Old 08-01-2012, 10:02 AM   #15
Esoteric
Esoteric's Avatar
Drives: FR-S|(2)AE86|TA22|E30M3|E36M3|BPLeg
The only thing that has kept us from going forward is the cost to the end user.
I'm not sure how much people will spend to get that last bit of N/A power... and those who will be racing, what the rules will say about a mani swap
Esoteric is offline   Reply With Quote
Old 08-01-2012, 10:09 AM   #16
Motordyne
Motordyne
Motordyne's Avatar
Drives: Nissan Z & Infiniti G
Motordyne is working on a new intake manifold for the FRS/BRZ now.
Its too early to say what the results will be but even modest changes to the intake runners can significantly change the power curve.
Below is an example of what we did on a Nissan 350Z. Very large gains in power and torque. If gains like this can be made on the FRS/BRZ, it would be awesome.
We will soon see.
Motordyne is offline   Reply With Quote
Old 08-01-2012, 01:03 PM   #17
OrbitalEllipses
Drives: Attitude
Originally Posted by ExiledLakai View Post
The people that go FI should think about them. Being plastic its hard to tell how much it will hold up to. I'm sure cosworth will have one out by years end.
The plastic IM is better than any stock cast aluminum one; it's less susceptible to conducting heat from the engine bay and flows more as well. A replacement will likely be unnecessary for 90-95% of consumers. Opposed piston engine manifolds typically don't see large gains; at most you gain at the top end and lose at the bottom end just because they're hard to design (or rather, a good design is too expensive for the average consumer to justify and knock-offs soon follow). That plastic manifold is advanced technology, bro.
Old 08-01-2012, 01:17 PM   #18
xwd
Yeah on the turbo EJ2xx motors there have been some gains to be found with manifold swaps but only at huge power levels and they sacrifice low end power. However, the FA20 is a whole different engine compared to those so it will be interesting to see how well Subaru designed the factory manifold. And like the above guy said, most aftermarket manifolds are $1k+ in price.
In the past the NA engines have had pretty good manifolds, even for FI applications. Some guys even swap the NA manifolds onto the turbo engines.
Old 08-01-2012, 03:13 PM   #19
Jason@Nameless
Jason@Nameless's Avatar
Drives: '88 BMW 535is Turbo
dwx, Indeed. 2.5RS manifolds are the go-to for cheap off the shelf large plenum manifolds for the STi. Go early enough and aside from injector and rail adaptation, you ditch the TGV's as well.
We certainly have some ideas to play with on this engine with and without ITB's that I'm certain can beat the factory manifold handily. As for heat soak concerns with Aluminum parts vs. injection molded, most of these issues can be handled with a two piece manifold running composite lower and tubular upper. Phenolic spacers work wonders in those applications as well and we have the ability to have them silicone beaded to get a perfect seal without any goop or spray hassle.
Either way, we're doin it. It's another area we want to invest time in and with a car permanently in house now, we're eager to use its availability to do more iterative testing and learn some new stuff.
Jason
Jason@Nameless is offline   Reply With Quote
Old 08-02-2012, 02:12 AM   #20
NOBROWS
NOBROWS's Avatar
Drives: 2013 FIRESTORM FRS
Originally Posted by Jason@Nameless View Post
We are game. Both for a sheet metal or cast long runner design and an ITB option. Have some further details on our exhaust offerings to test out and then we wi be tearing the top end off the engine.
Jason
intake ! with a induction scoop!
2013 Firestorm Red FR-S
1993 Honda civic track car
Motivate 2 Hate Motorsports
NOBROWS is offline   Reply With Quote
Old 08-02-2012, 09:28 AM   #21
Kuzuri
__(X)__
Kuzuri's Avatar
Drives: '11 Legacy, '89 190E, '78 GS1000
waiting for this. I think we could see some nice gains from a mani swap once boosted
Kuzuri is offline   Reply With Quote
Old 08-02-2012, 09:41 AM   #22
Ricepuddin
Get a Bowl
Ricepuddin's Avatar
Drives: 2017 BRZ PP
Jason
ITBs, would sound beastly. I am curious how well the electronic throttle will work with them.
Sent from my Galaxy Nexus using Tapatalk 2
Ricepuddin is offline   Reply With Quote
Old 03-18-2013, 06:53 PM   #23
Grip Ronin
The Mechanic
Grip Ronin's Avatar
Drives: Civic Turbo,FR-S
Its too early to say what they results will be but even modest changes to the intake runners can significantly change the power curve.
We will soon see.
Wasnt this due to the oem manifold starving the rear 2 cylinders? That was a older z issue. I don't think the frs would gain like that. ive been waiting on a manifold to see if we can find a real weak spot in the setup and not this little 5hp at 7100rpm from $2000 in exhaust parts lol
IG-Joey_Soul
Old 09-22-2014, 12:42 AM   #24
viking
Drives: 2013 scion frs
Any updates on this stuff yet ?
viking is offline   Reply With Quote
Old 12-01-2014, 03:40 AM   #25
Carlitoz3
Carlitoz3's Avatar
Drives: 2013 MT Asphalt FRS
We will soon see.
Jason
Updates?
Carlitoz3 is offline   Reply With Quote
Old 12-01-2014, 03:55 AM   #26
2much
I wanna go fast
Drives: 2013 FR-S 6MT
hmm this would go really well with a stroker kit too...
2much is offline   Reply With Quote
Old 12-01-2014, 04:55 AM   #27
Captain Snooze
Because compromise ®
Captain Snooze's Avatar
Drives: Red Herring
Did you notice that that Motordyne post is from 2012 and their last post was the 22nd of the same month?
I suspected not.
Old 12-06-2014, 02:21 AM   #28
viking
Brutal sucks that our only option is crawford billet blocks rather have a whole manifold to have something pop under the hood
Exhaust System/Exhaust Manifold Removal and Replacement GrimmSpeed DIY (Do-It-Yourself) Guides 52 11-11-2015 09:30 PM
Anyone going to paint their manifold covers? quik1987 Cosmetic Modification (Interior/Exterior/Lighting) 64 07-30-2014 02:39 PM
New intake? Mo707 Engine, Exhaust, Transmission 13 07-10-2012 05:55 PM
GRD intake kit. jet86 AUSTRALIA 9 07-09-2012 09:51 PM
HKS Intake? CoRi J Engine, Exhaust, Transmission 31 07-05-2012 07:53 PM
