#15 | |
Drives: Legacy GT
I remembered that I had plotted a few of the points from the suspension model thread and opened that up and measured some angles. The numbers in that spreadsheet are not right, and I moved things around a bit to what seemed more accurate based on the track width, tire size, sai, and listed roll center height. Not exact but hopefully close and shows how the camber curve should generally look: ![]() 0,0 is where the ball joint and inner control arm pivots are level, starting with zero camber at that point. I went up to see where the camber would stop going more negative and it appears to not happen until the ball joint is 4-5" above the inner pivot point. Which is much farther than the suspension can actually move. It might only have 2" from that point. I think the reason for the difference with the other models is that some of the software treats a strut like double a-arm with an infinitely long upper arm. Maybe. I remember hearing that for some reason but don't remember where. But doing it like that would produce those curves posted earlier as the top mount would be moving straight up and down and the arc of the ball joint would be the only factor for the camber curve. |
#16 |
Drives: 2023 BRZ
I thought you guys might appreciate the data @fika84 and I gathered on the new Whiteline roll center correction kit. It appears it is beneficial even for cars lowered only an inch. Check out the thread here. Specifically, the most recent post (as of today) shows the benefits.
FWIW, I did everything reasonably possible to ensure the only variable between the two tests were the Whiteline kit. I also learned I should run all four tires at the same PSI. I had been running the driver's side front tire 0.5 PSI lower than the rest. But now I'll run them all at 34 PSI. They are GT Radial Champiro SX2s in 225/45-17.
Director of Rocky Mountain 86CUP
#17 | |
Drives: '22 BRZ
Would you be able to dig that data up and post it here?
#18 |
Drives: 2023 BRZ
Unfortunately not, Doc. Sorry, but that forum was shut down.
| Roll Center correction | Mikepage | Suspension | Chassis | Brakes -- Sponsored by 949 Racing | 4 | 03-14-2016 03:22 PM |
| Whiteline Roll Center/bump steer kit - KCA435 | MicheleAbbate | Brakes, Suspension, Chassis | 4 | 03-14-2016 01:33 PM |
| For Sale: Whiteline roll center correction kit BNIB | xDanger_208x | Brakes, Suspension, Chassis | 3 | 06-23-2014 09:56 AM |
| Whiteline Roll Center/Bump Steer Correction Kit! | MAPerformance | Brakes, Suspension, Chassis | 3 | 10-23-2013 10:24 AM |
| Whiteline releases their roll center/bump steer correction kit for the BRZ/FRS! | RallySport Direct | Suspension | Chassis | Brakes -- Sponsored by 949 Racing | 19 | 10-15-2013 05:57 PM |
