#15 | |
#16 |
Drives: '23 BRZ
I don't have direct experience with the PS4S, but given the tread pattern I suspect it would generate more heat and not stay at peak performance for as many laps, and also wouldn't provide the same kind of direct feedback from the contact patches as a good Extreme Performance or streetable R-comp tire. That said it's surely "close enough" that anyone casually/occasionally tracking an FT86 that came with PS4S could just use them and not bother with EP or Rcomp tires.
| The Following User Says Thank You to ZDan For This Useful Post: | strat61caster (06-05-2019) |
#17 |
Drives: 2016 Scion FRS
I'm not a track guy, but I've autocrossed quite a bit.
I get not starting on bias ply slicks or something, but I'm not sure I totally buy into the learn on crappy tires theory. 1) It is supposed to be fun. 2) You'll never stop learning. When is it appropriate to run the fun stuff? 3) If you don't pick a decent tire, you'll probably get frustrated pretty quickly. You may even pick up bad habits from trying to throw around a car on really bad tires. |
| The Following 3 Users Say Thank You to steverife For This Useful Post: |
#18 |
less grippy tires ARE more fun... lap times aren't the fun part, unless the fun part to you is buying the way to faster lap times. The fun part is being at the limits as much as absolutely possible.
The fallacy in tracking is the thought that if you have a faster time, you did something right. This is only the case if all other conditions are the same. Fun stuff for me is still the cheaper / less grippy, but predictable tires... this is after running through the old PSS, ZII Star Spec, RS3, Z214, V12 Evo, SX2, RE71r, Toyo RR, V710s and RC1s (i think that runs the gamut of what I've run?). At this point, I get whatever is most cost effective without being a safety concern (not doing 600tw all seasons that are going to chunk all over the place). I'd rather drive than spend more money on tires. Besides, it's more fun passing people, having them come up to you... and then all you have is a stock car with street tires on when they have _______ with _____ WHP and r-comps. But... if you just need the faster lap time for bragging rights and have the money to burn, go for it! |
| The Following 3 Users Say Thank You to pcs For This Useful Post: |
#19 | |
I do want to get RE71Rs finally for autocrossing though ![]()
#20 | |
Drives: Crapcan
| The Following User Says Thank You to NoHaveMSG For This Useful Post: | strat61caster (06-07-2019) |
#21 |
RE71R's are fun, they're just more expensive per smile.
| FS: Brand New Set of Black RPF1 17x8 +45 w/ Toyo R888Rs & TPMS | TheWeatherman | Wheels and Tires | 10 | 10-14-2018 08:45 AM |
| Super cheap track day? Super cheap track day!! | Decay107 | Northwest | 8 | 04-05-2015 01:36 AM |
| Cheap tires as good/bad as oem | theurge | Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack | 11 | 07-24-2014 02:40 PM |
| privat legende wheels SUPER CHEAP help me out! | WillBRZ | Northern California | 3 | 05-29-2013 07:38 PM |
