Old 04-16-2019, 01:23 AM   #15
steve99
Originally Posted by Scremin@ATS View Post
I called HPI tuning and emailed ecutek. HPI initially thought the cable was bad, but I can see the cable in ecutek (just won't turn green). Due to that HPI thinks maybe the ecutek software revision (build) might be bad.
Anybody happen to have an old build?
Sent from my SM-G950U using Tapatalk
You eould tgink if the ecutek software build was bad causing calbes not to be recognised lots of people would be haveing same issue and ecutek would know about it.
As guy above said try deleting and reibstalling drivers for cable.
I know a couple of guys thst have had same issue and its been cable, quickest way is to try anyone elses cable ( just the cable not dongle)
We cannot wend you our ecutek as each install is keyed to your dongle id
Techstream TIS VCI Installation Guide (64-bit OS) Including All Software Needed! Jhood Software Tuning 48 03-09-2024 06:04 PM
Unichip tune software needed almeshtaq Software Tuning 0 06-24-2016 02:58 AM
Body Shop Guru's needed.. samisons Cosmetic Modification (Interior/Exterior/Lighting) 4 01-13-2014 12:50 AM
Audio Guru help needed Thongpocket Electronics | Audio | NAV | Infotainment 17 10-03-2013 07:13 AM
So what ECUtek software do you need to make changes to the ECU yourself? seven Engine, Exhaust, Transmission 30 01-04-2013 12:58 PM
