Old 08-06-2018, 04:49 AM   #15
nikitopo
nikitopo's Avatar
Drives: '15 BRZ RA
Originally Posted by alf View Post
if this is a case and engine is protected by ECU against low octane fuels, that's awesome.
Your ECU is protected against low octane fuels, but I wouldn't do often long trips under these conditions.
Old 08-06-2018, 07:29 AM   #16
steve99
Originally Posted by conehead View Post
You don't need a tune. The ECU will pull timing to protect the engine. However, since the engine was actually built for premium, your mileage and performance will suffer. A tune can't fix that.
Guys it true the ecu has timng compensations tiggered by the amount of knock the knock sensors detect but these compensations have limits
This motor is 12.5:1 compression and it needs decient fuel.
The minium recomended octane rating is 91 AKI MON (usa) and 95 RON in the european\australian\asian standard. This is from subaru\toyota
For best performance you need to un 93 or above MON and 98 or above RON fuels
Ive got logs of the stock tunes from peole running on the lower rating fuels ie 91 and 95 and the ecu is getting towards it maxium amount of compensation ie the IAM Advance multiplier as arround 0.2 or 0.3 and it was still getting FLKC knock indications of close to 4 degrees.
The IAM will be 1 when on good fuels and its minium value is 0.
So with 87 in tank its not going to be pretty your just going to get heaps of knock and the ecu wont have any compensation left. And 87 is way below the minimum​ standard recomended by subaru\toyota.
Here is a log from a srock car running stock tune on 95 RON fuel ie the minuim recomended. This wasnt on track this was jist normal road driving
https://datazap.me/u/steve99/south-a...8&solo=2-13-28
The Following 5 Users Say Thank You to steve99 For This Useful Post:
ayau (08-09-2018), FRSBRZGT86FAN (08-09-2018), JohnJuan (08-09-2018), nikitopo (08-06-2018), Ultramaroon (08-08-2018)
Old 08-06-2018, 12:29 PM   #17
bcj
Geo Tyrebighter Esq
bcj's Avatar
Drives: '13 scion fr-s
If you're going that far off the map, you may lose your twin in a pothole.
I'd rent a Suzuki Jimney that can handle the circumstances and is designed to run on low octane fuel.
Maybe a Hilux if you need auxiliary security personnel.
Old 08-06-2018, 09:20 PM   #18
alf
alf's Avatar
This is the point of the trip, sorry cannot reveal details yet. Risk is factored in and I am fully aware I might eject in the middle of the trip.
alf is offline   Reply With Quote
Old 08-06-2018, 09:22 PM   #19
alf
alf's Avatar
What countries do you plan on driving your car through .. ??
no car there for 1000-2000 miles. in fact the roads are limited too.
Old 08-06-2018, 09:24 PM   #20
alf
alf's Avatar
Steve, thanks for more technical insight. This is why I asked for OFT map which would eliminate knocking. For that leg of the trip, power does not matter.
I wonder though, in case I will not be able to get a map, if driving style (never WOT, stay below 4k RPM) would help eliminate some of results of using low grade fuel.
Old 08-06-2018, 09:32 PM   #21
I truly mean what I wrote. Cannot reveal details. Not yet.
alexpham_ (08-18-2018), jonboy99 (08-08-2018), Ultramaroon (08-08-2018)
Old 08-06-2018, 09:38 PM   #22
humfrz
If there are no cars and few roads, why would anybody be selling gas of any kind??
I suggest you have one of these follow you, then it can give you ride back to civilization when your BRZ fails. Oh, don't forget to have this vehicle tow a gasoline trailer.
humfrz
Old 08-06-2018, 09:51 PM   #23
humfrz
If your objective is to destroy your BRZ out in the bush, may I suggest an plan B.
Drive it to Ft Irwin, CA and drive it around for a few thousand miles. Arrange for the post POL to air drop a couple of 5 gallon Gerry cans of gasoline every now and then. Then when your BRZ gives up, call for a CH-47 (Chinook) to extract you and whatever is left of your machine.
humfrz
Old 08-06-2018, 10:10 PM   #24
alf
alf's Avatar
humfrz
A little correction. While the area I will be traveling thru is super sparse, the longest segment of road with no gas stations is 666km long. I troll you not.
By 1000-2000k miles I meant no 91 or better gas. Ppl still live there.
Old 08-06-2018, 10:13 PM   #25
alf
alf's Avatar
If Fiat Panda made it (again it is not a troll), I should be able too. And I do have an advantage being 2 wheel driven (as opposed to 1 wheel for the most of cars). Odds that I will get suck are lower than getting TB in first 50k (s)miles.Which I replace as a preventive maintenance before the trip.
Old 08-06-2018, 10:33 PM   #26
x808drifter
LMGTFY
x808drifter's Avatar
Drives: 13 FRS, 91 Miata
The more I hear, the more it feels like a Top Gear Challenge.
The Following User Says Thank You to x808drifter For This Useful Post:
ajcarson11 (08-13-2018)
Old 08-06-2018, 10:38 PM   #27
Mr.ac
[insert cool phrase here]
Mr.ac's Avatar
Drives: BRZ Premium
Sounds like your better off buying a small tow trailer or extended hitch and a few jerry cans of your preferred gas.
By the way you sound, are you Canadian eh?
Old 08-06-2018, 10:46 PM   #28
humfrz
DANG, I reckon you plan on taking a few side trips -
humfrz
mixing e85 (109 octane) with e15 (91 octane) pcguru2000 Engine, Exhaust, Transmission 19 03-08-2022 11:35 PM
100 Octane? hellyvin Northern California 23 07-24-2017 09:01 PM
Do you use 93% octane RichardsFRS Mechanical Maintenance (Oil, Fluids, Break-In, Servicing) 62 02-09-2016 12:21 AM
100 octane race gas: 91 octane ratio? GhostofAkina Scion FR-S / Toyota 86 GT86 General Forum 15 02-08-2013 02:23 AM
93 Octane? ashtray BRZ First-Gen (2012+) — General Topics 175 04-04-2012 01:22 PM
