Old 05-29-2019, 12:25 AM   #15
squelchy451
Drives: Pending
Yup! Same license plate, just checked on Turo haha!
squelchy451 is offline   Reply With Quote
Old 05-29-2019, 03:34 AM   #16
dhuang
Cannonball Record Guy
dhuang's Avatar
Drives: Series.Yellow, 4C, Fit
Wow, small world indeed.
What's crazy is less than a month after renting the same 86 you drove, my roommate sold his AP2 S2000 + Miata (pending) and picked up a (very similar) '17 Ablaze 86 -- the Turo rental certainly made a strong impression on him.
(Our Ketchup & Mustard combo)
Originally Posted by dhuang View Post
I think you and my roommate may have rented the same car from Turo!.
He rented an ND Miata in SF, hopped into a Jeep and drove down to LA, and spent a few days with a red 86 with TRD wheels & exhaust.
Came back to Atlanta and wanted move from the Miata platform to the twins.
2017 Series.Yellow
2013 Whiteout
VINwiki - Changing Automotive History
dhuang is offline   Reply With Quote
Old 05-29-2019, 12:01 PM   #17
squelchy451
Drives: Pending
ND engine and trans inside a BRZ layout would be perfect. The Skyactiv 2.0 was a capable little engine and I had no complaints when I had the Mazda3.
As it stands, the clutch and shifter on the 86 are the only things I didn't like.
Old 05-29-2019, 12:09 PM   #18
accwai
初級成員
Drives: 2017 86, 2010 Corolla
[...] Jeez, I guess my opinions aren't welcome here then.
I just wanted to point out how comfortable it actually is. All the other reviews I've seen focus way too much on how fun it is to drive. I'm out to buy the most fun comfortable car, and this falls under the 'comfortable' category in a way that the Mazda3 wasn't.
Oh your opinions are welcome for sure. But my wife would totally disagree with your point about comfort. And she's been on the passenger side of an 86 of the exact description as yours (same color, model, TRD stuff etc) for a lot more than 72 hours. So I would assume her opinion would count for something too
accwai is offline   Reply With Quote
Old 05-29-2019, 04:56 PM   #19
Th3rdSun
Drives: 2013 FR-S MT Hot Lava
The clutch is a bit high compared to other MTs and took me quite a while to get use to. The shifter is fine,but becomes great if you add a Raceseng Ashiko weighted knob,and I can't even imagine what it would feel like if I put a Kartboy in!
Th3rdSun is offline   Reply With Quote
Old 05-30-2019, 10:28 AM   #20
bandy
Drives: 2017 Toyota 86
OP: I'm @dhuang's roommate. I really enjoyed that rental and ended up buying essentially the same car once I made it back home. I enjoyed taking that car around the fun roads near LA and el mirage but it took me over an hour to detail the car before I brought it back. Hope it was still clean for you
bandy is offline   Reply With Quote
Old 05-30-2019, 10:44 AM   #21
Xerexyz
Drives: 2017 Toyota 860 in Supernova
As long as it is the newer higher revving version of the 2.0.
Honestly though, I owned a Mazda3 2.5 MT for 2 years and never really liked the engine much, it was the weakest link. Maybe it was just the gearing and the fact that the 3s are setup for efficiency.
At least the FA20 has some kind of character to it.
Xerexyz is offline   Reply With Quote
Old 05-30-2019, 11:10 AM   #22
WNDSRFR
Drives: FR-S,GTI
I'm probably going to keep the GTI for the long term. Still a fun ride, I just wish more cars didn't do this little shimmy at highway speeds.
What GTI do you have?
I still have my 2002 Mk IV. It has over 275,000 miles on it and still runs like new.(after spending 10's of thousands of dollars over the years to keep it running. I stripped out the interior and use it pretty much as a pickup truck anymore. Just taking out the seats alone lightens it by at least 300 lbs. It really hauls ass now.
As far as shifter comparisons, the FR-S has the tightest shifter I've ever had. And I've had a lot. The GTI has by far the worst shifter ever made IMO. It feels like moving a stick around in a tub of luke warm tar.
Once you buy the 86 you'll never drive the VW again. I'll bet.
Old 05-30-2019, 03:02 PM   #23
squelchy451
Drives: Pending
I have a 2007. I do have a Neuspeed short shifter, some cable end bushings, and a South Bend clutch, so the drivetrain feels super solid. The stock shifter, while vague, is smooth.
Maybe I had a bad apple, but the shifter on 86 just felt very flimsy. It was cool seeing the stick shake a little when you fire up the engine, but using it wasn't exactly what I expected. Maybe bushings, weighted shift knob, or some other aftermarket part could take care of that.
Old 05-30-2019, 03:13 PM   #24
Keep in mind that the shifter in the 86 is hard mounted directly to the transmission with only 4 inches of shaft between them. There are no cables, rods or other isolating parts that reduce vibrations.
The direct connection also is what makes it feel weird when used to cables and shafts. You get used to it really fast. To me cable type shifters feel sloppy and loose.
Old 05-30-2019, 03:55 PM   #25
Jordanwolf
Rice King
Jordanwolf's Avatar
Agree.
Glorious Honda.
Jordanwolf is offline   Reply With Quote
Old 05-30-2019, 04:07 PM   #26
EAGLE5
Dismember
EAGLE5's Avatar
Drives: 2013 Red Scion FR-S
I like the GTI. When I got the FRS, it was in third place, behind the Abarth and tied with the Golf R. If the GTI or R were cheaper, maybe things woulda been different. We also ended up getting a Fiat 500E, which is like an Abarth with a better motor and worse suspension. Honestly, one of the most fun cars ever. I still think of buying a 500e, stripping the interior completely, putting on some hacked together Bilsteins, and installing a Recaro seat. It would be epic fun.
I no longer dream of the GTI or Golf R at all.
Old 06-03-2019, 02:54 PM   #27
squelchy451
Drives: Pending
I was surprised that I preferred the shifter on the GTI, as you all correctly pointed out, is a cable linked mechanism. Stock-for-stock, the 86 wins out marginally, but with the aftermarket bits, the GTI feels better for me. I'll definitely invest in a short shifter kit and a mount insert when I do get a 86/BRZ. I just love the steering feel more than anything else.
Old 06-04-2019, 02:16 PM   #28
DarkSunrise
DarkSunrise's Avatar
Also surprised about your preference for the GTI gearshift. I recently drove a MT mk5 GTI and the shifter was smooth, but vague. Fun car otherwise though with a stage 2 package.
2022 BRZ Build
2013 FR-S Build
***NEED SOME HELP IN THE NEXT FEW HOURS IF POSSIBLE??*** NorCalGirl Northern California 1 01-21-2015 05:39 PM
FIA WEC - 6 Hours of COTA mav1178 Other Vehicles & General Automotive Discussions 9 10-16-2014 03:26 AM
Anyone going to the 12 Hours of Sebring? Rampage Southeast 14 03-19-2014 11:00 PM
15% off for the next 48 hours at DetailersDomain.com DetailersDomain Cosmetic Maintenance (Wash, Wax, Detailing, Body Repairs) 0 10-27-2013 09:48 AM
Few Hours w/ an Ultramarine Guaruja FR-S & 86 Photos, Videos, Wallpapers, Gallery Forum 30 04-07-2012 04:42 AM
