#15 | |
Drives: 2017 86 860 Special Edition
The shocks definitely changed. Suspension over all is much more compliant and better damped, plus a thicker rear ARB. Hence the curiosity about the specific kouki dampers. |
#16 |
FRS, BRZ, and 86 base model shocks are the same given the same model year, they did change over the years
#17 |
Drives: 2001 Subaru Impreza
Per the 2017 changes PDF, the standard (i.e. non-Sachs) dampers have been changed in the following ways:
- Optimized friction of front struts and rear dampers - Changed damping force of front struts and rear dampers - Changed structure of front struts and rear dampers For front/rear shock internals: - Changed rod guide bushing - Changed damping force - Changed piston |
| The Following 2 Users Say Thank You to scoobydrew For This Useful Post: | strat61caster (09-11-2019), Tokay444 (09-11-2019) |
#18 | |
bruh
Drives: Raven 2015 FRS
#19 |
Drives: 2015 FRS - FFR GTM
Speedway Motors offers Shock Dyno Services,,, I had a set of Konis for the GTM done there.
https://www.speedwaymotors.com/Info/Shock
2015 FR-S - One Day I'll Finish The Swap |
#20 | |
Drives: 84 944 and 2015 brz
#21 | |
https://www.ft86club.com/forums/show...&postcount=302 |
| The Following User Says Thank You to RayRay88 For This Useful Post: | scoobydrew (09-12-2019) |
#22 | |
Directly from Toyota Parts: FL Shock 2016: SU00305257 https://parts.toyota.com/p/Scion_201...U00305257.html FL Shock 2017: SU00306793 https://parts.toyota.com/p/Toyota_20...U00306793.html |
| The Following User Says Thank You to RayRay88 For This Useful Post: | strat61caster (09-12-2019) |
#23 |
Deleted because mistaken.
#24 | |
No, even Subaru has different part numbers for the shocks from 2016 to 2017. FL 2016: 20310CA130 https://parts.subaru.com/p/Subaru_20...0310CA130.html FL 2017: 20310CA170 https://parts.subaru.com/p/Subaru_20...0310CA170.html Rear ARB 2016: 20451CA010 https://parts.subaru.com/p/Subaru_20...0451CA010.html Rear ARB 2017: 20451FG002 https://parts.subaru.com/p/Subaru_20...0451FG002.html The numbers you posted are call out numbers in an assembly drawing, they're not the actual part numbers. The call outs are the same for all years because in terms of BOM/P there are no extra parts in that assembly. The parts department can do nothing with those numbers. Last edited by RayRay88; 09-12-2019 at 05:22 PM. |
| The Following 2 Users Say Thank You to RayRay88 For This Useful Post: | Butterman (09-12-2019), scoobydrew (09-12-2019) |
| The 2nd Official Shock Dyno Thread | Shankenstein | Suspension | Chassis | Brakes -- Sponsored by 949 Racing | 32 | 04-09-2020 08:44 PM |
| What can you learn from a shock dyno chart? Or shock dyno 101 | Racecomp Engineering | Suspension | Chassis | Brakes -- Sponsored by 949 Racing | 30 | 03-01-2016 07:40 AM |
| Shock dyno? | wootwoot | Suspension | Chassis | Brakes -- Sponsored by 949 Racing | 4 | 10-30-2014 02:43 PM |
| Stock FR-S/BRZ shock dyno & stock FR-S spring dyno | xwd | Tracking / Autocross / HPDE / Drifting | 16 | 08-07-2014 09:04 PM |
