Old 03-21-2019, 05:13 PM   #15
brzcui
Drives: 2014 supercharged brz
what tune are you guys running on your cars? i'm definitely gonna look into retune the car because the dealership guys said it looks like a bad tune, but tuning comes after i fix the car completely
brzcui is offline   Reply With Quote
Old 03-21-2019, 05:16 PM   #16
maslin
Benz Tech
Drives: 2017 BRZ Premium
Originally Posted by brzcui View Post
should i have the shop check for vacuum leak and loose wire then? right now i can't even tell the shop what's wrong with my car lol, do you think i should upgrade the fuel pump too? the codes about the fuel running too lean is kinda worrying me
You don't have to diagnose your car before you take it to the shop. That's what a shop is for. What's wrong with you car is that the CEL is on and it stalls and runs like crap.
Take it to a shop. We've all probably been in over our head a bit, sounds like you made a hefty investment in an older modded car. It's only going to cost more money.
In my experience, people don't flip good solid cars. There's a reason he was moving it down the road so quickly.
maslin is offline   Reply With Quote
The Following 3 Users Say Thank You to maslin For This Useful Post:
brzcui (03-21-2019), humfrz (03-21-2019), Tcoat (03-21-2019)
Old 03-21-2019, 05:18 PM   #17
That was where I was headed next.
brzcui (03-21-2019), maslin (03-21-2019)
Old 03-21-2019, 05:20 PM   #18
brzcui
yah i definitely learned my lesson on this one, he told me the reason he sold it is because his wife hates how much money he puts on to fix the car and it's too small too low... and he needs some money back from this car to start his jeep project
Old 03-21-2019, 05:23 PM   #19
brzcui
i called two shops today, one of the shops works with edelbrock superchargers but only on mustangs and the other shop has no experience with any brz but has worked on turbo builds before, these are the two shops that i can possibly drive myself to just for a check? another option would be the tuning shop i had my car in two weeks ago, but its about 45 miles away and i don't really feel like driving an hour with the check engine light on, what should i do tho?
Old 03-21-2019, 05:25 PM   #20
brzcui
or i can take it to the shop down the street, i called them a while ago when i didn't have a ob2 scanner and they said they will charge me 160 bucks to pull a code lol
Old 03-21-2019, 05:26 PM   #21
maslin
Benz Tech
Wild guess... 4 door JK with a ton of bolt on parts and angry eyes? Welcome to my damn neighborhood, the place is over run with hardcore rigs that will never see any dirt.
Find a shop that will work with you. You don't need everything fixed at once. You need it to run reliably, then tackle the other stuff.
The Following User Says Thank You to maslin For This Useful Post:
brzcui (03-21-2019)
Old 03-21-2019, 05:31 PM   #22
brzcui
ya it was a super old jeep with bolt on parts, he was planning on building it as his next daily and retiring the truck, definitely wasn't gonna take his jeep off roading
Old 03-21-2019, 05:33 PM   #23
ybotspawn
ybotspawn's Avatar
Drives: 13 Subaru BRZ
I wouldn't worry about the tune as much as I'd worry about the health of your supporting components. Each one of us has done different things to our cars, so comparing tune's wouldn't do you a bit of good. Do what Tcoat, Maslin, and DarkPirate have said and take it to a shop.
ybotspawn is offline   Reply With Quote
The Following 2 Users Say Thank You to ybotspawn For This Useful Post:
Old 03-21-2019, 06:36 PM   #24
alphasaur
friendly
Drives: 17' 86
If you're in PA you should try motoeast they have a fairly good reputation
Seek comfort in discomfort.
alphasaur is offline   Reply With Quote
The Following User Says Thank You to alphasaur For This Useful Post:
brzcui (03-21-2019)
Old 03-21-2019, 07:39 PM   #25
steve99
@brzcui
The shops your using dont seem to be doing good diagnostics
Diagnostics is npre than just reading cel codes and randomly replacing bits baeed on cel codes.
They need to log ecu fueling timing, port and direct injection times afr closed open loop fueling knock etc to work out whats going on.
Also trying to diagbose anything without acces to the ecu tune is going to be difficult as different tuners do things in different ways and if its ecutek it add functionality to the ecu via custom maps or speed density tuning.
Often port injectors are changed and MAP sensors changed when tuned for forced induction these changes need to be mapped into tune or car will run like crap.
Other common issues are intake and exhaust leaks, thes can often be deteced by logging ecu parameters like fuel trims or manifold pressures.
Also check the Direct injection computer is securly bolted up to side of engine will all three mount bolts that its only ground\earth.
Your going to need to take it to a shop that is familiar with brz\86 forced induction its unlikely any other shop will be able to help the shop will need diagnistic and logging tools for brz\86 and the tune system possibly ecutek that the car is tuned with
The Following 3 Users Say Thank You to steve99 For This Useful Post:
brzcui (03-21-2019), maslin (03-21-2019), Tcoat (03-21-2019)
Old 03-21-2019, 07:49 PM   #26
humfrz
Hey guys im new to the forum, - really any help is appreciated, i have no idea what is going on with the car
Hello brzcui and welcome to …. The Forum -
After reading all of your posts and the responses, I would strongly suggest that you sell that machine "as is". Just tell the prospective buyer that it's not running good and you have no idea what's wrong with it.
Let the buyer be a hero and figure it out.
Then, don't do that no more -
humfrz
The Following 3 Users Say Thank You to humfrz For This Useful Post:
brzcui (03-21-2019), x808drifter (03-21-2019), ybotspawn (03-21-2019)
Old 03-21-2019, 08:15 PM   #27
humfrz
That may be a tad extreme. It could still be something very simple. The fact that it is so interment would sort of indicate that.
brzcui (03-21-2019)
Old 03-21-2019, 08:42 PM   #28
Lantanafrs2
Drives: 2013 frs red
Imo if there are no unhealthy mechanical noises there's hope. Don't panic. Just get it to a qualified mechanic.
The Following 2 Users Say Thank You to Lantanafrs2 For This Useful Post:
brzcui (03-21-2019), Tcoat (03-21-2019)
Broken Sun Visor feldy Issues | Warranty | Recalls / TSB 99 10-10-2022 10:33 PM
Cat broken apart Frank the Tank Engine, Exhaust, Transmission 3 10-23-2015 02:18 PM
My car got BROKEN into. Hiros86 Northern California 25 02-25-2014 11:33 AM
Still not broken in Drftfan Scion FR-S / Toyota 86 GT86 General Forum 38 06-13-2013 07:51 PM
Broken into sharris721 BRZ First-Gen (2012+) — General Topics 42 04-28-2013 12:22 PM
