Tracking / Autocross / HPDE / Drifting What these cars were built for! |
08-24-2019, 11:19 AM | #15 |
Please do not use a harness and bucket in a street car. You are compromising the safety systems designed to keep you safe.
Please do not use a harness and bucket on track without at least a half cage with harness bar. This method of using harness is for show cars only, and is NOT SAFE. |
The Following 4 Users Say Thank You to CSG Mike For This Useful Post: | CrowsFeast (08-26-2019), NoHaveMSG (08-24-2019), Racecomp Engineering (08-29-2019), timurrrr (08-24-2019), why? (08-24-2019) |
08-24-2019, 10:29 PM | #16 | |
Drives: 2017_86 2016_frs 2007_335i
if i add a harness bar. is it will be safe enough?
YouTube Video:http://www.youtube.com/channel/UCBXFeelPFI8XzGese8Eug-g
ins:zayliu.jiayu Build Journal:http://www.ft86club.com/forums/showthread.php?t=136068 "if in doubt flat out" |
08-24-2019, 10:45 PM | #17 |
08-24-2019, 11:44 PM | #18 |
08-24-2019, 11:55 PM | #19 |
Drives: Crapcan
08-25-2019, 05:44 AM | #20 | |
so, its need a roll cage then.
08-25-2019, 11:01 AM | #21 | |
Drives: Crapcan
Half cage with a harness bar min as CSG Mike said.
08-26-2019, 03:35 AM | #22 |
thx for the help, slowly getting there!
08-26-2019, 04:55 AM | #23 |
For a street car, you only really want a half cage, with a full cage ingress and egress is a PITA (a full cage without side intrusion is stupid), plus without a helmet your head will open up like a smashed water melon if it comes into contact with the bar (window bar or front leg), seat design can negate this to a point, but visibility can be lost , harness bar is a given.
For a street car there is always compromises, BUT, never on safety. Weld in is best, bolt in is adequate. Good installation is paramount, welds, bracing, plating, bolts, if any of these points fail, the roll bar might not give any protection, or kill you even in a minor crash. Seat mounting, same same, mounting points and seat angle. Harnesses, if you are doing it, do it right, get a 6 point, your balls will thank you, mounting points, correct fixture position, both angles and points. No point adding safely devices that are installed incorrectly, making them worse than OEM in a crash. My 2 cents, go to a joint that preps race cars, NOT, your local tuner, or mate with a drill and welder. Cool story (bro): when I was young and dumb I put in a 4 point, it worked OK, till I hit a barrier, then I basically ended up mostly in the foot well, turned out my seat angle was wrong (not enough angle) and the 4 point was actually the reason I turned into a submarine. Be safe, have fun.
http://www.ft86club.com/forums/showthread.php?t=133311 I'm only here for the biscuits |
08-26-2019, 09:19 AM | #24 |
Drives: 2013 BRZ Sport-Tech
If you are at all wondering why the installation is so important (and often unsatisfactory for bolt-ins) look at this picture closely (unless you're squeemish)
This was a bolt in cage that did not have proper reinforcement/bracing at the mounting locations. Notice that the cage just blew right through the floor pan and that there is no 'roof' anymore. Miraculously I believe that both the driver and passenger survived this crash uninjured but don't expect the same fate awaits everyone experiencing this failure. EDIT: can't seem to figure out why the image is only visible half the times I load the page... Last edited by CrowsFeast; 09-04-2019 at 12:12 PM. |
The Following User Says Thank You to CrowsFeast For This Useful Post: | Racecomp Engineering (08-29-2019) |
08-27-2019, 01:13 AM | #25 | |
so for the stx in autox and 4 trackday in a year i may just need harness bar and a good hans right? in my opinion, the only thing i changed is side airbag, and 6 points harness(only use it on track maybe) it should be just safe as factory right? did nothing but a seat, and stock seat belt is working just as before
08-27-2019, 01:15 AM | #26 | |
08-27-2019, 02:42 AM | #27 |
https://www.google.com/search?q=roll...obile&ie=UTF-8
I used a Bond bolt in half cage in my Skyline and a MX5 Plus bolt in in my, um, MX5
08-27-2019, 10:57 AM | #28 |
Similar Threads | ||||
Sit in the rear seat for me ;) (with photos of people in back seat) | D4ng3r | Scion FR-S / Toyota 86 GT86 General Forum | 125 | 11-14-2013 06:59 AM |
Portland people meet with Seattle area people before going into ForumFest 2013? | stockysnail | Northwest | 24 | 06-18-2013 06:19 PM |
Passenger seat not sliding to let people out.. | wparsons | Issues | Warranty | Recalls / TSB | 9 | 10-01-2012 07:28 AM |
Seat fit for tall people? | clubraf | Scion FR-S / Toyota 86 GT86 General Forum | 14 | 06-29-2012 10:51 AM |
Pics of people sitting in rear seat | glorydays | FR-S & 86 Photos, Videos, Wallpapers, Gallery Forum | 2 | 12-08-2011 04:54 AM |
