Old 01-04-2019, 07:13 AM   #15
B.Pod
Drives: White Toyota GT86 '12
Hello Pat,
Did you manage to find your problem ?
Could you tell me if your feeling with your car is comparable to this old video ?
[ame="https://www.youtube.com/watch?v=Ddl4nDEzQOM"]https://www.youtube.com/watch?v=Ddl4nDEzQOM[/ame]
B.Pod is offline   Reply With Quote
Old 01-04-2019, 11:58 AM   #16
Pat
Pat's Avatar
Drives: 2023 BRZ
Hey B.Pod, thanks for checking in with me. I did not manage to find the problem yet. That said, I haven't experienced the problem since soon after I last posted. I had a friend log it while I was driving, but I could not get the car to stumble as it had previously. I wonder if it has anything to do with the cooler temperatures here now.
Some people here think it is an issue with my coilpack(s). If that were the case, might the problem go away when ambient or intake temperatures are colder?
The video posted above is similar, or maybe the same, type of behavior I have seen in my car. That said, I see it in all gears, not just first. And not just at full throttle.
Old 01-04-2019, 01:57 PM   #17
OwlDance
Drives: Halo 86, '19
Originally Posted by Pat View Post
Recently my BRZ has begun to stumble at RPMs below about 3,500. The drivetrain is completely stock and never been modified. At first I only noticed it at throttle tip-in. However, over the last few months it has become more frequent, regardless of throttle position. In fact, this morning on the highway in 6th gear at 62 mph I floored it and it seemed to stumble two or three times per second for maybe three or four seconds. I have never seen a single CEL in this car, and the car has always been maintained impeccably well. The spark plugs have 15,000 miles on them. I always use gas from good stations that see a lot of turnover. Primarily that is Shell and Conoco.
Does anyone have any idea what might be causing this? At first it wasn't really a big deal, but it slowly seems to be happening more often in a wider variety of conditions.
Thanks!
Couple things; by stumble at throttle tip in, do you mean that the car feels shuddery when just gently opening onto the throttle? Does it happen when you lift off the throttle as well?
Regarding the bolded text, does it look like this?
[ame]https://www.youtube.com/watch?v=3AU035Pvkp0[/ame]
6th gear at 62mph sounds like really low RPMs on either MT and AT gearing. If I suddenly floor it at low RPMs (sub 2.5k) my car almost "shudders" and the tachometer "jolts" around briefly but only at the initial moment of acceleration, not later on like in the video.
OwlDance is offline   Reply With Quote
Old 01-04-2019, 03:29 PM   #18
Pat
Pat's Avatar
Drives: 2023 BRZ
It is not happen just when gently opening the throttle. It can happen at any open throttle position. It never happens when closing the throttle. Only right when I open it some amount.
Yes, my car look like what happens in that video.
Old 01-04-2019, 06:42 PM   #19
OwlDance
Check out this thread, then. http://www.ft86club.com/forums/showthread.php?t=66620
Sounds like a DI failure?
Old 01-04-2019, 08:29 PM   #20
Pat
Pat's Avatar
Drives: 2023 BRZ
Possible. Unlikely.
Old 01-04-2019, 09:15 PM   #21
Lantanafrs2
Drives: 2013 frs red
Seems so minor. I wouldn't worry about it. Check all intake hose clamps and clean maf sensor.
Old 01-04-2019, 09:30 PM   #22
Ultramaroon
not playing cards
Ultramaroon's Avatar
Pat, post those logs as a baseline. They are valuable.
Do you know how to https://datazap.me/ ?
Old 01-04-2019, 09:38 PM   #23
Pat
Pat's Avatar
Drives: 2023 BRZ
Thanks, Ultramaroon. I know nothing about logging data. @fika84 did it for me. Maybe he can chime in here.
Old 01-04-2019, 11:43 PM   #24
Mr_Eyo
Drives: 2017 Toyota 86
Transient ignition retard is aggressive in the stock ECU and OFT OTS. I think throttle tip in might be able to trigger it despite enrichment, not sure though.
Mr_Eyo is offline   Reply With Quote
Old 01-05-2019, 12:14 AM   #25
Ultramaroon
not playing cards
Good friends are cool. Or is it the other way around?
It would be interesting to see if something is operating in a borderline manner. Worth a shot.
Old 01-06-2019, 11:01 AM   #26
guybo
Huge E85 fan!
guybo's Avatar
Drives: 2016 Scion FRS
A log of fuel trims would be helpful
Old 01-06-2019, 11:51 AM   #27
22R
22R
22R's Avatar
Drives: 2012 Camry SE 2017 Toyota 86
perhaps some bad gas that has gone ???
22R
22R is offline   Reply With Quote
The Following User Says Thank You to 22R For This Useful Post:
Lantanafrs2 (01-06-2019)
Old 01-06-2019, 12:18 PM   #28
Pat
Pat's Avatar
Drives: 2023 BRZ
22R
Possible, but unlikely. It lasted for months through many tankfulls from many different gas stations.
Engine running rich, stumbling, rough idle after motor swap toyubie Engine, Exhaust, Transmission 19 04-07-2018 01:11 PM
Completely stock 2016 FR-S, what would you do first? Derek J Scion FR-S / Toyota 86 GT86 General Forum 141 07-08-2017 05:27 PM
P2096, Completely stock. cbell7492 Issues | Warranty | Recalls / TSB 6 01-31-2016 11:10 PM
Tire PSI for completely stock autocross? bladesamurai Tracking / Autocross / HPDE / Drifting 16 06-11-2013 11:07 AM
Completely stock BRZ / FR-S needed AMR Engine, Exhaust, Transmission 11 04-03-2013 11:01 AM
