Old 10-03-2019, 12:30 PM   #15
RToyo86
RToyo86's Avatar
Drives: 17 Asphalt 86
Originally Posted by ZDan View Post
At 24.4", 235/40-17 isn't closer to stock height of 24.7" than 225/45-17 (25.0").
235/40-17 isn't a good a fit on a 7.5" wheel, need 8" minimum up to 9.5".
225/45-17 is a MUCH better size choice for 7.5" wheels.
235/40r17 = 24.4 (-0.8%)
215/45r17 = 24.6
245/40R17 = 24.7 (+0.4%)
225/45r17 = 25 (+1.6%)
235/40 is closer than a 225/45 in height.
I agree 235 isn't Ideal for an 7.5", it's at the max end of the spectrum.
Old 10-03-2019, 02:44 PM   #16
ZDan
ZDan's Avatar
Drives: '23 BRZ
215/45r17 = 24.6
235/40-17 is too wide for a 7.5" wheel, minimum recommended width is 8", max is 9.5", measuring rim width is 8.5".
I just looked at eight of the most popular max and extreme performance tires in 215/45-17, and six of them were 24.7" in diameter, one was 24.6", and one outlier was 24.4" (Hankook RS4). Also OEM Primacy HP is 24.7" in 215/45-17, so stock diameter is 24.7".
225/45-17 is a very good fit on 17x7.5 and very close to stock diameter. 235/40-17 is not recommended on 17x7.5 and is as as much shorter than stock diameter as 225/45-17 is taller. Which is not enough to be concerned about anyway...
Old 10-03-2019, 02:51 PM   #17
Racecomp Engineering
225/45/17 works really well on this platform with a 7.5 or 8 inch wheel. There is also a wide selection of tires to choose from.
- Andrew
The Following User Says Thank You to Racecomp Engineering For This Useful Post:
wparsons (10-25-2019)
Old 10-03-2019, 09:41 PM   #18
qqzj
Drives: MDX, Camry
- Andrew
Any tire you can recommend? Is there a relatively lighter one?
Sent from my Pixel 3 XL using Tapatalk
qqzj is offline   Reply With Quote
Old 10-04-2019, 08:17 AM   #19
TunaNoCrust
TunaNoCrust's Avatar
Drives: 86, 981S, RX8, 2500HD, GenesisV8
Really need to know your end goals. What are your most important criteria?
Tread Life, traction, noise, etc and will it be tracked, driven in snow, temperature range?
A lighter tire?
TunaNoCrust is offline   Reply With Quote
The Following User Says Thank You to TunaNoCrust For This Useful Post:
Old 10-04-2019, 09:39 AM   #20
Daily driver? Looking for an all-season or a summer tire?
- Andrew
Old 10-04-2019, 12:50 PM   #21
venturaII
Only users lose drugs.
venturaII's Avatar
Drives: All the time
Nah. Let me explain a bit more. 215 is the width of the tire. The place where the tire is 'widest'. For most of the tires I have seen before, the 'widest' place is in the middle of the side wall, with the width of the tread larger than wheel width.
For the OEM tire, I feel that the 'widest' place is just where tire meets the wheel, with the width of the tread smaller than wheel width.
So the key is the definition of '215'. Tires with the same 215 width can have different tread width for sure.
To add to the murkiness, that number is calculated when the tire is mounted on an 'optimally' sized wheel...so, the measured section width and tread width will change, depending on how wide the wheel is. Ever wonder how TireRack comes up with the range of acceptable wheel widths for tires, and then the one they use for their published numbers?
As far as what actual tire to recommend, given that you're in California, I'm assuming you could get away with a dedicated summer tire; certainly a high performance all season one. I think Continental make excellent tires that perform 95% as well as the benchmark Michelins, but for far less money. Additionally, Contis always seem to be the lightest in their category, at least in the extreme summer and winter categories I've used in the past... Some complain about them having a softer sidewall than others might, but I don't feel it's to the overall detriment of the tire; response might be incrementally lower, but unless you've got urethane bushings everywhere already, I think that's chasing handling perfection in an already compromised system.
"To know a thing well, know it's limits. Only when pushed beyond its tolerances will true nature be seen." Amtal Rule
venturaII is offline   Reply With Quote
The Following User Says Thank You to venturaII For This Useful Post:
qqzj (10-04-2019)
Old 10-04-2019, 01:44 PM   #22
TunaNoCrust
I entirely agree, great performance to price ratio with Continentals, especially since their Hoosier acquisition I feel.
Old 10-07-2019, 12:26 PM   #23
qqzj
Drives: MDX, Camry
Continental has many tires with suitable sizes. Anyone you can recommend? Dws06? Control contact? Thanks
Old 10-07-2019, 12:42 PM   #24
strat61caster
strat61caster's Avatar
Do you go up to Tahoe with the car or just stay in the Bay?
If no snow have fun and get the Extreme Contact Sports, very highly rated tire, will do great year round here.
ineedyourdiddly
Old 10-07-2019, 01:09 PM   #25
qqzj
Drives: MDX, Camry
Thanks. No ski trip with BRZ. I have MDX for that.
Old 10-25-2019, 02:11 PM   #26
ROFL it's Waffle
The guy w/o an FRS or BRZ
ROFL it's Waffle's Avatar
Drives: '23 GR86 Premium 6MT Halo White
I kind of feel like this has something to do with sidewall rigidity, like what you'd see with all season tires (tire might be flush with rim) vs summer performance tires (tire may extend beyond the rim).
Do the OEM tires come with all-seasons, or is it more performance oriented? I've always wondered if the "Prius tires" was just the same dimension, or the actual rubber that ships on the Prius too.
ROFL it's Waffle is offline   Reply With Quote
Old 10-25-2019, 02:21 PM   #27
JD001
JD001's Avatar
Drives: Subaru BRZ
FFS.... Meaty tire thread in disguise... makes my head hurt.. BTW, I still haven't got round to switching my OEM tyres!! Coming up to 5.5yrs.. circa12.5k miles.
Old 10-25-2019, 03:01 PM   #28
conehead
Drives: RS 2.0
Originally Posted by Mr.ac View Post
Ah you been smoking the good stuff eh?
Let go over real quick tire size.
215/45/17.
First number is tire width. Bigger the number, wider the tire. And vice versa
Second number is side wall hight. Bigger the number taller the side wall. And vice versa.
Last number is rim/wheel size. Self explanatory.
As for your complaint, what you want is a wider tire. A 225/45/17 would be the fix for you. If you want more meat a 235/40/17.
Stretching tires is really a retarded move. Some would say it helps with tire flex, but really they are just retarded. If you wanted performance you'll just get better tires.
As for the idea of design, gas saving, performance, nah it's just the tire companies making a deal with the car company. Some retards would disagree saying the oem tires are a god send. Lol nope.
Posts like this drive me nuts. If you are going to be condescending and sarcastic, at least know what you are talking about.
The OP is absolutely right. Tread width and section width are different, and the section width is just a rounded off number on a sample size wheel anyway. Tires with the same advertised section width can have a range of tread width, and efficiency tires like the primacy tend to have narrower treads and hard rubber to reduce rolling resistance and increase MPGs slightly (which OEMs like for certification and advertising). Performance tires are the generally opposite.
Stretching tires onto wider wheels is common in race classes that limit tire section width. It maximizes contact patch and minimizes tire rollover. Race classes that limit wheel width tend to do the opposite and stuff the widest tire they can on the wheel.
conehead is offline   Reply With Quote
The Following 2 Users Say Thank You to conehead For This Useful Post:
churchx (10-25-2019), Shizuka (10-25-2019)
Winter tires question cocoy_labuyo Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 2 10-13-2017 10:36 AM
17x9 235/45 vs 235/40 tires QUESTION karma003 Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 1 07-21-2013 04:13 PM
Tires question Biggdogg Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 1 06-10-2013 09:45 AM
question about tires flameSniper Southern California 2 06-26-2012 01:49 AM
question on tires ! FR Off-Topic Lounge [WARNING: NO POLITICS] 1 05-02-2012 02:00 PM
