Old 06-30-2019, 09:17 PM   #15
Clutch Dog
Drives: 2017 BRZ PP , 2005 Saab 97X
first big mod was a shift knob. it made it mine. second big mod was the driver mod. drive it for at least a year daily if possible, with changing nothing. understand the chassis and the platform first, especially on the oem tires, and the positive and negative attributes will make themselves known.
uhhh ( 3 month ownership, everything driving dynamic and input was swapped)
Opps
Favorite first mod: Anything Driver input, so shift knob or pedal kit
Worst First Mod: cheap coilovers. OR Cold air intakes
Clutch Dog is offline   Reply With Quote
Old 06-30-2019, 09:54 PM   #16
86MLR
86MLR's Avatar
curious if you've got more info on this somewhere? i'd like to read it
There are 100's of papers, multiple how too's and other various guides on how to design and build a exhaust header.
The whole "tuned length" bit seems to get pushed out with good marketing.
Give them a read, all about torque curves, rpm, hp, primary lengths, secondary lengths, collector design, yada yada yada.
Every single one states to attempt to acheive a equal length in runner length to help with flow.
Lots of talk about reversion, sound waves, pulses, 4:1, 4:2:1, exhaust temps and other groovy stuff.
I actually had a play with a Tomei UEL header vs a OEM header with the cat punched out.
I found the OEM header performed better.
And that is a OEM header with the compromises in the pipe lengths due to the need of fitting in a cat.
It wasn't until the WRX STI turned up that the sound of a poorly designed exhaust header became fashionable.
Prior to the Rex the only other car that sounded like that was a VW beetle, who's exhaust was designed that way because of packaging and cost.
Opinions may vary
Why was the WRX STI header designed this way, from talking to some old rally guys it was about packaging and available room.
Opinions may vary
Why do the ACE headers and other top of the line headers feature so prominently in motorsport?
Hell, a UEL header is basically a excellent example of how "not" to design a exhaust header.
Opinions may vary.
Our racing series here, they all run EL.
The Jap STI, EL.
Nearly every man and their dog swaps the UEL header on the EJ for a EL.
Why do manufacturers still sell the UEL header? the sound....and the fact that with enough good marketing, some companies sell a exposed pod filter and call it a performance upgrade.
Disclaimer: opinions may vary
http://www.ft86club.com/forums/showthread.php?t=133311
I'm only here for the biscuits
The Following 5 Users Say Thank You to 86MLR For This Useful Post:
Face_Plant (07-23-2019), humfrz (07-01-2019), jcw99 (07-02-2019), Jordanwolf (07-02-2019), soundman98 (06-30-2019)
Old 07-01-2019, 03:37 AM   #17
Adam_L
Adam_L's Avatar
Drives: '16 FR-S RS2 MT, '06 xA Polar MT
Best cosmetic upgrade : take off front license plate. Looks better, saves weight.
Cost = about 1 minute of your time, and a little energy = 10 calories maybe.
Math is like Love, simple idea at first that quickly gets complicated
Adam_L is offline   Reply With Quote
Old 07-01-2019, 03:43 AM   #18
NARFALICIOUS
NARFALICIOUS's Avatar
Drives: 88 Supra 1JZ, 16 FRS, 25 GR Corolla
Originally Posted by 86MLR View Post
In 3 to 5 years you will most likely have a different car, even if you think "I'm going to keep this car forever", LOL, YEAH NAH.
I'm going to keep my car forever.
NARFALICIOUS
Noob Poster
1988 | 2016
NARFALICIOUS is offline   Reply With Quote
The Following User Says Thank You to NARFALICIOUS For This Useful Post:
dnieves (07-02-2019)
Old 07-01-2019, 04:14 AM   #19
JD001
JD001's Avatar
Drives: Subaru BRZ
I'm not in the same league as some of fanatical modders on this forum... I've done the following, no regrets:
Tomei UEL header
Berk fast cat fp
Miltek op
Takeda CAI
EucTek tune
Eibach sportlines
Eibach spacers
Negative camber bolts
STI Group N engine and transmission mounts
Williams Ceramic coating..
The car looks standard.. only other "fanatics" clock the different look.
Old 07-01-2019, 05:54 AM   #20
Riftur
Riftur's Avatar
The most bang for your buck that I have found is running E85. You only need the OFT to tune it.
Riftur is offline   Reply With Quote
The Following 2 Users Say Thank You to Riftur For This Useful Post:
Clutch Dog (07-01-2019), Yoshoobaroo (07-01-2019)
Old 07-01-2019, 10:03 AM   #21
PetrolioBenzina
PetrolioBenzina's Avatar
Drives: 17 86
This right here.
PetrolioBenzina is offline   Reply With Quote
The Following User Says Thank You to PetrolioBenzina For This Useful Post:
Old 07-01-2019, 10:42 AM   #22
ermax
ermax's Avatar
E85 and obviously some real tires.
The Following 2 Users Say Thank You to ermax For This Useful Post:
Clutch Dog (07-01-2019), trvth (07-03-2019)
Old 07-01-2019, 10:42 AM   #23
ermax
ermax's Avatar
Originally Posted by DarkPira7e View Post
Best mod - Oil catch cans and tires.
Worst mods - Cold air intake and brake booster delete
Are you kidding or did you really do this?
tomm.brz (07-01-2019), venturaII (07-01-2019)
Old 07-01-2019, 12:32 PM   #24
Qwimby1
Drives: 14 FRS Monogram, 05 Mazdasped Miata
Originally Posted by Raven86WPB View Post
Yeah, I've been looking into the Indy 500s heard they were good FL tires and rain is a definite concern here, thanks for the input!
I mounted Indy 500s after my MPSSs went. I'm very happy with them overall. Good in the often-heavy Florida rain.
Qwimby1 is offline   Reply With Quote
Old 07-01-2019, 12:38 PM   #25
LimitedSlip
Senior Citizen Member
LimitedSlip's Avatar
FYI: Illegal in many jurisdictions and just gives the local constabulary an easy reason to pull you over and look for other offenses.
Don't ask me how I know . . .
This is an initial estimate. Both time and monetary investment will likely increase shortly after being pulled over.
LimitedSlip is offline   Reply With Quote
The Following User Says Thank You to LimitedSlip For This Useful Post:
soundman98 (07-02-2019)
Old 07-01-2019, 01:24 PM   #26
DandoX
Senior gif poster
DandoX's Avatar
Drives: 2013 Asphalt FRS
Better tires
Hood struts
Arm rest
DandoX is offline   Reply With Quote
Old 07-01-2019, 01:59 PM   #27
DarkPira7e
Rust bucket enthusiast
DarkPira7e's Avatar
Oh I didn't realize these were things you had to have done, they were just what I think are the worst mods for this platform
DarkPira7e is online now   Reply With Quote
Old 07-01-2019, 02:01 PM   #28
Clutch Dog
I dont.... *sigh*
I dont think the brake booster delete is a "bad" mod. typically its done on one of two mindsets
Shaven Engine bay ( bad mod)
Better Braking feel
The dirt fish guys all have brake booster deletes and are running slightly better masters ( think ) for better feel under braking. and while yes you have to really push the brake pedal to make the car stop your control is almost unlimited. and when you get used to it, it doesnt matter
the whole boosted portion is for comfort on daily driving.
first 86, first mod, new car, oft tablet, tuner
Absolute cheapest way to a better sound exhaust? Gofrs Engine, Exhaust, Transmission 25 04-24-2014 11:10 AM
i Buy an Absolute Base 86, where do I go on the net to bring it up to Snuff? LBC Por Siempre Scion FR-S / Toyota 86 GT86 General Forum 17 02-20-2014 10:31 AM
Absolute insanity – A 1400WHP GT86 Casper Scion FR-S / Toyota 86 GT86 General Forum 19 02-04-2014 07:28 PM
