Old 12-30-2018, 06:21 PM   #15
dhuang
Cannonball Record Guy
dhuang's Avatar
Drives: Series.Yellow, 4C, Fit
Got my '17 battery replaced under warranty @ 29k miles last month -- turns out it had a bad cell.
2017 Series.Yellow
2013 Whiteout
VINwiki - Changing Automotive History
dhuang is offline   Reply With Quote
Old 12-31-2018, 12:59 AM   #16
nico_rsx
Drives: BRZ 2017 Pure Red, MT
Originally Posted by RZNT4R View Post
In fact one of the things I'm curious about is how the revised charging system on the '17 deals with the cold canadian winter and my short drive cycle and rather intensive electrical loads: I've got the auto lights set so that they turn on at the slightest dark, and front and rear defrost pretty much always going. So far so good.
I think in the winter the charging system behave the same as the 13-16'. If you check the voltage gauge (if you have the LCD screen), the voltage doesn't drop to 12.5V like it does in the summer. Below 7 or 8 degrees Celcius it stays around 14.5V all the time.
nico_rsx is offline   Reply With Quote
Old 12-31-2018, 03:16 PM   #17
humfrz
Just another data point. Yesterday, I went out in the garage to fire up my 2013 FR-S, with the OEM battery, after it had sat garaged unstarted for 11 days. It was about 50 degrees F in my garage.
Although it wasn't too happy about being waken up, it turned over the engine well enough to fire.
humfrz
Toyota replaced battery with group 26R?! Mikeez Electronics | Audio | NAV | Infotainment 6 02-06-2017 10:27 AM
Key fob battery died. Can I manually unlock without alarm going off? Stu L Tissimus Electronics | Audio | NAV | Infotainment 3 05-28-2016 06:06 PM
Battery Died--is my tune ok? TeutonicShift89 Software Tuning 21 05-09-2016 12:25 AM
Help! Battery died, charged battery now getting all sorts of error codes! jermyzy Issues | Warranty | Recalls / TSB 12 11-25-2015 12:35 PM
BRZ Battery died, when I tried starting it it made a terrible noise. cmspooner Engine, Exhaust, Transmission 95 06-17-2014 11:08 AM
