Old 02-04-2019, 07:43 AM   #15
dodj
Drives: Rallye Blue BRZ
Originally Posted by FRSBRZGT86FAN View Post
Electricity does like the cold but that's at liquid nitrogen temps and has more to do with conductivity and lowering resistance.
You have to be sure your battery is outputting enough CCAs. Also you might need more than just a block heater, maybe adding a oil pan heating pad would help. Also test the block heater as well to ensure it's actually properly heating the coolant.
If you weren't getting spark I'm pretty sure you'd throw a code. I'd check the fuel pressure at those temps.
I tend to believe my battery is doing it's job. It keeps on cranking. But, to test, if the cold comes back, I will parallel another battery and see if that makes a difference.
As for fuel pressure
Is there a fitting on the BRZ fuel line to check fuel pressure?
Oh, ya...I didn't hit a deer....well not with the BRZ. Really screwed up an Altima though..lol
dodj is offline   Reply With Quote
Old 02-06-2019, 12:46 AM   #16
FRSBRZGT86FAN
FRSBRZGT86FAN's Avatar
Fuel pressure would be my last test before checking the block heater and testing the batteries, and then adding an additional oil pan heater if needed. If it's the stock panasonic battery I'm in the group that had nothing but issues with it in sub 30 degree temps and ditched it for an AGM with 660 CCAs. The only way to be sure is to have a load tester handy, I bought one off amazon and have it in my tool set and it's super useful on all my cars:
https://www.amazon.com/Schumacher-BT...ry+load+tester
When I bought the schumacher one it was only $30 but it's been really useful for working on friends cars, and is more accurate then the multimeter 13-14.5 volt trick which doesn't really work on modern cars with voltage regulation like the later gen 86.
Checking fuel pressure is pretty involved sadly:
http://www.ft86club.com/forums/showthread.php?t=121645
https://demos.starbase7.net/t3Portal...00Q3M04GX.html
Easiest bet is to do your trick and make sure you're running it in parallel just like you'd jump start a car to effectively double the CCAs because that's what you have on hand and should negate any amperage issues .
Old 02-11-2019, 08:36 AM   #17
dodj
Yes I replaced my original Panasonic battery with an AGM after two and a half years. The AGM is an 800cca piece.
It got to -26*C last night and it started just fine.....
Think I'll make up a cord to use a clip on, and check the block heater current draw.
I also picked up a CTEK MUS4.3 Test and Charge. I'll try it's algorithms on the start/charge system and see what it says.
Old 02-12-2019, 01:11 PM   #18
guybo
Huge E85 fan!
guybo's Avatar
Drives: 2016 Scion FRS
I'd like to hear a sound clip of the car trying to start. That'll give us an idea of whether it's fire or compression that's lacking.
BREATHE IN THAT COLD AIR! AMAZING DEALS ON COLD AIR INTAKES AT EAST END RACESHOP! eastendraceshop Engine, Exhaust, Bolt-Ons 50 09-24-2019 06:45 PM
Subaru BRZ With e85 Flex Fuel Kit Not Starting In Cold morswestford Engine, Exhaust, Transmission 52 05-03-2017 06:50 PM
How cold is too cold to seal and wax? Jertronic Cosmetic Maintenance (Wash, Wax, Detailing, Body Repairs) 3 11-01-2013 11:20 AM
White Smoke cold start up in Cold Weather (turbo cars) whitefrs Forced Induction 17 09-25-2013 05:05 PM
Starting it off e10rice Mid-Atlantic 93 03-26-2012 03:16 PM
