Old 09-19-2019, 09:39 PM   #15
NoHaveMSG
NoHaveMSG's Avatar
Drives: Crapcan
Originally Posted by new2subaru View Post
What is the tape supposed to accomplish? I’ve seen a video of a guy balancing a driveshaft with hoseclamps.
It appears that the shaft has been balanced. There’s a few weights glued on it. FWIW, I think the one piece shaft delivers all kinds of vibrations from the rear. It makes sense not having the carrier bushing.
I did notice when I switched track tires that it lessened. It’s still there but not as profound. That or I’m getting used to it lol
Something about dampening a certain frequency range. I don't exactly remember.
Old 09-19-2019, 09:52 PM   #16
new2subaru
Weight Weenie
Drives: 15 FR-S
Interesting. Vibrations are a waste of energy and destroy shit.
Old 09-19-2019, 10:15 PM   #17
Goingnowherefast
Drives: AP2 S2000, 91 Miata 1.8L Rotrex 5MT
Damping*
Dampening is when you're getting something wet
2022 Hyundai Elantra N 6MT SCCA TT S3//Will be back in an 86 eventually
Goingnowherefast is offline   Reply With Quote
The Following User Says Thank You to Goingnowherefast For This Useful Post:
whataboutbob (12-24-2019)
Old 09-20-2019, 07:01 AM   #18
why?
Only happy when it rains.
why?'s Avatar
Drives: series.blue
Originally Posted by prandelia View Post
Yeah, that is interesting, and comforting at the same time. It is also worth noting that I have SPL solid subframe bushings, and we "raised" the subframe about 0.5" toward the body (to allow for better axle angles after lowering the car), and this also slightly affects the drive angles. Nothing extreme, but it seems it may be more related simply to the AL construction than anything else, given others also note the same vibration.
The easy way to find out is to slap my OE drive shaft back in, and if it goes away, then we have our answer. Perhaps CF driveshaft would be better.
I bought my AL one locally for only $200 so couldn't resist it, so it's not a huge deal if I move away from it. It definitely felt like more of a "whole car" vibration, and while I've felt engine harmonics that bad, I can see how it might be the AL driveshaft as well.
Anybody with CF driveshafts notice anything similar?
I've seen lots of people on here with AL shafts that complain. Not as many with CF. I have a carbon one from driveshaft shops and I have a tiny increase in whine, but no added vibrations. I've had it in for about 20,000 miles so far. Note at this point my car is mostly stripped.
Old 09-20-2019, 08:39 AM   #19
Dzmitry
Dzmitry's Avatar
Drives: 2018 Subaru BRZ Limited with PP
So if it is the driveshaft, then it certainly sounds like an imbalance. I don't know where you can take it to get it balanced, but that would certainly solve your problem if it IS in fact the driveshaft and you would like to hold on to it.
Some interesting instructions to finding if you have an imbalanced driveshaft I found here. I would be far too lazy to do this though I guess in your situation it's basically impossible anyway, as you only experience it at higher RPM's.
http://www.demandaam.com/technical-s...haft-balancing
Dzmitry is offline   Reply With Quote
Old 09-20-2019, 10:45 AM   #20
CrowsFeast
CrowsFeast's Avatar
Drives: 2013 BRZ Sport-Tech
Since it's always around 5500 RPM in any gear, wouldn't it make sense for it to be something on the engine side of the transmission rather than the driveshaft?
CrowsFeast is offline   Reply With Quote
Old 09-20-2019, 11:23 AM   #21
NoHaveMSG
NoHaveMSG's Avatar
Drives: Crapcan
Originally Posted by Goingnowherefast View Post
Damping*
Brain fart
Can't speak for the OP but mine does it in other areas too, it is the worst at 5500. Similar to the OP mine is worse in upper gears.
I have read in other threads that balancing didn't help.
The Following User Says Thank You to NoHaveMSG For This Useful Post:
Goingnowherefast (09-20-2019)
Old 09-20-2019, 12:38 PM   #22
ka-t_240
How did you adjust the subframe?
ka-t_240 is offline   Reply With Quote
Old 09-22-2019, 10:31 AM   #23
prandelia
Drives: 2015 FRS
SPL's kit has shims, so you can install at OE height, or raise/lower it depending on what you want to do. Super easy to adjust.
'15 FRS - GLTC spec
YouTube channel race vids: https://www.youtube.com/channel/UClU...phsppnA/videos
prandelia is offline   Reply With Quote
Old 09-24-2019, 06:56 PM   #24
prandelia
Drives: 2015 FRS
How many out there with CF driveshafts have vibrations ?
'15 FRS - GLTC spec
Old 09-24-2019, 08:41 PM   #25
new2subaru
Weight Weenie
Drives: 15 FR-S
1
I’m not done tweaking it yet. I want to check the pinion angles. My rear is dropped slightly with bushing inserts and diff inserts. I don’t know if that threw it off.
The Following User Says Thank You to new2subaru For This Useful Post:
why? (09-25-2019)
Old 09-25-2019, 10:00 AM   #26
prandelia
Drives: 2015 FRS
1
Which one do you have? PST, DSS, or Verus ?
I'm beginning to think if you have stiffer motor, trans, and diff mounts, typical of a race car, then virtually any 1 piece drive-shaft will vibrate badly. Maybe I'm wrong.
'15 FRS - GLTC spec
The Following User Says Thank You to prandelia For This Useful Post:
Dzmitry (09-25-2019)
Old 09-25-2019, 10:20 AM   #27
StraightOuttaCanadaEh
Wes
How bad are these vibrations? I have vibrations and/or resonance from either one, or a combination of, subframe and diff bushings, shifter bushing and trans insert and I really don't mind them. It makes the car sound raw and visceral. So how would a carbon driveshaft worsen the vibrations? Any insight on this? I wonder if anyone's done it in the same order
Instagram: @gt86ws
Old 09-25-2019, 11:52 AM   #28
Dzmitry
Dzmitry's Avatar
What you said there is probably very true. As the motor and trans have natural vibrations, having mounts on them sends it to the rest of the chassis and parts. In this case, your driveshaft would certainly gain some substantial vibration, and not due to an imbalance (which makes more sense, not sure why I didn't think of that before).
Hood Vibration Question shinbatsu BRZ First-Gen (2012+) — General Topics 10 07-02-2023 07:06 AM
ATI Harmonic Dampner JJD28 Engine, Exhaust, Transmission 19 07-03-2017 05:14 AM
Question weird vibration/camber dillanp86 Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 10 05-12-2017 11:43 PM
Harmonic Noise from rear Differential at 69 MPH solved Avion Engine, Exhaust, Transmission 0 01-28-2016 08:51 PM
New owner! Question about warranty and brake pedal vibration BBYZILA Scion FR-S / Toyota 86 GT86 General Forum 2 12-10-2014 12:22 PM
