#15 |
Drives: 17 86
#16 | |
My 2016 Build thread TRD Exhaust with custom quad tips, TRD Lowering Springs,TRD Quick shifter,LED;DRL, Projectors, and turn signals. Re-badge, 86 Nanny, WinmaxW2 Pads, K&N Drop In, Antenna delete |
#17 |
Drives: 2015 FR-S
If you're such a hotshot battery engineer then why during a discharge of electricity does the chemical on the anode release electrons to the negative terminal and ions in the electrolyte through an oxidation reaction?
#18 | |
Drives: GTS 86 auto
GTS86 Auto (Australia)
#20 | |
Thupercharged
2013 FRS
Vortech V3 11psi Revworks UEL - PLM Overpipe - MOTIV catted frontpipe - Invidia Q300 2019 Series.Grey STI - Stage1+ SF |
#21 | |
humfrz |
#22 | |
| The Following 2 Users Say Thank You to strat61caster For This Useful Post: | Impureclient (11-01-2018), Ultramaroon (10-31-2018) |
#23 |
Drives: '16 FR-S RS2 MT, '06 xA Polar MT
Unless things have changed with Panasonic batteries the last 5-6 years, then I'm not aware of it. My Panasonic in my xA lasted 9.5 years, and finally died towards the end of 2016. At that point, I had about 85k miles on the car. About a year previous to replacing it (got a Optima Red top), I had left on the dome light over one late Fall night (so it was on a solid 12 hours), so that drastically drained the battery. I was able to revive it(charged it over 8-10 hours), and it lasted about 12-14 months past that point.
Math is like Love, simple idea at first that quickly gets complicated
| The Following User Says Thank You to Adam_L For This Useful Post: | Leonardo (11-01-2018) |
#24 | |
Yea things have changed, the panasonic battery in our cars is trash, and is under powered for the car honestly. Well known to become a problem on the BR-Zs with more active electronics when the car is off at 4 years. On my FR-S I've already replaced it, on my friends 2014 it got replaced after only 3 years. It's simply not the right size for our cars and the quality is crap.
| The Following User Says Thank You to FRSBRZGT86FAN For This Useful Post: | Leonardo (11-01-2018) |
#25 |
not playing cards
Still on my original battery. I have, mostly through my past experience servicing home electronics, become a die hard fan of Panasonic's approach to design and documentation, no matter what their product. I was truly excited to see the label on the battery. When the time comes, I'll replace it with the same.
#26 |
Gotcha.
OK, the other point I wanted to make was (it's common knowledge, but in case others didn't know) : batteries lifespan decreases when outside ambient temperatures are at their extremes (below freezing , and above say 90 F). If you live where the temps are more temperate ( 40-80 degrees night/day year round) you're good to go. If you live where it snows , or desert (90+ degrees) several days per year then your battery will live a short life. I'd think (believe) colder temperatures do more damage to batteries, then hotter temps (both aren't good). This winter, when temps are going to be under 32 degrees at night for 7-10 straight days, I'm going to give my battery a trickle charge for 8-12 hours at least once maybe twice this winter
| The Following User Says Thank You to Adam_L For This Useful Post: | notout86 (11-01-2018) |
#27 |
6/22/12-2/6/24
I got rid of the OE one mostly for piece of mind. Running extra electronics and wires here and there. Cold crank being a tiny bit longer. I figured it wouldn't hurt to bump up the juices. I think the cold crank helped and it helped reduce the ignition coil code for me. I got the code a lot less frequently.
| Dash Cam Knowledge | SmireyFase | Electronics | Audio | NAV | Infotainment | 19 | 09-04-2016 10:35 AM |
| Someone who has knowledge about the stock touchscreen HU | IDFWU 420 | Electronics | Audio | NAV | Infotainment | 11 | 01-27-2015 09:07 PM |
| I need a plumbers knowledge | whaap | Off-Topic Lounge [WARNING: NO POLITICS] | 7 | 11-04-2013 04:28 PM |
| Anyone go from a 06-11 Civic Si to an FR-S/BRZ? Opinions/ Knowledge needed! | jbsali | Other Vehicles & General Automotive Discussions | 2 | 01-15-2013 01:41 AM |
| Some Scion Knowledge and History... | Jay Grey | Scion FR-S / Toyota 86 GT86 General Forum | 130 | 06-08-2011 12:08 PM |
