Old 01-13-2019, 08:32 PM   #15
Ultramaroon
not playing cards
Ultramaroon's Avatar
Yeah that's overcharge.
Old 01-14-2019, 04:07 AM   #16
guybo
Huge E85 fan!
guybo's Avatar
Drives: 2016 Scion FRS
Originally Posted by RZNT4R View Post
What is a "full charging system check"?
A voltmeter will show voltage, but you need to see ripple, loaded voltage and amperage too. He needs a real tester, not a voltmeter.
The Following User Says Thank You to guybo For This Useful Post:
Ultramaroon (01-14-2019)
Old 01-14-2019, 06:22 AM   #17
RZNT4R
Professional Mechanic
Drives: 2017 86 6MT Oceanic
I was asking because voltage and amperage are the only metric to test an alternator by.
"Loaded" is the only way to test an alternator, as sticking multimeter probes on the battery terminals at idle with all accessories off isn't an alternator test. He can easily do it all with a cheap meter. VAC on the alt case and B+ terminal will show ripple better than the usual "charging system tester" with a ripple/diode indicator. But a leaking battery isn't likely to be a ripple issue. You don't need an amp clam, all accessories and lights on and a 1500 RPM idle is all the load you need, observing an output voltage that remains comfortably around 14V is all you need to know to confirm amperage output.
What we want to know here however is if the system is over charging, and we'll find that out by turning all the accessories off and having the engine turning at usual driving speed. It's OK to do this parked, and an overcharging alternator will simply show up as gradually increasing voltage following engine RPM, steadily increasing over 15 and possibly over 16V.
Old 01-14-2019, 10:53 AM   #18
ka-t_240
Is your car tracked or auto-crossed?
Mine was always fine durint street use, but would notice it to be a tish wet after tracking/autox events.
ka-t_240 is offline   Reply With Quote
Old 01-14-2019, 12:12 PM   #19
rice_classic
rice_classic's Avatar
Drives: Nevermorange FRS
Possibly (likely) culprit is a faulty voltage regulator. A fellow racer had his battery spew it's guts all over his engine bay twice until we finally put a volt meter on the terminals and revved the engine a bit. The Voltage regulator should keep the voltage at a constant despite RPM like RZNT4R mentioned. However his would climb with RPM - 12v @ idle and I believe it jumped to 40v or more over 3000rpm.
On his car the voltage regulator is inside the Alternator (not sure on our cars) so swapping the alternator, along with cleaning the engine bay with baking soda, and we were back on track.
PRO86 | WTCC | STL
Old 01-14-2019, 12:59 PM   #20
slizoth
slizoth's Avatar
Drives: 2013 WRB Subaru BRZ
I installed a Shorai battery in September of 2014 and I've had no major issues. I have noticed the battery doesn't like cold (sub 40s F.) but it still starts first try.
There was an old thread (locked now) where a forum member was selling custom battery trays to accommodate it and I picked one up. Definitely recommend running Shorai, I've been very happy with their products.
slizoth is offline   Reply With Quote
Old 01-14-2019, 02:00 PM   #21
ka-t_240
I removed the factory style and went to a 11lb Braille unit. Made my own install kit as I wasn't going to pay 100ish for the FT86SF unit.
Old 01-14-2019, 03:09 PM   #22
slizoth
slizoth's Avatar
Nice, any issues? When it gets cold I think the longest I can go without driving my car is about 8 days. However I picked up the Shorai charging unit so if it goes longer I just hook that up.
Old 01-14-2019, 03:16 PM   #23
ka-t_240
I have a CTEK charger wired into the car, its not a daily and is stored in winter.
I had a little trouble starting the last autocross I was at when I took it off the trailer and in the morning for the 2nd day. It was 34 degrees and I am on a E85 OFT map with no adjustments to cold start tables. I did have some cold start issues on really cold mornings with previous battery as well.
The Following User Says Thank You to ka-t_240 For This Useful Post:
slizoth (01-18-2019)
Old 02-14-2021, 11:16 PM   #24
Delmar
Drives: 2013, Subaru BRZ
Hi, sorry for resurrecting a kinda old thread... But has anyone found the issue yet?
I've had the battery of my 2013 BRZ leak twice within the passed 3 months. Had the first battery replaced under warrany after it leaked during autocross and when I had it checked with those fancy tools you clamp onto the battery, I was told the charging system was fine...
The replacement I got leaked 3 months after out the vent hole during a trackday. (Maintenance free battery)
While on the track I plugged in an obd2 reader and was monitoring voltage during a track and if I remember correctly, it never went above 14.5 or (14.2 I think) which is supposedly normal. Had my eyes on the track.
It seems to only happen at high rpm high load scenarios as it didn't leak on the way home from the track, but would always leak when I would go out for a lap on the track... I taped a piece of tissue over the vent hole to confirm that the battery was leaking out of there.
Now I'm thinking if this is still an issue with the alternator even after having it checked and nothing is wrong, OR it is the sensor with the plug on the Negative battery terminal as it is supposed to monitor the battery (?). I'm not completely sure, but I'm stumped right now. not sure also if it's the brand of battery I'm using or if I got a bad battery? But c'mon 2x within 3 months!?! 😪
It's the second time I will be having to clean and paint my engine bay because of the battery fluids leaking and rusting out the car :/
Anyone have an idea what may be wrong?
Delmar is offline   Reply With Quote
Memory Saver For Battery Replacement DaJo BRZ First-Gen (2012+) — General Topics 7 05-29-2018 08:47 PM
Lithium Ion Battery Replacement Benzin Mechanical Maintenance (Oil, Fluids, Break-In, Servicing) 15 06-06-2017 06:05 PM
Replacement Battery jasonojordan Mechanical Maintenance (Oil, Fluids, Break-In, Servicing) 17 01-24-2017 06:15 PM
Car Audio Battery Replacement brzstormtrooper Electronics | Audio | NAV | Infotainment 0 03-23-2016 07:38 AM
Replacement Battery slizoth Mechanical Maintenance (Oil, Fluids, Break-In, Servicing) 3 02-09-2014 02:04 PM
