Old 02-05-2019, 12:38 AM   #15
Ultramaroon
not playing cards
Ultramaroon's Avatar
Wait, is that bad?
Not for yours it isn't.
Spuds (02-07-2019)
Old 02-05-2019, 12:40 AM   #16
Sapphireho
Famous Potatoes
Sapphireho's Avatar
Drives: '15 ultramarine
Thank God.
Old 02-06-2019, 11:00 AM   #17
BellaItalia
BellaItalia's Avatar
Drives: 2017 860 Solar-stick
Originally Posted by jrb363 View Post
I redline it a couple half dozen times in the driveway when it snows to get it warm faster.
that's fun to do in the garage, with the door closed, so it kills all the plants the wife brought in for the winter hahahahaha
BellaItalia is offline   Reply With Quote
Old 02-06-2019, 04:55 PM   #18
86MLR
86MLR's Avatar
I use one of these, helps bring oil temps up much quicker from cold.
Best investment for a street car.
When my oil is 90°C it's time for thrashing.
Many many motors have died because they were leaned on hard before their oil was at temp.
http://www.ft86club.com/forums/showthread.php?t=133311
I'm only here for the biscuits
The Following User Says Thank You to 86MLR For This Useful Post:
MCTeeJ (02-07-2019)
Old 02-06-2019, 05:08 PM   #19
Tokay444
Originally Posted by 8RZ View Post
Your water temp is a more important factor than your oil temp when it comes to revving it out. As long as your coolant is at normal operating temp (180-220 deg F) you're fine, which usually happens after just a few miles depending on ambient temp.
Negative. Oil temp is far more important than water temp. That being said, they are generally very close to the exact same until you really start extreme usage.
The Following 3 Users Say Thank You to Tokay444 For This Useful Post:
8RZ (02-07-2019), DaBoBo21 (02-07-2019), ermax (02-06-2019)
Old 02-06-2019, 06:17 PM   #20
ermax
ermax's Avatar
My water temp comes up super fast but oil temp seems to take forever to come up in this car. It's torture. But then once it's up there and you drive it hard it skyrockets. Hahaha
Old 02-06-2019, 06:43 PM   #21
mav1178
mav1178's Avatar
Drives: 2005 Toyota Camry
Sounds about right. 10 minutes or so to get to temp and there is often a delta of 20+C right after the thermostat opens.
http://www.ft86club.com/forums/showp...46&postcount=7
When I'm at the track and stuck with a cold engine or long periods of idling, I use the first lap out on track as an opportunity to warm up the fluids, but at least I'm not starting from a completely cold engine situation.
-alex
Old 02-07-2019, 08:14 AM   #22
alex87f
Meow
alex87f's Avatar
Drives: GT86 (now sold)
So based on what I'm reading, it's safe to really have a go at the engine (read: redline it ) as soon as the oil is over 80°C (176°F)?
Obviously that's provided the rest of the car is up to temp as well.
alex87f is offline   Reply With Quote
Old 02-07-2019, 08:40 AM   #23
SUB-FT86
86 Member
Drives: 2013 Toyota 86 2.0T (Asphalt)
I always wait till 180F oil temp.
SUB-FT86 is offline   Reply With Quote
Old 02-07-2019, 09:00 AM   #24
8RZ
The Gunshine State
8RZ's Avatar
Drives: '14 BRZ Limited
I'm just saying not many cars come with an oil temp gauge (none of the 15 cars I've owned) so the closest thing we have to base it on is water temp.
Current DD: M235i
8RZ is offline   Reply With Quote
Old 02-07-2019, 09:25 AM   #25
ermax
ermax's Avatar
Only that isn't what you said. You specifically said "Your water temp is a more important factor than your oil temp". This leads someone to believe that as soon as the water temp gauge reaches its normal resting place you are good to go when in reality the oil temp trails WAY behind. Water doesn't lubricate the engine, oil does.
The Following 3 Users Say Thank You to ermax For This Useful Post:
8RZ (02-07-2019), Dave-ROR (02-08-2019), Tokay444 (02-07-2019)
Old 02-07-2019, 09:31 AM   #26
Trueweltall
Trueweltall's Avatar
Drives: 2016 Subaru BRZ
When my water is up to around ~190f the oil temp is anywhere from 140-160f and this is in Florida winter. It takes at least 6-10 miles before the oil is just getting up to around 200 degrees.
Please cite some sources for this. I have never once heard or seen of this happening(to a street car), just a lot of internet parroting.
Trueweltall is offline   Reply With Quote
Old 02-07-2019, 10:59 AM   #27
Can't cite any "sources" but can say it can and does happen up here. I think part of it is the definition of "cold". Your Florida "cold" start temperatures are our mid summer ones.When your motor oil is at sub zero temperatures (as the OP mentioned) even the multigrade stuff is thick. You lay on that engine too soon you WILL cause damage. Will it blow up that very second? Probably not but that does not mean you are not create abnormal wear. At the low temperatures we see the coolant can be up to temperature well before the oil is even half way. The best thing to do is wait and let everything warm up before flooring it. Shouldn't be a big deal to anybody to just wait a few minutes before bouncing off the limiter.
Spuds (02-07-2019)
Old 02-07-2019, 11:21 AM   #28
Spuds
The Dictater
Spuds's Avatar
Drives: '13 Red Scion FRS
Bare minimum is about 160F for me. I like to wait till 180F, (or try to get it to 180F) but sometimes I get to the on-ramp a bit too quickly and have too little self-control...
The Following User Says Thank You to Spuds For This Useful Post:
ermax (02-07-2019)
oil, temperature
FS: BNIB Prosport Guages (Water Temp / Exhaust Gas Temp) AtlasMick Interior Parts (Incl. Lighting) 2 03-31-2015 06:47 PM
STRI DSD SLM II Gauges (boost/oil temp/oil press/water temp/egt) BNIB ziptiedae86 Interior Parts (Incl. Lighting) 0 10-30-2013 12:50 AM
2.5L with lower revs/more torque, or 2.0L with higher revs? Superhatch Engine, Exhaust, Transmission 124 08-28-2013 01:20 PM
