Old 08-08-2019, 11:53 PM   #15
Decep
Drives: 2013 FR-S Series 10
when i changed control arms my alignment got out of wack and it was about a degree of toe out. the car was very nervous on the way home, obviously. a degree of toe is way out of line. once i aligned it, it drove great obviously.
i would probably look for a new alignment shop...
The Following 2 Users Say Thank You to Decep For This Useful Post:
maslin (08-09-2019), strat61caster (08-09-2019)
Old 08-09-2019, 02:50 PM   #16
mav1178
mav1178's Avatar
Drives: 2005 Toyota Camry
Originally Posted by jslack View Post
Hi group. Hoping you can help me out. I recently just added a new front and rear sway bar, front ends links and rear lower control arms. As soon as I got done with it the abs and tcs light activate when going around curves mainly going over 50 mph. I didn’t like the feel of the rear sway bar and removed that but the car does seem to still activate the abs and tcs when driving. Could I have done something to an abs sensor? I also have 17 BRZ and I did have to disconnect the hi low level sensor to replace the lca’s. Could that have caused the issue too? Thanks for any help guys.
your problem is you need to get an alignment. and since you already got one, you need a new alignment shop that is more competent.
or do pedal dance every time you drive.
The Following User Says Thank You to mav1178 For This Useful Post:
strat61caster (08-10-2019)
Old 08-09-2019, 06:15 PM   #17
timurrrr
timurrrr's Avatar
Drives: 2022 GR86
That seems strange. I have been much lower (along with many others) and OEM toe arms are plenty of adjustment. Any damage in the rear?
He installed LCA to presumably get some extra negative camber in the back, which is known to affect toe in.
timurrrr is offline   Reply With Quote
Old 08-09-2019, 07:04 PM   #18
finch1750
Undisputed El Presidente
finch1750's Avatar
Drives: Zenki 37J ZN6
I understand. Many people have LCAs and are lowered 2" or more (like I was) and/or running -2.5 or more rear camber. OEM toe arms were plenty to get within spec.
I was going down the line of I think he just needs a quality alignment place vs more parts.
Old 08-09-2019, 07:18 PM   #19
norcalpb
norcalpb's Avatar
I’ve found you only need adjustable toe arms in the rear if you are trying to DECREASE camber.
The Following User Says Thank You to norcalpb For This Useful Post:
maslin (08-10-2019)
Old 08-10-2019, 03:40 PM   #20
timurrrr
timurrrr's Avatar
Drives: 2022 GR86
Interesting data, thanks!
Old 08-10-2019, 05:33 PM   #21
maslin
Benz Tech
Drives: 2017 BRZ Premium
Lowered an inch I got the toe in and camber up to -1*24”. I would have needed the bushings to get the camber closer to 0*.
I installed LCAs to get less negative (closer to 0*) camber.
maslin is offline   Reply With Quote
Old 08-10-2019, 05:51 PM   #22
timurrrr
timurrrr's Avatar
Drives: 2022 GR86
Why on Earth would you want less/zero camber in the rear on a RWD car though?
Old 08-10-2019, 07:42 PM   #23
maslin
Benz Tech
Understeer sucks? I needed less than I had, not zero. My rear camber was -2* and -3* after lowering. Front camber maxed on bolts and a little less in the rear. Lowered twins with 0 front camber and -4* in the back look ridiculous.
Old 08-10-2019, 09:28 PM   #24
churchx
churchx's Avatar
Drives: 2014 GT86
There are several options to dial even more front camber then just with camberbolts. Camberbolts in both holes & lowering probably worth upto -2.5, pedder topmounts -0.75, powerflex bushings also can net similar amount. Those all together imho may net even -4, and that's without going to pillowball camberplates.
Imho to reduce understeer it's preferable to add grip front then to reduce it rear.
Also worth work more with mass-transfer technics to reduce understeer.
The Following 2 Users Say Thank You to churchx For This Useful Post:
maslin (08-10-2019), timurrrr (08-11-2019)
Old 08-11-2019, 08:30 AM   #25
timurrrr
timurrrr's Avatar
Drives: 2022 GR86
Understeer sucks?
Bad traction on all four corners sucks even more.
Old 08-11-2019, 10:00 AM   #26
strat61caster
strat61caster's Avatar
He's limited to bolts in the front which is like -1.x
Putting the rear at -1.4 is reasonable to better balance the car, you're blowing his poor phrasing way out of proportion.
ineedyourdiddly
Old 08-11-2019, 11:23 AM   #27
maslin
Benz Tech
Understeer sucks?
Let me clarify. This sucks.
0* front camber, -3* rear camber is not a correct alignment. For any reason. Adding a bit of front negative camber with bolts and pulling the rear closer to zero not only looks better, but actually works.
I wouldn’t recommend -4*front, -3* rear camber to a car driven on the street. It just isn’t necessary. I think people should be honest about how they drive their cars. I’m a hard (driveway) parker, who commutes 2 or 3 times a month and sometimes gets out an hour or so on Saturday. My alignment works well for me.
Pretty clear here as well, they aren’t dumping the rear camber to gain grip. https://speed.academy/track-alignment-specs-scion-frs/
Mine, degrees and minutes, not decimals. 1.66* front, 1.38* rear.
Old 08-11-2019, 12:25 PM   #28
churchx
churchx's Avatar
Drives: 2014 GT86
Of course, -3.5F/-2.2R is certainly excessive camber for something daily driven. Then again, if you want to argue with practical reasoning, overlowering car, putting widest possible wheels/tires is also making it way less compliant and practical for daily driving. But if it's for those specific weird looks only, such people going for that are willing to sacrifice practicality/comfort/handling anyway. Imho they should only be told against only if they try suggest weird setups for people that are not of their kind but happen to ask advise in same forum.
BTW, imho oversteer/understeer balance also matters way less for daily driving. If one pushes enough on public roads for that to matter much .. imho one's driving is of type to quickly loose license anyway.
The Following User Says Thank You to churchx For This Useful Post:
maslin (08-11-2019)
NRG Hub hard to turn? Scjacob827 Cosmetic Modification (Interior/Exterior/Lighting) 10 10-18-2019 11:44 AM
Traction Control activating in track mode imprezive Software Tuning 2 07-21-2019 06:16 AM
Traction control activating in 3rd and 4th gear... JBezugs Issues | Warranty | Recalls / TSB 5 11-01-2017 11:27 AM
Traction control light comes even when not hard cornering? Yamajee Issues | Warranty | Recalls / TSB 26 04-10-2014 01:04 PM
hit a curb HARD, traction control and ABS light on now need help plz! EvoXDD Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 26 02-28-2013 04:08 PM
