Old 03-20-2019, 09:08 AM   #15
Originally Posted by Mr.ac View Post
Only if you do the same to mine *cough* I mean it would be odd chances both out cars where to spontaneously combust.
Good thing for full coverage insurance right *wink, wink*
FRS/BRZs spontaneously combust across the continent.
Today at precisely 10:02am thousands of cars all ignited at the same time. All were 2013 models within a specific VIN range. Up to date information indicates that the largest outbreak appears to be in California where a recent recall is mandatory.
Mr.ac (03-20-2019), why? (03-20-2019)
Old 03-20-2019, 09:22 AM   #16
venturaII
Only users lose drugs.
venturaII's Avatar
Drives: All the time
I'm holding off with mine for now as well...at least, until there's either a change to the bulletin to somehow make sure the the techs are more careful on reassembly, or changing how the actual procedure is done to make it more foolproof. And based on other interesting stuff I've seen in these threads, I think I'm also going to pop the oil pan off and pull the pickup tube and take a look at the screen...
"To know a thing well, know it's limits. Only when pushed beyond its tolerances will true nature be seen." Amtal Rule
venturaII is offline   Reply With Quote
The Following User Says Thank You to venturaII For This Useful Post:
Tcoat (03-20-2019)
Old 03-20-2019, 09:37 AM   #17
If I were affected I would not be having it done even if there hadn't been the initial rash of post repair failures. The recall does not expire so if a spring fails 5 years from now then it will be fixed. If there had been a huge failure rate prior to the recall my decision would have been different but it is just simply to intrusive a task to do because 100 out of 400,000 vehicles had a failure.
Summerwolf (03-20-2019), Teseo (03-20-2019), why? (03-20-2019)
Old 03-20-2019, 11:03 AM   #18
venturaII
venturaII's Avatar
My only worry with that plan is that if I do end up with a valve spring failure and subsequent engine damage, that Toyota corporate will attempt to force me to pay since they have record of me deferring the work once already... My local Toyota dealer was initially very aggressive about getting in touch with owners to have this work done; I deferred the work a few weeks because of some other scheduling conflicts, and then by the time they contacted me again, the whole repair failure rate issue was starting to be known. I've been ignoring their calls since then.
The recall is specifically to replace the bad parts. Repair of engine damage associated with the part's failure would be a warranty issue, not recall work. They could make my life miserable by denying warranty coverage of the rest of the repair work needed from a valve spring failure if they can show I elected not to have the bad part replaced prior to failure.. Manufacturers can and are ****s like that, on a regular basis..
Old 03-20-2019, 11:14 AM   #19
Had I not already had it done prior to a lot of these failures showing up, this is what I would be doing at this point as well. As it is I'm tempted to take it in to my mechanic and have him drop the oil pan to check the screen.
Old 03-20-2019, 11:19 AM   #20
ybotspawn
ybotspawn's Avatar
Drives: 13 Subaru BRZ
They seem to be good at making everyones life hell after they broke the motor... What makes you think that plan is much better
ybotspawn is offline   Reply With Quote
Old 03-20-2019, 11:26 AM   #21
Scenic Driver
Drives: 13 Subaru BRZ, 02 Audi TTQ
Mine is one of the recalled cars and I feel the same way.
Scenic Driver is offline   Reply With Quote
Old 03-20-2019, 11:34 AM   #22
I disagree with the comment that they are making "everyone's" situation hell. With the very limited data we have on the post repair failures there are two people they have outright refused to cover the repairs. There are 10 where the repairs have been done without a fight. The other 15 or so either have not contacted the dealer yet or the case is in review. The fear that no dealer will cover it is unwarranted. Of course we pay attention to those where they were refused but at this point they are the minority not "everyone".
Dadhawk (03-20-2019), Summerwolf (03-20-2019), Ultramaroon (03-21-2019)
Old 03-20-2019, 11:45 AM   #23
ybotspawn
ybotspawn's Avatar
You're right, its wrong to use the term everyones. But the previous poster is worried about his motor being blown, due to not doing the recall, and toyota failing to honor their warranty. Seems to me if he has concerns about his local dealership not honoring the terms of the warranty its reasonable to assume he doubts their competence in doing the recall in the first place.
The Following User Says Thank You to ybotspawn For This Useful Post:
Tcoat (03-20-2019)
Old 03-20-2019, 11:54 AM   #24
Teseo
Drives: frs
0.025% fail rate...
I will leave my car alone and stick with regular maintenance
Old 03-20-2019, 11:56 AM   #25
fang_gt86
FR Noob
fang_gt86's Avatar
I'm keeping mine "unfixed". There are plenty of used motors that I can easily drop it in if this supposed "ticking time bomb" should go off.
"I'm having too much fun to care about horsepower" - Unknown
6MT FR-S Whiteout:OFT- OTS V2 Stage 2 (93oct & E85), Tomei UEL, Invidia OP, JDL UltraQuiet FP, Ark Grip catback, GS hood struts, Perrin Inlet & K&N drop-in
fang_gt86 is offline   Reply With Quote
Old 03-20-2019, 12:02 PM   #26
See that is just it. His dealer may be totally competent but he is concerned by the horror stories that appear to be the majority. They are not. Yes, it would completely and totally suck to have the work done and be on the failure list but with what we know so far that risk is small. Sort of a damned if you do and damned if you don't scenario.
When I said I would not have it done it was not through fear of them screwing it up. In fact I said that in other threads well before they started the recall. I just do not feel that the original concern warranted a recall in the first place so why mess with things?
Dadhawk (03-20-2019), humfrz (03-20-2019), why? (03-20-2019), ybotspawn (03-20-2019)
Old 03-20-2019, 12:03 PM   #27
YamahaR86
JDM Vaping Stance Nation
YamahaR86's Avatar
Drives: 2013 White
I think I got lucky as well. My dealership says he has his "top tech" to work on mine and they were only doing 1 recall a week.
Got mine done a month ago and about 2k miles, with 1 Autocross session a week ago.
I'm still going to install a fire extinguisher after I fix the stripped seat bolt.
Clueless
YamahaR86 is offline   Reply With Quote
The Following User Says Thank You to YamahaR86 For This Useful Post:
Tcoat (03-20-2019)
Old 03-20-2019, 12:14 PM   #28
bfrank1972
Drives: 2013 FR-S Argento
Hmmm - I see what you're saying regarding heightened fear due to only seeing posts from people who have problems (vs. people who do not), but you also have to consider this forum is a very small % of the overall FR-S/BRZ/86 owners. And out of that small % of active posters, there are a pretty high number of people with issues.
I.E. yes there could be a large number of success stories out there we're not hearing, but I'd bet there's a larger number of fail stories we're not even hearing about either.
And it's not generalized issues - it's exactly the same issue, every time. Rod knock from oil starvation, being consistently tied to mis-application of sealant (whether it be incorrect bead placement, overuse, or just not letting it cure). And strongly correlated to Toyota, who just doesn't have the experience with putting Subaru boxer engines together like experienced Subaru mechanics.
There could be a large # of success stories, but based on this forum sample, I feel there's a solid chance of my engine going south if I took it to my dealer - solid chance meaning more than I'm willing to risk at the moment.
I'd rather 'fight the fight' with a dealer to fix my motor post valve spring failure rather than 'fight the fight' after a dealer gums up my oil passages. JMHO
bfrank1972 is offline   Reply With Quote
The Following 2 Users Say Thank You to bfrank1972 For This Useful Post:
Tcoat (03-20-2019), venturaII (03-20-2019)
Possible recall on the 86 regarding valve spring tanner CANADA 84 11-28-2019 10:32 PM
Valve spring recall meadowz06 Issues | Warranty | Recalls / TSB 115 06-09-2019 12:38 AM
BRZ Valve Spring Recall mrhemi Issues | Warranty | Recalls / TSB 6 03-01-2019 04:35 PM
FR-S Valve Spring safety recall Ħɞ|| Hypnocracy Scion FR-S / Toyota 86 GT86 General Forum 65 02-27-2019 12:53 AM
Valve Spring Recall venturaII New England 13 02-25-2019 08:41 PM
