Old 10-15-2018, 06:18 PM   #15
Leonardo
Country Boy 4 Life
Leonardo's Avatar
[QUOTE=Sapphireho;3144632]via Imgflip Meme GeneratorQUOTE]
FIFY
I LIKE TIRES!
The Following 3 Users Say Thank You to Leonardo For This Useful Post:
Adam_L (10-15-2018), Sapphireho (10-15-2018), Spuds (10-16-2018)
Old 10-15-2018, 09:57 PM   #16
Adam_L
Adam_L's Avatar
Drives: '16 FR-S RS2 MT, '06 xA Polar MT
Originally Posted by Grady View Post
Yes but you can gut the cat on your stock header and get 90% of the power. That puts you in the power range of cheap headers at no cost. That makes a cheap header the most expensive.
Not in all states. CA requires at cat.
Originally Posted by BlueWhelan View Post
That depends on how strict the inspection is. Are they doing a visual and using a sniffer? You might pass that if they don't care look under at the header. In California they just hook you up to OBDII and run your monitors. If they all run and no faults or codes show up, you're good. If you have a header and a tune that eliminates the codes, you should be ok.
**the key word you used is "If".
Math is like Love, simple idea at first that quickly gets complicated
Adam_L is offline   Reply With Quote
Old 10-15-2018, 10:11 PM   #17
norcalpb
norcalpb's Avatar
Do you have a heatshield for the K&N cone filter? Or is it sitting front and center of the engine bay? I'm afraid you may have concocted yourself a hot air intake.
The fuel pump you bought is unnecessary as others have stated. This can however be a nice setup if you decide to but a smog legal forced induction kit on.
As for mods, I would recommend Subaru underbody panels for less drag on the car if adding more power will void smog, and a steering rack brace of your choice. New shocks would be nice too. I have the Bilstein B6. Leagues better than the stock 13 suspension.
The Following User Says Thank You to norcalpb For This Useful Post:
Adam_L (10-15-2018)
Old 10-15-2018, 11:47 PM   #18
Adam_L
Adam_L's Avatar
On the steering rack brace, is that mainly if you auto-x your car ? Will a DD benefit any ?
Old 10-16-2018, 12:03 AM   #19
StraightOuttaCanadaEh
Wes
I just installed the whiteline rear subframe bushings and I feel those would fit right in with the rest of your mods.
Instagram: @gt86ws
Old 10-16-2018, 01:26 AM   #20
norcalpb
norcalpb's Avatar
No it’s for all kinds of driving. I personally love them just cruising around town.
Old 10-17-2018, 10:18 AM   #21
jeconti
Drives: '13 BRZ Limited
I do have the heat shield for that intake.
Also, I don't live in CA, I live in RI, and I know from printed law and from seeing a sensor go in my exhaust they test. No laws specific about cats. Knowing that, think I'd still pass?
jeconti is offline   Reply With Quote
Old 10-17-2018, 02:05 PM   #22
norcalpb
norcalpb's Avatar
If they put a sniffer in your exhaust it’s probably measuring for carbon monoxide, which I believe would cause a fail but I’m not 100%.
mods, performance
