#15 |
Drives: Subaru BRZ
#16 |
Drives: 1993 Caterham HPC Evo
#17 |
#18 |
OK so were is the caliper?
#19 |
Where is it? I had to lift it up. After I removed the wheel. After I jacked the car.
That is the entire basis of my whining and bitching and ranting! |
#20 | |
Drives: 2014 Monogram Hot Lava
It's all about gearing and steering.
#21 |
How would that be visible with any other car with calipers? What cars did you own where that was open and visible?
#22 |
The Dictater
Drives: '13 Red Scion FRS
Well, the really annoying thing about this car is that I have to stick the key in it every time I want to drive it. You look in every other car in the parking lot and there is a button to start it! Some you don't even have to start!
#23 | |
You will clearly see the brake pads Last edited by GrantedTaken; 09-08-2019 at 10:03 PM. |
#24 |
Airborne at your service
Drives: '17 BRZ Series.Yellow
Jesus OP, how hard is life for you?
#25 |
ProCrastinationConsultant
what other cars have you owned?
#26 | |
Lonely or bored maybe?
![]() Quote:
I can't see the pads on any of the cars in my garage right now. At best, I can potentially look at the bottom of the calipers on my wife's Yaris and deduce the pad thickness by the gap next to the rotor. I might be able to see the FR-S's if I had my thinner-spoked, slightly larger track wheels on, but I doubt it. That being said once the wheels are off, the "window" in the caliper is fine for a quick check when I rotate tires (I'm not sure why you can't see it). If it gets to the point that I can't tell from the window, then it's getting close but here's the thing - the brakes on these (and most modern, small) cars last a crazy long time. I still have the original pads on my '13 with 50k miles, and that includes an average of six AutoX a year since new (I do swap out for track pads on track days). My wife's Yaris has 100k+ miles on the original pads, and there's still a ton of life left in them! I bought a new set just b/c I figured it was probably time, and the original pads are still well over half the thickness of the new ones! That being said, as others have mentioned it's very easy to loosen the bottom bolt and remove the top to swing the caliper out if you want to double-check. If you check them when you rotate your tires at an oil change, they will not go bad in the time between one oil change and the next. |
#27 | |
Well, I don't know bout that - ![]() Back in the day, to inspect the brake shoe thickness, one had to first jack up the car with a flimsy bumper jack, then go find the cement blocks (that your dad used for something else) to put under the car, then find the big star lug nut wrench (that your brother used and didn't put back), then take off the wheel. Next, pull on the brake drum and see that it is stuck, so go find the BFH (that someone didn't put back in the combine's tool box) then beat on the drum to the point you were afraid you were going to break it. Then if you were lucky, the drum would pop off, exposing you to a face full of finely ground asbestos fibers for you to inhale. NOW, you can inspect the brake shoes for wear. Oh, did I mention that, just as you started, it was getting dark and starting to snow and the wind was whipping snow around from both sides of the car? ![]() humfrz PS - I left out important step, who knows what it was? Last edited by humfrz; 09-08-2019 at 05:02 PM. |
#28 |
The Dictater
| DIY - Changing Your Brake Pads (Race Pads upgrade) | PMok | DIY (Do-It-Yourself) Guides | 53 | 09-03-2021 05:17 PM |
| Brake Pads, Rotors and All Your Brake/Suspension Needs! Great Prices!! Check it out!! | Mike@CZP | Brakes, Suspension, Chassis | 348 | 06-01-2018 12:29 PM |
| Wtb coilovers, brake pads, SS brake lines, engine dress up stuff | IBill4You | Want-To-Buy Requests | 2 | 06-13-2015 03:02 PM |
| Project Mu - Brake Pads, Rotors and Brake Cooling Duct - FREE SHIPPING! | eauto | Brakes, Suspension, Chassis | 255 | 10-15-2014 01:45 PM |
| Redline360: Brake Lines, Brake Rotors, Brake Pads for BRZ/FRS | Redline360 | Brakes, Suspension, Chassis | 12 | 01-05-2013 10:20 PM |
