Old 07-02-2019, 07:22 PM   #15
Route
Route's Avatar
Drives: 2007 GT3 | 22' BRZ
Originally Posted by ayoshioka1 View Post
Update 7/1/2019
Just got all of my necessary parts in friday afternoon and spent all night installing everything so i can get it ready for an alignment the following morning. All of the work was done myself besides the alignment.
Suspension / Wheels / Tires :
Fortune Auto 500 Gen 7 6k/7k
Whiteline RLCA, SPC Toe Arms
Advan TC3 18x9.5 +45 255/35/18 Firestone Firehawk Indy 500 Square setup.
Project Kics R26 Gunmetal w/ locks (due to the nature of the offset, i figured having extended lugs would look kinda weird... and i was right. the R26 is the perfect length to fit within the wheels lug hole depth.)
No fender rolling. -2.4 Front Camber / -0.7 Rear Camber - 0 Front Toe 0.2 Rear Toe. Alginment done by Best Care Auto in Orange County.
No rubbing what so ever with this height and able to turn full lock to lock with no issues.
These pictures were right after the install, and the car has settled and lowered a bit in the rear to match the fronts. I like my cars low and aesthetically pleasing while still providing good performance all around. I will definitely get some better pictures soon!
0-100 real quick
Route is offline   Reply With Quote
The Following User Says Thank You to Route For This Useful Post:
ayoshioka1 (07-03-2019)
Old 07-03-2019, 04:58 AM   #16
WC-BRZ
Drives: Black BRZ
Update 7/1/2019
Is there any chance you may be able to provide a brief review on the FA 500 coilovers?
Which other coils did you consider before going with these?
Specifically, how does the chassis feel over mid-corner bumps? Of course it doesn't have to be a focused track review, but if you have any bumpy roads around you (especially, curvy bumpy roads), I'm wondering if you get the sensation that the tires can maintain contact during mid corner?
Other insights would be great as well; turn in, overall handling and response, etc.
Granted your alignment and tire setup will impact your review, but any input would be great either way!
Car looks badass
WC-BRZ is offline   Reply With Quote
Old 07-03-2019, 07:30 PM   #17
ayoshioka1
Drives: 2019 BRZ / E36 325is
Car looks badass
Thanks for the kind words <3
The other coilovers i had my eyes on were the HKS Hipermax IV SP, KW V3 or club sports, Ohlins Road and Track.
JDM coilovers were highly considered but HKS has stopped all coilover maintenance here in the US and they would need to be rebuilt overseas in Japan. With KW i didnt want to settle with a twin tube design and wanted something more robust with a monotube damper. As for Ohlins, they are a more track oriented setup and seeing that my car will see 80% street and maybe 20% track time through out the year. It didn't make sense to me go with a track spec setup which would compromise ride comfort.
Initial impressions of the FA500 Gen7 is quite good. The ride compliance is a bit more stiff than stock (3 clicks from full soft), but the ride is very smooth with no jarring or crashing over bumps, such as railroad tracks, man hole covers and small crack on the parking lot floor. The slight digressive nature of the shock truly does feel very apparent on the freeway as you hit cracks and differences in pavement at high speeds. The car stays flat and absorbs those bumps quite well, dare i say a little better than stock imo. I have only driven on the freeway, not so much in the corners so i have yet to test the setup as of late. With the new suspension and tire combo i do feel a lot of grip and response when i turn the wheel. Mid corner grip on and off freeway ramps is pretty good. Car feels stable doesn't wander and want to kick out like it used to.
I will be doing a shakedown of the car soon in the next auto-club autocross event and then i should be able to dial in the car to suit my driving style. I'm already thinking that the rear camber may not be enough so i will address that later on as i get more acquainted with the new chassis.
23 GR86 Halo MT Prem - Racecomp Engineering SS-2 - Sayber Designs - Voltex - RE71RS - Project Mu
ayoshioka1 is offline   Reply With Quote
The Following User Says Thank You to ayoshioka1 For This Useful Post:
WC-BRZ (07-03-2019)
Old 07-04-2019, 01:05 AM   #18
jflogerzi
jflogerzi's Avatar
Let me know when you go. I would to meet other local members and do an auto cross event.
2013 Series 10 FRS #553
Old 07-05-2019, 03:17 AM   #19
ayoshioka1
definitely, id love to meet some fellow frs/brz owners as well!
2019 Fiesta ST or 2019 Subaru BRZ korhun BRZ First-Gen (2012+) — General Topics 97 08-02-2019 09:56 AM
Would you prefer 2019 Toyota TRD or 2019 Subaru BRZ limited Busybee Scion FR-S / Toyota 86 GT86 General Forum 64 02-24-2019 01:05 PM
Alex's daily FRS UPDATED 2019 Toyota 86! Alex86em1 Member's Car Journals 11 11-02-2018 02:38 PM
Alex's SWP BRZ Buurz Member's Car Journals 14 05-07-2015 09:37 PM
Alex Bin Jackson's BRZ AlexBinJackson Member's Car Journals 3 10-28-2014 04:53 PM
