Old 09-16-2019, 04:37 PM   #15
NoHaveMSG
NoHaveMSG's Avatar
Drives: Crapcan
Originally Posted by Butterballz View Post
Update: Had the dealer pull the master cylinder and they said it was dry.
Not sure if that amount of wear would account for the drop in fluid..
No, not even close. Full pad, with new full fluid to worn out pad shouldn't go below the low mark.
Old 09-16-2019, 06:42 PM   #16
Butterballz
Drives: Black FRS
It was between max and min after 5k miles. It's just weird that it happened over time as oppose to right after the track day. I would think the pads wearing down at the track would lead to lower levels immediately so I'm thinking there is still a leak somewhere.
Butterballz is offline   Reply With Quote
Cusco Pedal Install & Pedal Lateral Stiffening (Sideways Loose Pedal) BOND007_LTK DIY (Do-It-Yourself) Guides 5 05-20-2022 05:12 PM
Noises coming from the rear or trunk area? It might be this... Lightened Issues | Warranty | Recalls / TSB 9 03-13-2020 09:54 AM
Rust in clutch pedal area bhbnuckle Issues | Warranty | Recalls / TSB 15 06-27-2016 12:56 PM
Anyone in Tacoma area willing to help with clutch pedal? EpidemicFRS Northwest 9 03-15-2014 05:02 PM
strange coilover install noises/ tried everything NemeGuero Suspension | Chassis | Brakes -- Sponsored by 949 Racing 16 02-27-2013 12:02 AM
