Old 09-25-2019, 05:28 PM   #15
Irace86.2.0
Irace86.2.0's Avatar
Drives: Q5 + BRZ + M796
Originally Posted by MaverickMonk View Post
The turbo bolts directly to the head due to the headifold design, so that should add minimal weight, maybe 20lbs. Adaptive suspension isn’t necessary or part of an engine swap so I don’t see why that matters (although a Tein kit is like 5lbs). BBKs are lighter than stock, and aluminum chassis stiffening is a matter of tens of pounds, not hundreds. Even being conservative you’re looking at 400-500lbs lighter of car, assuming you don’t strip weight elsewhere (battery, seats, etc).
You’re not getting something for free, you’re building a purpose built racecar or “racecar” or hotrod or drift missile or whatever you want to call it, instead of a pseudo-luxury sportscoupe. The “cost” is in that you’ll have a loud, rarely, harsh racecar instead of a car you can drive to work every day.
On some B58s it has a manifold. The engine has an intake manifold with an integrated water to air intercooler and an intercooler up front. It has a turbo system with more actuators and sensors than the FA20. It has a larger radiator. The transmission is larger. It has two extra cylinders. I can’t imagine saving 80lbs of weight with this swap.
The point about the adaptive suspension, active diff, stiffer chassis, etc is that the Supra has better components which is why it is heavier and is why it has more value. Again, by the time someone completes the swap, they may end up wishing their Supra clone was just an actual Supra, especially after spending Supra money and having less quality parts.
Like I said below, I agree with you that a racecar is the most logical application for this setup. Also, it could be cheaper trying to make the 86 more powerful with this swap than trying to make the Supra lighter. It would be hard to remove sound deadening; it would be hard to remove and sell the adaptive suspension system in order to install static compression; it would be hard to remove thickness from the subframe or suspension components to match that of the 86; it would be harder to remove quality from the interior without a full strip; it would take more effort to swap to a smaller brake setup to match the 86. I agree that this swap is most logical/cost-reasonable as a racecar likely using a used, higher mileage 86 along with a basic ECU package just to get the car running.
The big thing is Pure Automotive isn’t likely going to do a Motec setup for canbus integration or anyone else, so this would only be for a racecar situation because I doubt it would be a good daily without full integration.
Old 09-25-2019, 06:16 PM   #16
Irace86.2.0
Originally Posted by Kodename47 View Post
Because I like my eyes. I have also paid off the 86 a long time ago and don't want to drop £50k on a car that I hate the look of..... I'd rather buy an A110 but I'm told by SWMBO that I need more than 2 seats [sigh].
M140/240 comes in manual here. Probably not as good as the OEM in terms of feel but it's OK and obviously designed for the torque. Probably similar in length on those platforms too. Would need a little research.
Yea, if you are disgusted with the looks of the Supra and enamored that much with the 86 then the swap makes sense. Selling your car and putting that money plus the $20-25k in swap cash towards a different used car could get something better or worse, depending on your tastes. Subjectivity does play a hand in these decisions.
On the manual transmission, like I said earlier, that is one of the best advantages here. The engine and transmission could be bought as one assembly. With the 2JZ, the CD009 and adapter kit is another large expense. With the Pure Auto K24 swap, there is a need to source a S2000 tranny and an adapter kit. Usually an engine and transmission joined together are cheaper and less headache.
Old 09-26-2019, 12:35 AM   #17
GrabTheWheel
Drives: 16' BRZ
2JZ are not cheap here in the UK, certainly not as cheap as the B58, which comes as a surprise. The fact the B58 makes good power and is modern so should be quite a decent engine to run. Certainly is decent fun in the M240 so a lighter more able chassis seems an obvious choice. I quite like the i6 idea and bar the 2JZ and also expensive RB25/26 the options are limited.
UZ is one that I've been tempted by but we don't get many V8 Toyotas/Lexus here so again, not that cheap and need work to make similar power. LS just isn't an option here, we don't get any of the models that use them so you either have to get one imported or from an imported car, so guess what, they aren't cheap.
Sorry, didn't realize you from the UK until after my post.The swap starts to make more sense on that side of the pond. I say go for it!
GrabTheWheel is offline   Reply With Quote
Old 09-26-2019, 02:44 AM   #18
Originally Posted by GrabTheWheel View Post
First thought is why? I’m just trying to figure out what benefit there would be over a 2J, LS or UZ engine? If it’s just to be the first person to do it then sure I guess it would be cool.
600whp with bolt-ons and a tune on race gas.
The Following 4 Users Say Thank You to CSG Mike For This Useful Post:
DriftinFRS (12-23-2019), DustinS (09-26-2019), strat61caster (09-26-2019), wparsons (11-20-2019)
Old 09-26-2019, 03:45 PM   #19
strat61caster
strat61caster's Avatar
Shit, 400whp with a tune and exhaust on pump fuel is plenty for this car and cake for a B58 to make.
And if you can cross your i's and dot your t's you can even keep it street legal in California.
ineedyourdiddly
yelsew (09-26-2019)
Old 09-26-2019, 05:27 PM   #20
Kodename47
Kodename47's Avatar
Drives: UK GT86
After a quick search I can't find much info on ECUs but I don't think that the M150 can run the DIs that the B58 uses. I suspect that the N55 uses similar injectors and seems that the M142 is used, but then I'm not sure you can get the factory accessory compatibility that you get with the M150.
.: Stealth 86 :.
Kodename 47 DJ:
Old 09-26-2019, 07:22 PM   #21
Rumor has it CSG is already working on something CA legal!
The Following 3 Users Say Thank You to CSG Mike For This Useful Post:
GrabTheWheel (09-26-2019), strat61caster (09-26-2019), wparsons (11-20-2019)
Old 09-26-2019, 08:21 PM   #22
GrabTheWheel
Drives: 16' BRZ
With what trans?
Old 09-26-2019, 11:12 PM   #23
With what trans?
ZF Auto 8speed (that the Supra comes with)
Old 09-26-2019, 11:17 PM   #24
sato
sato's Avatar
Drives: Dodge Patitas
Old 09-27-2019, 12:41 AM   #25
Irace86.2.0
Why no xDrive while you're at it? Go all out.
Old 11-20-2019, 12:47 PM   #26
strat61caster
bump
ineedyourdiddly
Old 11-20-2019, 04:12 PM   #27
Irace86.2.0
bump
I was almost like when I saw sparks.
Old 11-20-2019, 04:12 PM   #28
wparsons
wparsons's Avatar
Because swaps are often about bettering one’s position. Some could buy a Supra or LS300/IS300/GS300 if they want a 2JZ easier, but then they have an old car or an overpriced Supra If someone wants an LS then they have to buy a boat of a Camaro or drop some coin on a Corvette. As a racecar, this swap makes sense, but not as a full canbus daily; by the end of the swap, someone would likely drop Supra money into a car with less quality, less stiffness with weaker and cheaper components, etc. That just seems silly, but if someone wants to burn cash on a project then more power to them.
An LS swap with full can integration will cost more than just buying a C5 Z06...
The FA20 also has twice as many heads and cams. These boxers are VERY heavy for all aluminum 4 cylinders.
According to published weights I can find, the FA20 engine and transmission is 480lbs. The B58 is 306lbs and the ZF 8HP is 192lbs (498lbs combined). Not lighter than the FA20 driveline, but also a completely negligible weight gain for the performance difference.
flickr
