Old 08-01-2012, 04:01 PM   #15
SkullWorks
Drives: SSM LT MT BRZ
the stock flywheel isn't a dual mass unit is it?
SkullWorks is offline
Old 08-01-2012, 04:07 PM   #16
epson1
Drives: 2013 BRZ Limited
These clutches are awesome. I ran one in my LS 240 drift car and my bff from Canada, Chris, also runs one on his LS 240. Work great and definitely can wait for this product
epson1 is offline
Old 08-01-2012, 05:28 PM   #17
Don@Accelerated
Don@Accelerated's Avatar
Originally Posted by wu_dot_com View Post
clutch, pressure plate, and flywheel assembly, about 37lbs.
So its a heavy bitch! Told ya so Jeremiah. It feels like it.
Don@Accelerated is offline
Old 08-01-2012, 05:47 PM   #18
wu_dot_com
Drives: accord
dont think so, but Jeremiah can confirm when he gets them in the next day or so.
one think i want to bring up is that excedy is the supplier for the clutch assembly.
i think the clutch is also a heavy hitter.
wu_dot_com is offline
Old 08-01-2012, 05:54 PM   #19
Draco-REX
Corner Junkie
Draco-REX's Avatar
Drives: 13 BRZ, 11 STI, 99 RS
Seeing as how the stock master/slave setup of the stock system feel like it's over boosted (if it were boosted), it must be able to handle a pretty strong pressure plate. If that's so, I wonder if someone's going to make a smaller diameter multi-plate clutch.
Draco-REX is offline
Old 08-01-2012, 06:41 PM   #20
Jeremiah@MPG
Drives: 2003 350z TT
Send a message via AIM to Jeremiah@MPG
You were right Don haha. Now we just need to get a good setup in your BRZ
Exedy has always been a big supplier for many OEM manufactures. They usually have the DK stamp on the pressure plate and disc.
We actually were talking today about doing a 7.25" twin disc. To make this happen, honestly someone will need to be in the 700rwhp range. So, not sure how much need there is for this, but it is on the drawing table for discussion.
Jeremiah@MPG is offline
Old 08-01-2012, 09:30 PM   #21
Draco-REX
Corner Junkie
Draco-REX's Avatar
I was thinking that would get the mass of the clutch closer to the center of the crank shaft, making the assembly easier to spin.
Old 08-03-2012, 12:05 AM   #22
wootwoot
Drives: FRS
What about two models on the flywheel? One light-weight for racing application and another less-light-weight for street/DD?
wootwoot is offline
Old 08-03-2012, 08:08 AM   #23
d1ck
Drives: Black 2013 FRS
I don't think you want to rate your clutch for 300 rwtq, as the rear wheel torque in first gear would be much higher than 300 ft lbs.
d1ck is offline
Old 08-03-2012, 01:45 PM   #24
serialk11r
Drives: '06 AM V8V Coupe
Stupid conventions in the car community made by stupid people, what can you do about it...
serialk11r is offline
Old 08-04-2012, 11:54 AM   #25
Jeremiah@MPG
Post 10 states that we are going to be doing two version of the flywheel. So we already have it in mind
Old 08-04-2012, 12:04 PM   #26
wootwoot
Drives: FRS
Hurry!!!
wootwoot is offline
Old 08-04-2012, 12:21 PM   #27
Jeremiah@MPG
Haha we are working on it as fast we can. We don't want to rush anything though.
-Jeremiah
Old 08-06-2012, 06:04 PM   #28
Jeremiah@MPG
Thanks (Bryan)Wu_dot_com for getting the clutch and flywheel out to me. We received it today. With that being said, we can now start drawing the flywheel. I will keep everyone in the loop with the progress.
Regards,
Jeremiah
Special Deals on Clutch Masters Clutch & Flywheel Combo! KronosPerformance Transmission and Driveline 15 08-25-2012 12:22 PM
Clutch Masters Clutch and Flywheel Kits for FR-S and BRZ available at Redline360 Redline360 Transmission and Driveline 2 07-30-2012 10:01 AM
Clutch Masters Clutch Kits | Island Import Performance IslandImportPerformance Transmission and Driveline 1 07-20-2012 12:06 PM
ATS carbon clutch collaboration model prototype clutch 86 & BRZ kanundrum Engine, Exhaust, Transmission 41 02-27-2012 03:48 PM
