta have their smoke breaks and lunch and so forth that there is like 2 hours XD
but seriously when i took my car in for the 1000km inspection it took them 3 hours to do a hours worth of work (inspecting brake pads, see if the tires are holding air, the air filter is clean, nuts and blots are tighten, see if oil is at appropriate level) its a joke tbh
I almost dont want to book my car in for its first actual oil change lol it'll take them 4 hours (small town no where to go)
Grey86 is offline   Reply With Quote
Old 10-14-2019, 11:01 PM   #17
Brink
Drives: 2017 BRZ
Also gotta add an hour for them to bring the keys back up to the desk after the car is done.
Brink is offline   Reply With Quote
The Following User Says Thank You to Brink For This Useful Post:
humfrz (10-14-2019)
Old 10-14-2019, 11:44 PM   #18
humfrz
Well, the maintenance manual for my 2013 FR-S says to inspect the AT fluid at 30,000 miles or 30 months and replace at 60,000 miles or 60 months.
Other cars may differ -
Hold on - my car is a MT - why are you trying to confuse me? -
humfrz
Old 10-15-2019, 12:34 AM   #19
86MLR
86MLR's Avatar
This is why they are called Stealerships.
http://www.ft86club.com/forums/showthread.php?t=133311
I'm only here for the biscuits
Old 10-16-2019, 06:45 AM   #20
Hoahao
Drives: 2014 Monogram Hot Lava
I'd ask how much they want to change out the automatic trans fluid and consider doing that. I had mine done at 59,000 miles for about 280 bucks. They used a machine; your dealership probably use a machine too.
Had them do the rear diff fluid too; don't remember the price for that though. My gas mileage improved a bit. In retrospect, I should have done both earlier due to break in material possibly floating around. Definitely do it before the 60,000 mile mark so the power train is still under warranty if they mess up.
It's all about gearing and steering.
Hoahao is offline   Reply With Quote
Old 11-14-2019, 07:25 PM   #21
mrhayes1
Drives: 2013 Scion FRS white
Here are some time estimates; I am being generous too. A good mechanic could probably do much faster.
Details:
Perform tire rotation & inspection- 1/2 hour
Replace air cleaner element - 10 minutes
Inspect cooling system - 10 minutes
Replace brake fluid / clutch fluid (MT model only) - 1 hour
Inspect fuel lines and connections - 10 minutes
Inspect V-belt - 5 minutes
Inspect automatic transmission fluid - 10 minutes
Replace engine oil and oil filter - 1/2 hour
mrhayes1 is offline   Reply With Quote
Old 11-14-2019, 09:31 PM   #22
Sapphireho
Famous Potatoes
Sapphireho's Avatar
Drives: '15 ultramarine
I speak dealer. Let me translate..
30,000 Mile or 30 Month Maintenance
Details:
Perform tire rotation & inspection - rotate tires
Replace air cleaner element - Replace air filter
Inspect cooling system - do nothing
Replace brake fluid / clutch fluid (MT model only) - bleed brakes
Inspect fuel lines and connections - do nothing
Inspect V-belt - do nothing
Inspect automatic transmission fluid - check fluid level
Replace engine oil and oil filter - oil change.
They want the car so they can throw it at a tech between real jobs.
Old 11-15-2019, 03:43 PM   #23
ActionMaxon
Professional Auto Fixer
ActionMaxon's Avatar
Drives: 2016 Oceanic FR-S as Designed
At my shop, Rotate is .5, air filter .3, brake fluid flush 1.0, oil change .5, so that's 2.3. We wouldn't charge for general look over type stuff.
Inspect cooling system- verify fluid level and check freeze protection (this is done for every customer as a courtesy at my place,)
Inspect fuel lines- visual inspection of connections, particularly checking at fuel injectors for leaks. At 30K you probably wouldn't see this but also checking for cracks in hoses, and condition of gas cap seal(looking for cracks that could lead to evap codes).
Inspect belt, check for cracks, use gauge to determine wear if appears worn but no cracks. Verify tension.
Inspect trans fluid- verify level, smell it to check for burnt smell, check for leaks.
Customers expect technicians to catch things before they become a problem, and it is their responsibility to do so. Customer doesn't have to approve anything they don't want to, but it needs to be looked at for general maintenance and safety needs.
Edit: I looked up Mitchell book time for official 30K service book time and it lists 2.4 hours.
Work Hard. Play Hard.
2016 Oceanic
ActionMaxon is offline   Reply With Quote
The Following User Says Thank You to ActionMaxon For This Useful Post:
soundman98 (11-16-2019)
Old 11-16-2019, 12:40 PM   #24
soundman98
ProCrastinationConsultant
soundman98's Avatar
Originally Posted by Brink View Post
Just scheduled my 30 month service at my local dealership and they emailed back this morning to tell me this is a 6-7 hour service (they were following up since I had selected to wait at dealership during the service). What's going on in this service to make it take so long? I've done all my previous service at the same dealership and its never been more than 3 hours. This is for an AT. Here's what the dealership lists for the service:
Details:
Inspect V-belt
everything in bold is something you could do yourself with a socket wrench, a jack, 2 jack stands, and a few paper towels to wipe your hands when you're done.
anything not bold is messy. it can be done yourself for those inclined, but i understand taking it somewhere.
v-belt inspection is really easy, you just shine a light on it to look for cracks and odd wear patterns/ fraying. around my area, there's a free widget-tool to help check for this at every auto parts store near the registers.
come to think of it, other than the tire rotation, all the inspection items could also be done for free at an auto parts store, as they want to sell you the parts if it's time to replace.
i use the 2nd graph down to determine replacement schedules:
http://www.cars101.com/subaru/maintenance-2014.html
FR-S takes 3rd at Targa Newfoundland DarkSunrise Scion FR-S / Toyota 86 GT86 General Forum 1 06-11-2015 12:02 PM
Takes a certain person Joeycokeboy Scion FR-S / Toyota 86 GT86 General Forum 61 04-12-2015 07:43 PM
What it takes to update the Wheel Directory DarrenDriven Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 39 03-17-2014 07:57 PM
12 month and 3 month Xbox live continuecrushing Miscellaneous 3 04-29-2013 12:50 AM
Edmunds Takes Delivery of their FR-S Gaiakai Scion FR-S / Toyota 86 GT86 General Forum 2 06-14-2012 11:31 AM
